#4304 Broke down on the 14 at Roosevelt and Columbus Southbound been sitting there since 1pm this afternoon mobile truck is currently working on it Also #4043 broke down on the 14 as well at balbo and Michigan eastbound but they got it back running back in service as of 17:00
1 hour ago, skarz said:
#4025 broken down on 151 Sheridan. Bus got towed.
#4025 is currently on the 135. If that was #4025 u saw being towed today apparently it got fixed in like 30 minutes as from what i'm seeing it completed its trip on the 151 this afternoon successfully around 2:00pm before being pulled out at around 3:00pm for 135
12 minutes ago, skarz said:
it was, broke down on the 201 and was sitting in the same spot for around a hour before getting fixed and going to the 97. image.thumb.png.7d3de2e342e422c7202a8a8c444728e6.png
That isn't definitive. I've seen trackers mess up interlined routes and have times in the future. Pace is especially bad. 97 and 201 appear to be interlined, and that looks like a normal track.
I'm not saying that happened here, but unless you saw the bus on the side of the road with a mechanics' truck, you don't know.
i did see it on the side of the road, had supervisors checking the engine and everything, i was on my way to downtown chicago.
O.K.
Based on what im seeing, it might have sat oos somewhere. These screenshots show you the time when it last tracked on 201 exactly and when it started exactly on 97 and even where, too.
image.png.95ee9268c61d107927ba1b18b23f4aa7.pngimage.png.317bdb4198dd6d2766a921ccf028abbe.png
3 hours ago, EasyMoney said:
4053 Broke down again on the 6 at 67 and Bennett Eastbound Second time this week it broke down
Has any 103rd artic. not broken down? O.o 9_9
once K gets their artics back from 103rd i promise that bus will barley breakdown😂 cuz it was perfectly fine when it was at K
  • Haha 1
#4035 is broken down in the Belmont/halsted terminal and all the operators been jumping buses for the last 2 hours
#8883 broke down Monday afternoon on lasalle heading NB and was being repaired by a work truck on the street
