andrethebusman Posted September 3, 2024 Report Posted September 3, 2024 Kindly clarify - current(?) maps show 4 local via Columbus - South Water - Michigan while X4 is shown via Columbus - Wacker - Michigan. Is this correct? If so, when was X4 rerouted? Quote
Tcmetro Posted September 4, 2024 Report Posted September 4, 2024 Transit app shows both routes using Michigan, Randolph, and Columbus to the layover, then Columbus, Wacker, and back to Michigan. South Water was closed recently, which prompted a new route for the 124, and I believe also for the 6. Quote
jajuan Posted September 5, 2024 Report Posted September 5, 2024 On 9/3/2024 at 4:08 PM, andrethebusman said: Kindly clarify - current(?) maps show 4 local via Columbus - South Water - Michigan while X4 is shown via Columbus - Wacker - Michigan. Is this correct? If so, when was X4 rerouted? On 9/3/2024 at 7:58 PM, Tcmetro said: Transit app shows both routes using Michigan, Randolph, and Columbus to the layover, then Columbus, Wacker, and back to Michigan. South Water was closed recently, which prompted a new route for the 124, and I believe also for the 6. The 6 hasn't been on South Water in years. It had been terminating at Columbus near where Upper Wacker ends and using that last portion that wraps around the ramp to Lower Wacker to turn around. The city did some work on that portion a couple of years ago that facilitated a route change of the 6 to its present form. The work ended some time ago, but the 6 never reverted back to that prior form. When South Water was closed, that triggered a change in the routing of the 4, X4, 20 (rush hour Illinois Center marked trips), and the 124. So the map's routing for the 4 is incorrect, but for the X4 it is correct if I'm picturing the initial question correctly. Quote
andrethebusman Posted September 10, 2024 Author Report Posted September 10, 2024 So what is current 6 turnaround? Stop list still shows "Columbus & South Water NW corner", "Columbus & Randolph NW corner" and "Randolph and Stetson NE corner" as stops, but not Wacker and Columbus WB. Is the stop list out of date then? Quote
Busjack Posted September 11, 2024 Report Posted September 11, 2024 4 hours ago, andrethebusman said: So what is current 6 turnaround? Stop list still shows "Columbus & South Water NW corner", "Columbus & Randolph NW corner" and "Randolph and Stetson NE corner" as stops, but not Wacker and Columbus WB. Is the stop list out of date then? Bus Tracker map shows the following, which I assume is most current: Southbound progression: v Northbound progression:: Quote
