sht6131 Posted August 21, 2021 Report Posted August 21, 2021 Can someone explain why Rte# 72 has 3 810`s. Does it have anything to do with the Air Show? Quote
Policeman Posted August 21, 2021 Report Posted August 21, 2021 23 minutes ago, sht6131 said: Can someone explain why Rte# 72 has 3 810`s. Does it have anything to do with the Air Show? It probably does Quote
Mr.NewFlyer1051 Posted December 10, 2021 Report Posted December 10, 2021 so i went ahead and started my own run number somewhat of a guide of weekday runs past 1pm if anyones interested go ahead and start your own since ima 147 daily user and 3 user Quote
Erin Mishkin Jr. Posted December 11, 2021 Report Posted December 11, 2021 19 hours ago, Mr.NewFlyer1051 said: so i went ahead and started my own run number somewhat of a guide of weekday runs past 1pm if anyones interested go ahead and start your own since ima 147 daily user and 3 user Not to worry I do 90 all the time they got driver switches at blue line, but when I ride the 147 each time I somehow don’t pay attention Quote
Sam92 Posted December 11, 2021 Report Posted December 11, 2021 6 hours ago, Erin Mishkin Jr. said: Not to worry I do 90 all the time they got driver switches at blue line, but when I ride the 147 each time I somehow don’t pay attention 147 is relatively unchanged. I think what mainly switched up at NP is no longer having 144, 145, 146 and 148 all In the P420 bracket. 146 is accurate as far as I know. I think what really needs attention might be a little bit of 77th and to take any runs out of a garage that are extras (school trips from another garage etc; those are gonna be based off whatever mainline that run is rehooked with so should be either left blank or make a note of what those might be interlines with) with a grain of salt. I know 103rd is pretty spot on cause I live on Jeffery and work doordash, UberEats and grubhub in Hyde park at night so all those have checked out. Quote
Sam92 Posted December 11, 2021 Report Posted December 11, 2021 JP might have 81W, 88, 68 and 85A as the same bracket. 95th red line on the other hand ditched that practice. 34/119[1300-1400], 111/115 [1101-1140] are the only runs that interline, others do a half on state then the rest on feeder so ignore anything that has 1200; that came off state at some point. Quote
Sam92 Posted December 11, 2021 Report Posted December 11, 2021 And of course the midways that aren’t a main route are also interlined (55A/55N/62H/59/165/63W) under 6620-6700. Sundays 63Ws tend to interline with a 63 Quote
Sam92 Posted December 11, 2021 Report Posted December 11, 2021 If you want more accuracy I’d suggest doing this on the weekend. Weekdays you have a lot of wilder interlines that may throw you off. Quote
Mr.NewFlyer1051 Posted December 12, 2021 Report Posted December 12, 2021 1 hour ago, Sam92 said: JP might have 81W, 88, 68 and 85A as the same bracket. 95th red line on the other hand ditched that practice. 34/119[1300-1400], 111/115 [1101-1140] are the only runs that interline, others do a half on state then the rest on feeder so ignore anything that has 1200; that came off state at some point. yea 81W/88/68/85A use same run numbers Quote
