Buses Coming out Of The Garage And Going Back In
More than likely these are buses that are or will have repairs done to them. Many times when they are parked in the garage, there is a certain aisle or bay that they will be pulled into if there is some work that needs to be done. If the work is minor, it may be assigned to a run and either quick fixed or sent out with the intention to repair later...but if it is not minor and requires more attention, they will not be assigned to a run and will eventually be moved, which is probably what you saw (kind of moving something from the to do list to the do list).
