Wilmette fireworks shuttle
MRChiCity
1 hour ago, MRChiCity said:
Well PACE Northshore has not the Wilmette fireworks shuttle since 2019, I suspect that the ongoing man-power shortages are a large part of the reason why. BTW how bad is the man power shortage across the various divisions?
Probably the suspect had nothing to do with it. According to the Wilmette Park District site:
Apparently that was sufficient.
  • 1 year later...
21 minutes ago, MRChiCity said:
Its back!!!https://wilmettepark.org/event-list/fun-fireworks/ place your bets on what its routing will be?
Only thing relevant (other than  there will be a bus)  is that the lot is at Loyola Academy instead of Edens Plaza. How it goes "direct" doesn't matter, unless the riders get stuck in a traffic jam. Also. $4.50 seems a bit steep.
I figure it will go down Lake, as it's a large arterial directly from the academy to gilson park. $4.50 is a bit pricey, but for the intended audience, it is reasonable enough. I do wonder, why not old orchard?
Cheaper then Uber or lyft if they are surging
