trainman8119 Posted February 13, 2014 Report Share Posted February 13, 2014 Over the past month or so, when I get off the Kennedy about 4:20 am, there is a Madison bus headed east the never has a destination sign lit. The only thing that is lit is the run box, which Monday I noted that it was run 050 out of Chicago. During this time, only once has there been a lit destination. It doesn't matter what bus it is. I have seen Novas, 1400s, 1800s, 1900s, 2000s and today a 1000. So it is not that a single bus has a problem. Can't see the side sign, but the front is dark as well as the rear route number sign. Quote Link to comment Share on other sites More sharing options...
artthouwill Posted February 13, 2014 Report Share Posted February 13, 2014 Over the past month or so, when I get off the Kennedy about 4:20 am, there is a Madison bus headed east the never has a destination sign lit. The only thing that is lit is the run box, which Monday I noted that it was run 050 out of Chicago. During this time, only once has there been a lit destination. It doesn't matter what bus it is. I have seen Novas, 1400s, 1800s, 1900s, 2000s and today a 1000. So it is not that a single bus has a problem. Can't see the side sign, but the front is dark as well as the rear route number sign. My guess is that the daytime running lights are on, which would mean that the destination sign would be poorly lit. It would be less bright during the day than if all of the lights (taillights and markers) were on. The destination sign would be brighter and well lit. Next time check and see if the rear lights (tail and markers) are on. If not, then the daytime running lights are on. Because the headlights are always on (when daytime running lights are on), a lot of drivers assume that ALL of their lights are on and that is not true. It seems that a specific driver is guilty of this. The one time that you actually saw a lit destination sign was either a sub driver or someone gave that driver the bus with the lights in the proper position. Quote Link to comment Share on other sites More sharing options...
Busjack Posted February 13, 2014 Report Share Posted February 13, 2014 My guess is that the daytime running lights are on, which would mean that the destination sign would be poorly lit. .... I don't think it is that. Due to the consistency (and also the rear route number box being out), the gps probably has the sign off, but isn't displaying out of service. Note also that trainman said 4 a.m., and it sure isn't daylight yet. Also, if it was 5050,it would be the last run of the night, according to the garage page. That page also indicates that it could be setting up for route 120 or 121. Quote Link to comment Share on other sites More sharing options...
jajuan Posted February 13, 2014 Report Share Posted February 13, 2014 I don't think it is that. Due to the consistency (and also the rear route number box being out), the gps probably has the sign off, but isn't displaying out of service. Note also that trainman said 4 a.m., and it sure isn't daylight yet. Also, if it was 5050,it would be the last run of the night, according to the garage page. That page also indicates that it could be setting up for route 120 or 121. If we're talking about 4 a.m., then the setting up for 120 or 121 part would be unlikely since service on those routes starts between 6:40 and 6:45 a.m. Quote Link to comment Share on other sites More sharing options...
