Guest Posted June 27, 2007 Report Posted June 27, 2007 I saw two clips on the right side, above the run number board, that were just high enough to hold the route slips that are used when the destination sign is down without covering the run number. On one hand I hope that's what the clips are going to be used for. They'll be better than defective farebox stickers or masking tape. On the other hand it means that the destination signs are so bad that such a solution had to be found and that just plain sucks. Quote
rmadisonwi Posted June 28, 2007 Report Posted June 28, 2007 Actually, those clips were used to hold the contestant's number on the windshield during the garage bus roadeos the last two weekends. Someone just forgot to take them off of that bus. Quote
Busjack Posted June 28, 2007 Report Posted June 28, 2007 Again, when we assume... Was in fact the destination sign out when you saw the clips (if the bus engine was on, as I have seen that turning off the engine also turns off the sign)? While there have been some problems with CTA Luminator signs, I haven't heard about much with the Twinvision ones. Quote
Guest Posted June 28, 2007 Report Posted June 28, 2007 Again, when we assume... Without assumptions this board would be dead as a door nail! The sign was working just fine and we were bouncing along Central towards Caldwell. The clips seemed to be in the perfect place to hold the slips that we all know too well. Assumption made? You bet. Quote
