MetroShadow Posted 14 hours ago Report Posted 14 hours ago (edited) On 11/8/2026 at 8:20 AM, Sam92 said: I don't get the point of the New Lenox connection if there's already a SWS/RI connection planned at 74th. Nothing in the document nor Metra's SNP plan mentions the purpose. So this popped up on my YouTube feed tonight: It looks like the goal (in addition to the SWS) is to move the Lincoln Service from the HC (which I didn't know). Would this also connect to and from Union Station as well? Edited 14 hours ago by MetroShadow Edited for context and format Quote
Sam92 Posted 9 hours ago Report Posted 9 hours ago 5 hours ago, MetroShadow said: So this popped up on my YouTube feed tonight: It looks like the goal (in addition to the SWS) is to move the Lincoln Service from the HC (which I didn't know). Would this also connect to and from Union Station as well? Hmm... That actually rings a bell but I never mentioned it 😅. If I remember correctly they did mention Amtrak on the rock and possibly connecting vs the St. Charles. Quote
Sam92 Posted 3 hours ago Report Posted 3 hours ago 11 hours ago, MetroShadow said: So this popped up on my YouTube feed tonight: It looks like the goal (in addition to the SWS) is to move the Lincoln Service from the HC (which I didn't know). Would this also connect to and from Union Station as well? After looking closer at the vid this still doesn't explain the New Lenox connection cause the Amtrak trains would just leave Joliet via the RI district. One thing I had personally contemplated was maybe diverting some Manhattan trains along the RI would somehow encourage more ridership (those are the weakest) while 179th to LaSalle would be its own pattern? Quote
artthouwill Posted 1 hour ago Report Posted 1 hour ago 1 hour ago, Sam92 said: After looking closer at the vid this still doesn't explain the New Lenox connection cause the Amtrak trains would just leave Joliet via the RI district. One thing I had personally contemplated was maybe diverting some Manhattan trains along the RI would somehow encourage more ridership (those are the weakest) while 179th to LaSalle would be its own pattern? I don't think routing any Rock Island trains to Manhattan makes any sense. That section of the route is single track so there's a limit to how many trains that run. Since these two lines are grade separated, a new connection would have to be built to connect the two. It isn't worth the cost. Quote
