Guest Posted March 11, 2009 Report Posted March 11, 2009 How can/what makes a bus idle ? A diesel engine with fuel in it! :lol: Quote
T8H5307A Posted March 11, 2009 Report Posted March 11, 2009 How can/what makes a bus idle ? :rolleyes: Quote
cta_44499_FG Posted March 11, 2009 Report Posted March 11, 2009 Well first of all you need a bus.... Then you need to have fuel in the bus otherwise you won't be doing anything with it. Of course, the bus needs to be running...you want might want to look into that. Then you need to push the nice 'N' button to put the gear selection in neutral. Then you need to pull the parking brake, and voila....the bus is idling! If you want it to idle even louder flip the nice fast idle switch. That aught to keep you entertained. ;) Quote
tonytavell Posted March 11, 2009 Author Report Posted March 11, 2009 Well first of all you need a bus.... Then you need to have fuel in the bus otherwise you won't be doing anything with it. Of course, the bus needs to be running...you want might want to look into that. Then you need to push the nice 'N' button to put the gear selection in neutral. Then you need to pull the parking brake, and voila....the bus is idling! If you want it to idle even louder flip the nice fast idle switch. That aught to keep you entertained. the fast idle switch makes the bus sounds like the engine changed ? Quote
sw4400 Posted March 11, 2009 Report Posted March 11, 2009 How can/what makes a bus idle ? Two part question... two part answer... How can a bus idle? A device called the Idleographathingabobinexpiadadocuous controls idling in most engines in use today... in the DELF's that we have it's a Voltageidleographatingamabobinexpiadadocuouszapper. This device is unique... not only does it keep the engine idling, but it keeps the electric pods charged. What Makes a bus idle? Well, first, as cta_44499_FG says, you need fuel in the engine, the engine must be running, bus must be in "N" with parking brake on(we would'nt want that heavy bus rolling away, would we?). Fast idle makes louder idle, and if you hold the gas pedal to the floor, you make SUPER LOUD idle(although this could cause hearing damage to people near the bus, and damage the engine). Quote
mikeymc77 Posted March 11, 2009 Report Posted March 11, 2009 :P Maybe he meant IDOL. Like American Idol ???? Quote
T8H5307A Posted March 12, 2009 Report Posted March 12, 2009 Structural defects can make a whole series of bus sit idle... Quote
MVTArider Posted March 12, 2009 Report Posted March 12, 2009 Structural defects can make a whole series of bus sit idle... That one deserves a Jay Leno "HEY!" ------- Lots of passengers boarding. :P Quote
nextstopchicago Posted March 12, 2009 Report Posted March 12, 2009 What makes a blog diddle? A post on making a bus idle. Quote
Buslover88 Posted March 12, 2009 Report Posted March 12, 2009 What makes a blog diddle? A post on making a bus idle. One problem: This isn't a blog. This is a forum. Quote
cta_44499_FG Posted March 13, 2009 Report Posted March 13, 2009 One problem: This isn't a blog. This is a forum. Ditto. Quote
tonytavell Posted March 27, 2009 Author Report Posted March 27, 2009 do they also have a limit of idling ? Quote
T8H5307A Posted March 27, 2009 Report Posted March 27, 2009 do they also have a limit of idling ? This has been discussed in a previous thread Either the time limits or the bus running out of fuel will do it too! Quote
tonytavell Posted March 27, 2009 Author Report Posted March 27, 2009 Was causes them to cut off, the bus to be exact ! Quote
sw4400 Posted March 28, 2009 Report Posted March 28, 2009 Was causes them to cut off, the bus to be exact ! I believe T8H5307A already answered this... Either the time limits or the bus running out of fuel will do it too! Quote
tonytavell Posted March 30, 2009 Author Report Posted March 30, 2009 if you hit the air brakes too hard, will that cause a risk of the bus breaking down ? Quote
T8H5307A Posted March 30, 2009 Report Posted March 30, 2009 if you hit the air brakes too hard, will that cause a risk of the bus breaking down ? No but you risk throwing someone through the windshield! Quote
cta_44499_FG Posted March 30, 2009 Report Posted March 30, 2009 No but you risk throwing someone through the windshield! And spilling your coffee...never fun! Quote
Flxible 6211 Posted April 5, 2009 Report Posted April 5, 2009 When bus drivers shift their buses into drive, then put their foot on the gas, the engine sounds like its going but in reality its not, it just sits their and the engine's sound is going up. Quote
Busjack Posted April 18, 2009 Report Posted April 18, 2009 If you want to read a university study of this. Quote
