#7300's MAN articulated Lifetime Assignments, Retirements & Other Info
BusHunter
These are the assignments for the #7300's artics we got from Seattle.
This is the retirement list for the #7300's as they were being phased out. #7380 had already been retired in 2003.
And these are there former Seattle numbers along with what livery they had while in Chicago.
I have a newspaper article of a #7300 that burned up at 47th/Dan Ryan. It shows it pretty much demolished. I can't seem to find out what bus number it was though. When I find the article i'll post it.
Found a whole bunch of pictures on the #7300 fire at 47th/Dan Ryan Flickr under artistmac's profile. If you check his photostream he basically has the accident start to finish.
From that stream, 7327. The flames up the articulation joint are sure impressive.
