Idling Bus
tonytavell
:rolleyes:
Well first of all you need a bus.... :lol:
Then you need to have fuel in the bus otherwise you won't be doing anything with it. :P
Of course, the bus needs to be running...you want might want to look into that.
Then you need to push the nice 'N' button to put the gear selection in neutral.
Then you need to pull the parking brake, and voila....the bus is idling!
If you want it to idle even louder flip the nice fast idle switch. That aught to keep you entertained. ;)
the fast idle switch makes the bus sounds like the engine changed ?
How can/what makes a bus idle ?
Two part question... two part answer...
How can a bus idle? A device called the Idleographathingabobinexpiadadocuous controls idling in most engines in use today... in the DELF's that we have it's a Voltageidleographatingamabobinexpiadadocuouszapper. This device is unique... not only does it keep the engine idling, but it keeps the electric pods charged.
What Makes a bus idle? Well, first, as cta_44499_FG says, you need fuel in the engine, the engine must be running, bus must be in "N" with parking brake on(we would'nt want that heavy bus rolling away, would we?). Fast idle makes louder idle, and if you hold the gas pedal to the floor, you make SUPER LOUD idle(although this could cause hearing damage to people near the bus, and damage the engine).
