tonytavell Posted March 27, 2009 Report Posted March 27, 2009 Can 2 routes run the same run number at the same time ? Quote
T8H5307A Posted March 27, 2009 Report Posted March 27, 2009 Maybe our resident 4th grader "bus expert" can shed some light on this... Quote
cta_44499_FG Posted March 27, 2009 Report Posted March 27, 2009 Maybe our resident 4th grader "bus expert" can shed some light on this... So what exactly is the question because I am lost. Quote
Busjack Posted March 27, 2009 Report Posted March 27, 2009 I think he is talking about interlining, which is yes. If he is talking about two different buses with two drivers on the street simultaneously, the answer is no for CTA, since it uses the garage prefix. The answer is yes for Pace, since it doesn't use garage prefixes. The basic philosophy is that a run is one driver's piece of work for that day (or week, in case of block runs). I think he is also using two log ons, unless there are two people with the same name (which raises similar philosophical quandries). Quote
cta5300 Posted May 6, 2009 Report Posted May 6, 2009 what happenes when a bus has a woring run time like this 66 chicago 5603 and 70 division has the same run time 70 Division 5603 Quote
trainman8119 Posted May 6, 2009 Report Posted May 6, 2009 what happenes when a bus has a woring run time like this 66 chicago 5603 and 70 division has the same run time 70 Division 5603 This would imply that run 603 from Chicago ave is an interline between the two streets. Quote
cta_44499_FG Posted May 7, 2009 Report Posted May 7, 2009 This would imply that run 603 from Chicago ave is an interline between the two streets. Not necessarily, an interline would be the same bus with the same operator changing routes during the same portion of the run. It would most likely be that 5-603 is doing Division the first half of his run and Chicago the second half (or vice versa). And if my memory serves me correctly....5-603 would be a Division run... TH8 and 5555 could verify this. Quote
andrethebusman Posted May 12, 2009 Report Posted May 12, 2009 Not necessarily, an interline would be the same bus with the same operator changing routes during the same portion of the run. It would most likely be that 5-603 is doing Division the first half of his run and Chicago the second half (or vice versa). And if my memory serves me correctly....5-603 would be a Division run... TH8 and 5555 could verify this. A run can work several streets in the course of a day. so you can certainly see the same run number on different streets in the course of a day, but not at the same time on two streets. Some North Park runs show up on as many as FOUR routes. Quote
