Bus1807 Posted October 13 Report Posted October 13 1 hour ago, Bus1807 said: #7901 broken down on the 29. Returned to service at 11am. Quote
Bus1807 Posted October 20 Report Posted October 20 (edited) 19 hours ago, Bus1807 said: #4024 broken down at State and Polk. Returned to service on the 22 Clark at around 8am. Edited October 20 by Bus1807 Said 10am and not 8am Quote
Erin Mishkin Jr. Posted Saturday at 12:45 AM Report Posted Saturday at 12:45 AM I was riding #8799 on the 96 today and I noticed this sheet of paper listing the buses that were at the North Park Garage trouble track at 2:07 Am This morning. Quote
Bus1807 Posted Saturday at 01:38 AM Report Posted Saturday at 01:38 AM (edited) 55 minutes ago, Erin Mishkin Jr. said: I was riding #8799 on the 96 today and I noticed this sheet of paper listing the buses that were at the North Park Garage trouble track at 2:07 Am This morning. Is that why #8810 has been out for a while? Edit: It returned to service this morning I’m pretty sure. Edited Saturday at 01:41 AM by Bus1807 Quote
Erin Mishkin Jr. Posted Saturday at 01:51 AM Report Posted Saturday at 01:51 AM 12 minutes ago, Bus1807 said: Is that why #8810 has been out for a while? Edit: It returned to service this morning I’m pretty sure. It’s probably been broken down for 2 weeks Quote
Bus1807 Posted Saturday at 02:04 AM Report Posted Saturday at 02:04 AM 13 minutes ago, Erin Mishkin Jr. said: It’s probably been broken down for 2 weeks Probably. Or maintenance because from what I’m seeing, it was last seen on the 97 on 10/8/26 with all trips completed with no issue. Quote
Bus1807 Posted Saturday at 02:23 PM Report Posted Saturday at 02:23 PM 12 hours ago, Bus1807 said: Probably. Or maintenance because from what I’m seeing, it was last seen on the 97 on 10/8/26 with all trips completed with no issue. Wait, I looked at the list and it did break down on the 97 because it lists a “dead motor” on 10/8/26 which was when it was last seen. Quote
Bus1807 Posted 22 hours ago Report Posted 22 hours ago #8642 broke down on the 7 on 10/16/26. Hasn’t been seen since. Quote
Bus1807 Posted 9 hours ago Report Posted 9 hours ago I believe #1891 broke down on the 93 on 10/23/26. It was supposed to make a return trip to Davis and right as it left Logan Sq it sat for a long while and then disappeared off the tracker. Quote
Elkmn Posted 1 hour ago Report Posted 1 hour ago 8 hours ago, Bus1807 said: I believe #1891 broke down on the 93 on 10/23/26. It was supposed to make a return trip to Davis and right as it left Logan Sq it sat for a long while and then disappeared off the tracker. D40 on the 93??? Quote
Busjack Posted 56 minutes ago Report Posted 56 minutes ago 4 minutes ago, Elkmn said: then disappeared off the tracker. I mentioned before to you that "disappearing off the tracker" can mean a lot of things, and is certainly not worth posting. You're starting to sound like @79th to lakefront 1302--just sitting on a tracker and thinking every glitch is worth posting. Quote
Bus1807 Posted 53 minutes ago Report Posted 53 minutes ago 2 minutes ago, Busjack said: I mentioned before to you that "disappearing off the tracker" can mean a lot of things, and is certainly not worth posting. You're starting to sound like @79th to lakefront 1302--just sitting on a tracker and thinking every glitch is worth posting. Guess you’re right. But I only mentioned this because it still hasn’t returned to service. But still, I will watch what I post. Quote
Bus1807 Posted 22 minutes ago Report Posted 22 minutes ago 42 minutes ago, Elkmn said: D40 on the 93??? Yupppp Quote
Bus1807 Posted 21 minutes ago Report Posted 21 minutes ago 42 minutes ago, Elkmn said: D40 on the 93??? #1574 and #1862 were on the 93 as well on Saturday and yesterday #1105 and #1185 were on it too. Quote
