Danielsmusic Posted February 13, 2008 Report Posted February 13, 2008 Does anyone know what the X99 was? I'm not talking about the old southwest express routes; I'm referring to the route that operated in the early 2000s. I looked online, but couldn't find any real info. Quote
jesi2282 Posted February 13, 2008 Report Posted February 13, 2008 I remember this route, it didn't run for too long due to very low ridership. Here are 2 press releases from CTA: http://www.transitchicago.com/news/archpre...rticleid=105364 http://www.transitchicago.com/news/archpre...rticleid=102637 Quote
Busjack Posted February 13, 2008 Report Posted February 13, 2008 It was basically to serve the supplier complex east of the Hegewisch Ford plant. Besides the problem supposed cited (flex shifts), it was a low productivity route. Apparently, if you work in the auto industry, you have a car. Not to mention Ford's recent troubles. Quote
Danielsmusic Posted February 13, 2008 Author Report Posted February 13, 2008 I remember this route, it didn't run for too long due to very low ridership. Here are 2 press releases from CTA: http://www.transitchicago.com/news/archpre...rticleid=105364 http://www.transitchicago.com/news/archpre...rticleid=102637 Those were the only things I could find. But, what was the actual routing? What were the stops? Was it a 103rd route? What buses did it run with? Quote
CircleSeven Posted February 13, 2008 Report Posted February 13, 2008 The X99 was carried by 103rd Garage. The route started at 95th & State Red Line Station. The route went via 95th Street, Michigan, 103rd Street, Torrence, 126th Street, Burley Avenue, 123rd Street, Avenue O and back to 126th to go back towards the Red Line. The Stops were the Red Line, 95th & Michigan, 103rd & Michigan, 103rd & Cottage Grove, 103rd Garage, 103rd & Yates, 103rd & Torrence, 106th & Torrence, 112th & Torrence and 123rd & Avenue O at the Campus near the Ford Plant. This route was obviously a shift change route so they had the route running during both rush hour periods (4:40am-6:45am & 2:00pm-5:15pm) and during the late night hours at roughly 11:30pm till about 1:15am. At first I thought this route lasted only 2 Picks but I also remember that August 30th, 2004 bus assignment period lasted until the end of January of 2005 and I thought that route ended at that time when that new pick went into effect. But After reading that second press release posted above, the route lasted almost 11 months. When I saw the buses when they were running the PM rush, I remember seeing a TMC running the X99 but I dunno if they were using an Artic for that route. Quote
Danielsmusic Posted February 13, 2008 Author Report Posted February 13, 2008 The X99 was carried by 103rd Garage. The route started at 95th & State Red Line Station. The route went via 95th Street, Michigan, 103rd Street, Torrence, 126th Street, Burley Avenue, 123rd Street, Avenue O and back to 126th to go back towards the Red Line. The Stops were the Red Line, 95th & Michigan, 103rd & Michigan, 103rd & Cottage Grove, 103rd Garage, 103rd & Yates, 103rd & Torrence, 106th & Torrence, 112th & Torrence and 123rd & Avenue O at the Campus near the Ford Plant. This route was obviously a shift change route so they had the route running during both rush hour periods (4:40am-6:45am & 2:00pm-5:15pm) and during the late night hours at roughly 11:30pm till about 1:15am. At first I thought this route lasted only 2 Picks but I also remember that August 30th, 2004 bus assignment period lasted until the end of January of 2005 and I thought that route ended at that time when that new pick went into effect. But After reading that second press release posted above, the route lasted almost 11 months. When I saw the buses when they were running the PM rush, I remember seeing a TMC running the X99 but I dunno if they were using an Artic for that route. Thank you very much for the information. Quote
qwantae Posted February 14, 2008 Report Posted February 14, 2008 I was wondering what happened to that route, haven't seen it since summer 2005 on E.103rd/Michigan coming from 95/Dan Ryan Red Line in late evening. Quote
