MRChiCity Posted July 5, 2023 Author Report Posted July 5, 2023 Well PACE Northshore has not the Wilmette fireworks shuttle since 2019, I suspect that the ongoing man-power shortages are a large part of the reason why. BTW how bad is the man power shortage across the various divisions? Quote
Busjack Posted July 5, 2023 Report Posted July 5, 2023 1 hour ago, MRChiCity said: Well PACE Northshore has not the Wilmette fireworks shuttle since 2019, I suspect that the ongoing man-power shortages are a large part of the reason why. BTW how bad is the man power shortage across the various divisions? Probably the suspect had nothing to do with it. According to the Wilmette Park District site: Apparently that was sufficient. Quote
MRChiCity Posted June 9 Author Report Posted June 9 Its back!!!https://wilmettepark.org/event-list/fun-fireworks/ place your bets on what its routing will be? Quote
Busjack Posted June 9 Report Posted June 9 21 minutes ago, MRChiCity said: Its back!!!https://wilmettepark.org/event-list/fun-fireworks/ place your bets on what its routing will be? Only thing relevant (other than there will be a bus) is that the lot is at Loyola Academy instead of Edens Plaza. How it goes "direct" doesn't matter, unless the riders get stuck in a traffic jam. Also. $4.50 seems a bit steep. Quote
Elkmn Posted June 12 Report Posted June 12 On 6/9/2025 at 10:31 AM, MRChiCity said: Its back!!!https://wilmettepark.org/event-list/fun-fireworks/ place your bets on what its routing will be? I figure it will go down Lake, as it's a large arterial directly from the academy to gilson park. $4.50 is a bit pricey, but for the intended audience, it is reasonable enough. I do wonder, why not old orchard? Quote
Busjack Posted June 12 Report Posted June 12 2 minutes ago, Elkmn said: I do wonder, why not old orchard? Depends on if the property owner gives permission, and Old Orchard Road is all torn up. Quote
Elkmn Posted June 12 Report Posted June 12 1 minute ago, Busjack said: Depends on if the property owner gives permission, and Old Orchard Road is all torn up. It's been a while since i was last there. Is there still construction going on? Quote
Busjack Posted June 12 Report Posted June 12 1 hour ago, Elkmn said: It's been a while since i was last there. Is there still construction going on? Yes. It doesn't look like there has been much progress, especially around the Edens Expressway and the Hampton Inn. 1 Quote
MRChiCity Posted June 12 Author Report Posted June 12 19 hours ago, Elkmn said: I figure it will go down Lake, as it's a large arterial directly from the academy to gilson park. $4.50 is a bit pricey, but for the intended audience, it is reasonable enough. Cheaper then Uber or lyft if they are surging Quote
Elkmn Posted June 12 Report Posted June 12 3 hours ago, MRChiCity said: Cheaper then Uber or lyft if they are surging Well that's a given Quote
MRChiCity Posted June 24 Author Report Posted June 24 chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://d11ixze0kvt635.cloudfront.net/wp-content/uploads/2025/06/19084646/FF25_PUBLIC_EventMap_V4.pdf Looks like they moved the bus drop off/loading area to Sheridan it used to be at Michigan and Washington. Any thoughts as to why this was done? Quote
MRChiCity Posted June 29 Author Report Posted June 29 Watched the June park board meeting video, The park district is augmenting the service with two of there buses and drivers. Quote
MRChiCity Posted August 13 Author Report Posted August 13 The July and August park board meetings mentioned that the service was a relative success although ridership was low. The August park board meeting mentioned that they are looking at bringing some version of the service back next year. Possibly adding two additional stops along lake and adding one to the Ryan field lots. How they would accomplish that I don't know Quote
