sw4400
Random CTA
9 minutes ago, jajuan said:
The link in your post redirects back to the beginning of this thread instead of a video you apparently were trying to share.
This smells like some sort of database error, rather than the commenter's, so I so reported it to the administrators.
Share this post
Link to post
5 minutes ago, Kevin said:
Just before the link was fixed, I copied and pasted the link in a separate window, and @YoungBusLover was right in how mind boggling the content is.
Share this post
Link to post
10 hours ago, YoungBusLover said:
I'm just amazed at this.
Now that it's fixed, the only thing unusual is that there is a Starbucks on 47th St., but it was at Cicero.
I don't see what the photographer's big deal was, as the bus was legally in the left turn lane and the bus driver isn't able to see if someone is behind him.
Share this post
Link to post
3 minutes ago, Pace831 said:
The uploader seems to be blaming the bus driver for not backing up, but the problem is the truck driver's inability to judge whether and how he should turn.
Also whether someone should be driving a double trailer in the city, except to get to I-55.
Share this post
Link to post
I'm guessing the question that came across the photographer's mind is though the bus was legally in the left turn lane, could the operator of the bus have safely reversed the bus enough to allow the truck to complete its turn rather than stare the truck driver down for close to 3 minutes with both of them causing surrounding traffic to do unsafe maneuvers to get around them while they both faced off. I would say though the trucker did appear to cause the situation considering he did have cars passing to his right before he finally maneuvered out of the bus's way so that the bus could complete its left turn.
Share this post
Link to post
There's hopefully a logical reason for this....... I don't know what, if any, there is. Only someone familiar with CTA operations will know.....
  • Does the CTA actually get some computer report from the vehicles when a bus is put into "R" and they then question and possibly discipline the driver from using reverse? Is it restricted from use unless in dire situations like a no-other-option scenario, or if the bus is stuck in snow, requiring rocking to try to get the bus moving again?
I guess only someone with CTA experience as a Bus Operator will be able to answer this, though.....
Share this post
Link to post
It may be more self-actuating, i.e. if there isn't someone directing the driver while backing up and he/she hits a car behind him/her, heads will roll.
Share this post
Link to post
The best thing to do at certain intersections that are known for large vehicle turns is to NOT pull all the way up to the intersection,  especially if you don't have the Green light.   This alone will allow trucks and buses to turn easily and eliminates the need for a bus or truck to back up.  I've done it before with no problems.   Usually car drivers don't think about it at all,  but it should be second nature to  commercial vehicle operators.
It wouldn't hurt to have a white stripe in the turn lane that is further back from the intersection to let left turning vehicles know where they should stop.
Share this post
Link to post
I believe it was said before that CTA bus operators are not allowed to reverse while passengers are on board. I can't answer your question of whether the bus is equipped with an event recorder that would potentially allow an operator to get in trouble for reversing. However, I doubt that putting the bus in reverse would trigger some kind of alert that management would see.
Share this post
Link to post
Of course, the next question is whether the traffic signal has a detector loop, in which case if the vehicle doesn't stop on it, the green arrow will never show. For instance, my father used to stop well back of the stripe, and wondered why he never got an arrow and drivers behind him were honking.
Share this post
Link to post
What happened to your father certainly is true in the suburbs,  but city intersections have timed cycles so generally not getting an arrow wouldn't be a problem.
Share this post
Link to post
I did approach a Bus Operator tonight at work and asked them about reversing the bus, and the Operator told me they are not permitted to put the bus in reverse, that the vehicles must navigate around the bus. I didn't go into much more than that with the Operator, but that's what I was told. I did explain the video and how the semi-truck was trying to make a turn with the bus in the turn lane, Operator again said the semi must navigate around the bus.
Share this post
Link to post
While Chicago installs loop detectors at many signalized intersections, they're rarely used, unlike every suburb, where they're always used.
There are working detectors at Clark & Devon, they were used for maybe three weeks several years ago, but now they just use the timers to control the lights.
Chicago also disconnects the button for pedestrians to get a walk light to cross the street at almost every street.
The Chicago Department of Traffic Engineering is run by crazy people. Many years ago, an article about the department was in the Tribune. In it, one of the engineers was quoted as saying "we don't believe in left turns", which is one of the looniest things I've ever heard!
Share this post
Link to post
But then that was the basis of the [presumably dead] Ashland BRT.
Share this post
Link to post
They can do it but if they are not comfortable they shouldn't. According to the cdl rules of the road I believe I read that they are not supposed to back up and go right without a lookout assistant. Because they have a blind spot behind the bus. Now I dont know what happens at the garages but maybe the buses pull straight out but that could be argued on the Elston fence at the glen.
Then we have the wye turns to think about but yet again we don't have them now and the rules may be different than in the 60s.
Share this post
Link to post
"No backing up", in this case, would be a matter of CTA policy rather than rules of the road. I believe it was stated a few years ago that the rule only applies when passengers are on board, which may partially answer your question of what is done at the garage.
Share this post
Link to post
CTA rules or not the state guidelines should trump that. But of course they could be assisted at the garage unofficially.
Share this post
Link to post
The guideline you cited is just that, a guideline. The use of a spotter while blind side backing is only a suggestion. CTA could certainly implement a policy that prohibits or restricts backing up, as it does not conflict with state law.
Share this post
Link to post
A few fun facts for those who may remember:
(Copied from the chicago-l.org website:)
"In honor of the 125th anniversary of the start of "L" service this year, we present these events that occured on this date, January 30:
1989: Evanston Express trains began stopping at Belmont, Fullerton and Chicago; express surcharge collected by conductors south of Howard double regular surcharge.
1994: Madison/Wells station closed, for replacement by Washington/Wells"
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
