Busjack Posted May 28, 2014 Author Report Posted May 28, 2014 ....stops for other PACE route.... Although I have not been out there, the stops generally are posted for the particular route. The brochures for 810 and 811 show sample signs. 811 appears to be only a connector between the Blue Line station and the stated attractions, as the brochure says: The Circulator will make stops at the following locations as identified on the map. Look for the bus stop signs at designated pick-up and drop-off locations: • CTA Blue Line Rosemont Station • Donald E. Stephens Convention Center • MB Park Entertainment District • Fashion Outlets of Chicago So, at least for 811, the timepoints conclusion seems correct. Quote
jesi2282 Posted August 4, 2014 Report Posted August 4, 2014 Not surprised... http://www.pacebus.com/sub/schedules/route_notice_detail.asp?Notice_ID=4413 Quote
Busjack Posted August 4, 2014 Author Report Posted August 4, 2014 Not surprised... http://www.pacebus.com/sub/schedules/route_notice_detail.asp?Notice_ID=4413 I guess Brad Stephens didn't want to pay, and that people on Higgins and Devon didn't want to eat lunch at MB Park. Quote
ctrabs74 Posted August 5, 2014 Report Posted August 5, 2014 Not surprised... http://www.pacebus.com/sub/schedules/route_notice_detail.asp?Notice_ID=4413 I guess Brad Stephens didn't want to pay, and that people on Higgins and Devon didn't want to eat lunch at MB Park. Especially with numerous, and presumably less expensive, options on Higgins near River Road. Speaking of the 811, it's too bad the roads leading into MB Financial Park can't accommodate at least a 30-ft Eldorado, because they could certainly use them. On some trips, those paratransit buses weren't cutting it as they were full. The trip my girlfriend and I were on nearly had a standing load. Quote
Busjack Posted August 5, 2014 Author Report Posted August 5, 2014 .... Speaking of the 811, it's too bad the roads leading into MB Financial Park can't accommodate at least a 30-ft Eldorado, because they could certainly use them. On some trips, those paratransit buses weren't cutting it as they were full. The trip my girlfriend and I were on nearly had a standing load. At this point, probably not one available, unless they were going to take one from some feeder route. However, maybe you have the explanation for why they are using Aerolites instead of Aerotechs. Quote
mel bernero Posted May 23, 2016 Report Posted May 23, 2016 The two "buses" used on the circulator have a new wrap. See attached. Quote
Pace831 Posted May 23, 2016 Report Posted May 23, 2016 19 minutes ago, mel bernero said: The two "buses" used on the circulator have a new wrap. I rode 5302 on the circulator on Monday and thought it was unusual that an unwrapped bus was on that route. Maybe this explains why. There was one wrapped bus running as well, I don't remember the number. Quote
Busjack Posted May 22, 2018 Author Report Posted May 22, 2018 Passenger Notice that Pace is apparently using a real bus* for Chicago Dogs games, in addition to the circulator. _____________ *Based on "Trips depart from the Route 222 bus stop at Rosemont Transit Center; look for “Impact Field” on the headsign of the bus." Quote
rotjohns Posted May 22, 2018 Report Posted May 22, 2018 59 minutes ago, Busjack said: Passenger Notice that Pace is apparently using a real bus* for Chicago Dogs games, in addition to the circulator. _____________ *Based on "Trips depart from the Route 222 bus stop at Rosemont Transit Center; look for “Impact Field” on the headsign of the bus." I can't imagine a heavy crowd for this so if a real bus is used, I'd think a 30 footer would be appropriate. Quote
mel bernero Posted November 4, 2018 Report Posted November 4, 2018 17065 and 17069 have been wrapped for the Rosemont Circulator Quote
Busjack Posted November 4, 2018 Author Report Posted November 4, 2018 6 hours ago, mel bernero said: 17065 and 17069 have been wrapped for the Rosemont Circulator I guess that's the end of the 5980s. Quote
