Busjack Posted July 25, 2018 Report Posted July 25, 2018 I noted while scoping out Lake Cook that the buses were making an announcement: "Pedestrians: the bus is turning." Turns out that that was not some hack, but added to the specifications for the new buses: The specifications also call for backup cameras. Looks like Jan is now working for Pace. Also, I wonder what engineering staff or consultants Pace has to make the specifications or pass on the requests for approvals. Quote
Pace831 Posted July 25, 2018 Report Posted July 25, 2018 43 minutes ago, Busjack said: I noted while scoping out Lake Cook that the buses were making an announcement: "Pedestrians: the bus is turning." Turns out that that was not some hack, but added to the specifications for the new buses: The 6700s, 17500s, and 18500s have this announcement, in place of "Caution, look both ways" on previous Axess series and MCIs. I'm not sure if the older buses had the announcement updated. As before, the timing seems too late to be useful, as the bus would have almost completed the turn before an operator or pedestrian could react if both were unaware of each other. Quote
artthouwill Posted July 25, 2018 Report Posted July 25, 2018 4 hours ago, Pace831 said: The 6700s, 17500s, and 18500s have this announcement, in place of "Caution, look both ways" on previous Axess series and MCIs. I'm not sure if the older buses had the announcement updated. As before, the timing seems too late to be useful, as the bus would have almost completed the turn before an operator or pedestrian could react if both were unaware of each other. I will try to pay close attention but some of the buses play both announcements simultaneously while others only play the pedestrian announcement. Quote
Busjack Posted July 25, 2018 Author Report Posted July 25, 2018 8 hours ago, Pace831 said: As before, the timing seems too late to be useful, as the bus would have almost completed the turn before an operator or pedestrian could react if both were unaware of each other. I suppose it depends on the speed. The Lake Cook example could be effective, in that the bus is masking a hairpin turn into the terminal, and pedestrians are streaming from the train. But, like most warnings, I'm sure it becomes part of the background noise. Quote
Busjack Posted July 25, 2018 Author Report Posted July 25, 2018 10 hours ago, Pace831 said: in place of "Caution, look both ways" 5 hours ago, artthouwill said: but some of the buses play both announcements simultaneously Wouldn't the look both ways one be directed to departing passengers, rather than pedestrians? Quote
Busjack Posted July 25, 2018 Author Report Posted July 25, 2018 11 hours ago, Pace831 said: The 6700s, 17500s, and 18500s have this announcement I noted that this was added to the spec. The ENC questions included a request for clarification whether Pace wants the system as in the last build, or another brand.So, the correct inference from your observation is that the collision avoidance equipment was part of the build for those series. Quote
Pace831 Posted July 25, 2018 Report Posted July 25, 2018 2 hours ago, Busjack said: Wouldn't the look both ways one be directed to departing passengers, rather than pedestrians? I think it was directing the bus operator to look for pedestrians, because it played during turns rather than when the doors were opened. The specs you cited say "The system shall alert the bus operator and pedestrians", so Pace must have realized they can change the wording of the announcement to get pedestrians' attention as well. My question after reading the specs was whether the newer buses have additional equipment to detect objects that the sides of the bus might impact during a turn, or if they simply changed the announcement for clarity. Quote
Busjack Posted July 25, 2018 Author Report Posted July 25, 2018 37 minutes ago, Pace831 said: My question after reading the specs was whether the newer buses have additional equipment to detect objects that the sides of the bus might impact during a turn, or if they simply changed the announcement for clarity. It seems pretty clear it is additional equipment. There are various references to "Pedestrian Warning--ProTran." and ENC asked if Pace wanted ProTran as in the last build or Mobileye. (Description of the ProTran system). ENC must have asked about Mobileye because it is a more complete system. The specification that the collision avoidance and lane departure system uses a windshield camera means that it is fundamentally the same as in a Toyota, and hence the reason I mentioned Jan. Quote
artthouwill Posted July 25, 2018 Report Posted July 25, 2018 4 hours ago, Busjack said: Wouldn't the look both ways one be directed to departing passengers, rather than pedestrians? Actually the look both ways is directed to the drive as he is turning, though one would think the driver should look both ways BEFORE turning. The caution us is turning is directed at pedestrians. The only passenger warning is the "Please move away from the doors" which plays when someone is in the rear doorway while the bus is in motion. Quote
Busjack Posted October 8, 2022 Author Report Posted October 8, 2022 Pace has a solicitation for: Is for 250 buses, and looks like the signs now in CTA 600s and 8350s (integrated with IBS, but can also show promotions). Quote
MetroShadow Posted October 11, 2022 Report Posted October 11, 2022 On 10/8/2022 at 2:52 PM, Busjack said: Pace has a solicitation for: Is for 250 buses, and looks like the signs now in CTA 600s and 8350s (integrated with IBS, but can also show promotions). May this be a drastic improvement than the old TransiTV's of the 00's. ? 1 Quote
