PACE 834 Posted January 25, 2009 Report Posted January 25, 2009 Does anyone know what radio frequencies either CTA or PACE uses for bus operators to contact control?I appreciate any info provided. Quote
trainman8119 Posted January 26, 2009 Report Posted January 26, 2009 This would be the frequency for CTA: Bus Supervisor Channels: 470.5375, 470.6375 CPD Transit Detail: 472.9375 Pace has the following: 858.2375, 813.2375, 858.4625, 813.4625, 858.4875, 813.4875, 858.7375, 813.7375 and 858.9625 The Pace frequencies are a high frequency transmission (like it is some big secret or something). I have found that there is no real rhyme or reason to what comes out on the Pace Frequencies. Sometimes any one of those may have conversations from West, then you might hear something from South. Two days later you might hear Fox Valley and Elgin on the same channel. Also you may hear a call go out on one channel and the reply come through another...sometimes it is real hard to follow. Quote
PACE 834 Posted January 26, 2009 Author Report Posted January 26, 2009 Thanks Trainman,do you know if PACE operates on a trunked system or not since their frequencies are in the 800 band range?Also,do they go by run# as their radio designation? Quote
trainman8119 Posted January 26, 2009 Report Posted January 26, 2009 Thanks Trainman,do you know if PACE operates on a trunked system or not since their frequencies are in the 800 band range?Also,do they go by run# as their radio designation? I am not sure about the trunk system. They will call in either by run our route number depending on the garage. I'll have to check the Police Call book to be sure, but there might be some 400 band frequencies. I remember finding the 800 bands because that is where the supervisors would brodcast, and as a driver at the time I found that out, I wanted to hear some of the things that they would talk about on the secure channels which were on the higher supposedly more secure frequencies. I bought a scanner that had the higher frequencies, thus had a little bit more I could track. Quote
Chicago13 Posted January 26, 2009 Report Posted January 26, 2009 The PACE system is a 800mhz Motorola Type II trunked system. The link below is the RadioReference.com page with all of the frequency information on it. PACE Radio Frequencies Quote
Busjack Posted January 26, 2009 Report Posted January 26, 2009 One should also consider that the Orbital System used by CTA bus operatiors is essentially what we would now call a text messaging system, not voice. See this article. So, there would be nothing to hear. Quote
Northsider Posted January 28, 2009 Report Posted January 28, 2009 I have all the frequencies of the L routes: Red, Blue, etc, as well as the emergency frequency. I just need to get new batteries for my Motorolla to get them out of there. Quote
Guest Posted January 29, 2009 Report Posted January 29, 2009 Does anyone know what is a good brand of scanner to buy? Id like to listen in on radio frequencies. Quote
PACE 834 Posted January 29, 2009 Author Report Posted January 29, 2009 I've got a handheld model PRO-94 by Radio Shack(1000 channel dual trunking w/800 band capability)and a desk top model PRO-2040 100 channel also 800 band capability.Both have been very reliable for me. The desk top model is also from Radio Shack. Quote
BusHunter Posted January 29, 2009 Report Posted January 29, 2009 I have all the frequencies of the L routes: Red, Blue, etc, as well as the emergency frequency. I just need to get new batteries for my Motorolla to get them out of there. If you want to know the "L" frequencies here they are. The red line is 471.1125, the green line is 471.0625, the brown line is 471.0875, the blue line is 471.0375 I think the orange may show up on either the brown or green line frequency. If you wanted to know the bus frequency like trainman stated it was 470.5375 or what CTA officials refer to as channel 2. Now on that channel they sometimes say they want to 10-65. That's the code to change channels off the main frequency. They would switch to channel 3, but you can still follow the action if you switch to 492.2375 Back when operators used the telephone on board the bus, you could track them too reporting there defect to the controller. I forgot that number, but I remember a simple search in the 470 -512 range picked it up. Most city frequencies are here fire, police you name it. 1 Quote
