pace2322 Posted April 28, 2006 Report Posted April 28, 2006 Hey guys just want to let u know heres some buses u wont see on the road any time soon or not at all now. 2322 out of service do to fire will not fix 2361 out of service i been told ran over a person and the lawers dont want pace to used that bus anymore,6047 Brake fire will not fix,6173 hit a truck on 194 not going to fix 6241 Hit a truck in Joliet may be out of service for good and 6634 hit a pace bus that wil be fix someday. Quote
Busjack Posted April 28, 2006 Report Posted April 28, 2006 Thanks. I had previously noted that I had seen (from outside the fence) 6173 stripped in the South Holland yard and wondered why. The damage must be in the front, since it looked as though they were trying to save the body by putting plastic panels over the windows, but I guess not. Apparently cannibalized. 6634 must have been the one that hit the other Pace bus in Elgin about a month ago. From the TV report I saw, the windshield was damaged (in the manner safety glass usually is) but one couldn't tell from the video if there was other damage. (P.S., I also recognized the driver's name from another group.) As usual, it looks as though the transit agencies around here (I certainly include the South Shore) are wrecking the new stuff first. CTA isn't immune, considering 6700 and at least 3 NABIs were seriously damaged (7520, the one with the fire on LSD, and the one that hit the apartment building on Jackson Blvd.). However, it looks like CTA also wrecks a lot of old equipment too. About 1-1/2 years ago, Pace 6246 was in the South Holland yard with a smashed front end, but maybe they repaired that. Quote
Busjack Posted May 23, 2006 Report Posted May 23, 2006 Doing like some other members and trolling around transit sites, I found a picture in the Orion VI portion of the Orion Tutorial portion of Transitalk, which is apparently a stripped Orion VI in the Pace South Holland facility yard. Is that 6047? It is apparently fairly recent, since there is a 2200 with the number painted over to the left of it. Transitalk also has a couple of wrecks in its CTA/TMC and CTA/NovaBus galleries. Also, for you photographers, is there any secret to getting inside the yard fence (that you would want to divulge)?:shy: Quote
pace2322 Posted May 23, 2006 Author Report Posted May 23, 2006 Yes that will be 6047.Btw i have some pic of 6173 inside south like 3 to 4 hours after it hit the truck on 94 in indinana.Does anyone want to see them? Quote
Busjack Posted May 23, 2006 Report Posted May 23, 2006 Sure. All that was recently visible (from outside the fence) was it after it was stripped. Quote
RIPTA42 Posted May 24, 2006 Report Posted May 24, 2006 Also, for you photographers, is there any secret to getting inside the yard fence (that you would want to divulge)?:shy: Wide-angle and telephoto lenses are a good start . Quote
Busjack Posted May 24, 2006 Report Posted May 24, 2006 Wide-angle and telephoto lenses are a good start . But does that get you the interior shots? Quote
trainman8119 Posted May 24, 2006 Report Posted May 24, 2006 Also, for you photographers, is there any secret to getting inside the yard fence (that you would want to divulge)?:shy: Although I am not a true photographer, I think the real answer to your question would be simply get to be good friends with either a driver, mechanic or garage superintendant. My first experiences in bus garages were contacts with drivers...my uncle being one (way back when). Quote
