sht6131 Posted April 1, 2021 Report Posted April 1, 2021 Have not been able to get into it in over a weeks. Is it my computer. Any suggestions? Quote
Erin Mishkin Jr. Posted April 1, 2021 Report Posted April 1, 2021 You need to get onto an incognito tab, and then once you do that, type in the URL for cta.maths22.com. Once you do, you should press the "Advanced" button and then after that press the "Proceed to cta.maths22.com (unsafe). Then you'll be back in Math's again. Quote
Erin Mishkin Jr. Posted April 1, 2021 Report Posted April 1, 2021 4 minutes ago, sht6131 said: Thanks I`ll try it You're welcome! Quote
sht6131 Posted April 1, 2021 Author Report Posted April 1, 2021 It worked, We learn new things everyday. Thanks again Erin. Quote
Erin Mishkin Jr. Posted April 1, 2021 Report Posted April 1, 2021 3 minutes ago, sht6131 said: It worked, We learn new things everyday. Thanks again Erin. No problem. Quote
pudgym29 Posted March 25, 2024 Report Posted March 25, 2024 Could someone else here on the forum send an e-mail to Jacob Burroughs [Maths22]? I sent one two weeks ago. I ponder Gmail bounced it because it was not originating from Gmail. 😡 What for? The Authority has continued accepting new Nova LFS buses with higher numbers than 8649 ([c.v.: Transsee's tracker]), but he seemingly has not adjusted his API to display them collectively. He should just modify it to accept numbers up to 8949, since it is obvious the Authority will exercise all its options. Then he would be done with it. Quote
Busjack Posted March 26, 2024 Report Posted March 26, 2024 5 hours ago, pudgym29 said: In another thread in another rubric, I chastised Maths22 for not updating the collective roster of 8350-series Nova buses. But if you go to his 'run history for individual buses', you can play with bus numbers one-at-a-time to detect which buses are on the property and making runs, including buses numbered higher than 8649. 5 hours ago, pudgym29 said: Could someone else here on the forum send an e-mail to Jacob Burroughs [Maths22]? I sent one two weeks ago. I ponder Gmail bounced it because it was not originating from Gmail. 😡 What for? The Authority has continued accepting new Nova LFS buses with higher numbers than 8649 ([c.v.: Transsee's tracker]), but he seemingly has not adjusted his API to display them collectively. He should just modify it to accept numbers up to 8949, since it is obvious the Authority will exercise all its options. Then he would be done with it. What business do you have chastising a volunteer for rendering a service? And what makes you think you can tell others to do this (similar to what made you think others were going to ride from Jeff Park to some bar in Crystal Lake and "query the intrepid conductor")? 1 Quote
