jesi2282 Posted June 24, 2006 Report Share Posted June 24, 2006 The new Pink Line Schedule is now on CTA's web site, as well as the new Blue Line Schedule. http://www.transitchicago.com/maps/rail/rail.html Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 24, 2006 Report Share Posted June 24, 2006 You must have done some good detective work, because your link worked, while the "Train Schedules" link on the CTA home page did not. Turns out the difference is that the old one is .html and the new one is .htm. Clicking on the CTA home page, you can get to the new one by clicking on "Service Improvements." [This gives one a couple of days to compare the old and new schedules, to see, like trainman indicates, whether there was a service cutback, especially on the O'Hare branch.]--Turns out, not so fast. If you click on a Blue Line only station on either map, you get the same pdf. The Douglas one differentiates by having a "bp" prefix--presumably "blue pink." I suggest saving a Blue Line schedule tonight, and compare it when it does get swapped. Quote Link to comment Share on other sites More sharing options...
