strictures Posted May 23, 2015 Report Posted May 23, 2015 How long would it take to build a shoefly around the washed out section to get the line back in service? After all, the MWRD's contractor will have to pay for it, along with the lost revenue due to running the bus shuttles & possibly the layoffs of the shop workers, if they can't be reassigned to other shops for the duration of the closing. Even if it's a slow zone at 5 MPH, it would be an improvement over what's going on now.It can't be a very long section & I assume they could go through the area where the District is building the new sewage plant for several weeks without disturbing the construction, since it's probable that they've had to shut that down.I'd think the CTA would like to get access from the system to the Skokie Shops even more than getting the Swift back in operation. Quote
trainman8119 Posted May 23, 2015 Report Posted May 23, 2015 My guess would be no less than it would take to just complete repair on the damaged area.. The grade is damaged and washed/collapsed away.You would need some sort of grade to build the shoe fly, and there may not really be room to do so anyway, as is this next to the bridge (IIRC).Good thought, but probably not a real solution this time. Quote
rvwnsd Posted May 24, 2015 Report Posted May 24, 2015 I think trainman is right. If it is any consolation, we had some very heavy rains here in San Diego that left several parking lots (and the cars parked within) under three feet of water after a flash flood.Mother Nature reminding us who's boss. Quote
Busjack Posted May 24, 2015 Report Posted May 24, 2015 trainman is correct. One would still have to build some sort of incline to get up to the steel bridge that crosses McCormick Blvd and the North Shore Channel.The best perspective of the site is at about 1:29 of this WGN video (top one). Quote
strictures Posted May 24, 2015 Author Report Posted May 24, 2015 My guess would be no less than it would take to just complete repair on the damaged area.. The grade is damaged and washed/collapsed away.You would need some sort of grade to build the shoe fly, and there may not really be room to do so anyway, as is this next to the bridge (IIRC).Good thought, but probably not a real solution this time.I was thinking more like the shoefly the CTA built over the Wood St. rail yards, just north of the 18th St. station maybe 15- 20 years ago. That was on girders. Only a single track shoe fly would be needed due to the low volume of trains & it possibly could be a gantlet, to avoid switches.Just a thought. Quote
