Nabinut Posted June 16, 2011 Report Share Posted June 16, 2011 Photos taken from a recent trip to Toronto: 1982 GM Fishbowl #2251 awaiting passengers at Lawrence Station: GM #2246 hangs a left out of Lawrence West Station on its way eastbound: Both first and second generation Orion Hybrids are seen here as #1020 passes a disabled #1636: Novabus RTS-06 WFD #7219 is boarding passengers along Wilson on its way to York Mills Subway Station: Former CNG Orion V now Diesel #9401 arrives on the upper deck of Wilson Station on Route 29: Hybrid #1732 sits in the fog, awaiting passengers at Scarborough Centre RT Station: Another GM, #2444 on its way to pulling in for the evening on Route 52: The rest of my photos are here: http://s166.photobucket.com/albums/u91/nabinut/Toronto%20Transit%20Commission/ Videos: GM Fishbowl #2340: Detroit Diesel 6v71/Allison V730 Novabus RTS #7202: DD50/Allison B400R Orion V #9401: Cummins M11/Allison B400R Orion V #7007: DD50/Allison B400R Orion VII First Generation Hybrid #1125: Cummins ISB/BAE Systems Orion VII Diesel #7783: DD50/Allison B400R Toronto Transit Commission Bus Video: 2 Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 16, 2011 Report Share Posted June 16, 2011 Even though some of the Toronto enthusiast's sites indicate that the fishbowls were rebuilt several times, I'm surprised that they are still around. I also see that Toronto is adhering to 2 x 1 bus seating,* which they had going back to the late 70s, and I suppose was the "inspiration" for when that was used in Chicago. _______ *Apparently, though, that picture was of the RTS interior. Quote Link to comment Share on other sites More sharing options...
geneking7320 Posted June 17, 2011 Report Share Posted June 17, 2011 I'll check out your TTC pics soon but until then a question: Did all the TTC buses have double rear doors? [like the fishbowls for example]. Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 17, 2011 Report Share Posted June 17, 2011 I'll check out your TTC pics soon but until then a question: Did all the TTC buses have double rear doors? [like the fishbowls for example]. The pictures indicate that the new ones don't. The fishbowls generally did. IIRC from when I visited Toronto in the late 70s or early 80s, the rear door were floor treadle operated, as opposed to those on the CTA propanes, which you had to push open. One of the Toronto sites has a picture of the outside of one. That site also has pictures of buses acquired from Montreal, one in which the bus had an accordion type rear door. Quote Link to comment Share on other sites More sharing options...
qwantae Posted June 17, 2011 Report Share Posted June 17, 2011 I'll check out your TTC pics soon but until then a question: Did all the TTC buses have double rear doors? [like the fishbowls for example]. TTC's 1998 Nova RTSes were the first buses that were ordered with regular rear doors, plus the only difference between both (TTC's RTS and CTA's RTS) TTC's w/c lift is at rear door which is pretty rare on an RTS WFD. 1996 Orion 5 were the last buses ordered by TTC with double rear doors. Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 17, 2011 Report Share Posted June 17, 2011 ...the only difference between both (TTC's RTS and CTA's RTS) TTC's w/c lift is at rear door which is pretty rare on an RTS WFD. ... In fact, of those RTSs with lifts, going back to the 1980s in NYC, the lift at the back door was usual. The RTS08 was developed based on CTA's demand, upheld by the FTA, that the lift had to be in the front. Of course, after Nova took over the RTS, its models might have differed in that regard. Thanks for clarifying that the Orion Vs were the last with the double doors. Quote Link to comment Share on other sites More sharing options...
qwantae Posted June 26, 2011 Report Share Posted June 26, 2011 In fact, of those RTSs with lifts, going back to the 1980s in NYC, the lift at the back door was usual. The RTS08 was developed based on CTA's demand, upheld by the FTA, that the lift had to be in the front. Of course, after Nova took over the RTS, its models might have differed in that regard. Thanks for clarifying that the Orion Vs were the last with the double doors. That explained why CTA never bother to order normal RTS like an 06s or even GMC RTS like NYC/ L.A. because CTA policy was to only have W/C lift in front. Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 26, 2011 Report Share Posted June 26, 2011 That explained why CTA never bother to order normal RTS like an 06s or even GMC RTS like NYC/ L.A. because CTA policy was to only have W/C lift in front. That, in itself, probably wouldn't, because while NYC had lifts from the late 70s, CTA fought it until litigation, and finally the ADA mandated it. Besides that, CTA was trying to steer its business to MAN. It was only after the FTA ruled that CTA couldn't have a spec that discriminated in favor of one source that TMC and Flxible got the business, but the FTA said that CTA's requirement that the lift be in front was acceptable, so TMC had to develop the 08. Quote Link to comment Share on other sites More sharing options...
Wolfman Posted June 26, 2011 Report Share Posted June 26, 2011 "...the rear door were floor treadle operated, as opposed to those on the CTA propanes, which you had to push open." The 5000 series (and prior) Twin Coaches had treadle operated rear doors. The treadle operation (then) was a poor and primitave design. Many times, the treadle did not work. This was a major concern especailly after the PCC stretcar wreck at State & 63rd. New city ordinances mandated that future bus orders have the 'push door' option as well as 'cherries' at each door and an optional emergency exit. Quote Link to comment Share on other sites More sharing options...
Wolfman Posted June 26, 2011 Report Share Posted June 26, 2011 I also see that Toronto is adhering to 2 x 1 bus seating,* which they had going back to the late 70s, and I suppose was the "inspiration" for when that was used in Chicago. Yup. Toronto (and many other Canadian cities) opted for 2/1 seating. Been putting in specs for buses that way for a long, long time. I think even the Flyer E 700s had 2/1 seats. It made sense. It makes for a wider aisle, and the buses accomodate more riders when they cary crush loads. Some orders had half "bowling alley" seats (logitudinal). Same reason. CTA experiemented with 2/1 seating on one of the 9000s. 9537 in fact. It ran out of Forest Glen and Limits perpetually to great success. The seating plan was used with the last 25 Flyer D-901s (1600-1624). You would have thought the next bus order (M.A.N. 4000s) would have a similar seating arrangement. Not to be. When it was mandated that all following orders be ADA compliant (lifts), CTA had to swallow it and do 2/1 seats for the "Timmies" (4400s). Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 26, 2011 Report Share Posted June 26, 2011 .....When it was mandated that all following orders be ADA compliant (lifts), CTA had to swallow it and do 2/1 seats for the "Timmies" (4400s). I'm not so sure about swallow, because the 6000s were 2 x 2 and, of course, most of the low floors, while having few seats were mostly 2x2 until the most recent ones. Quote Link to comment Share on other sites More sharing options...
Orion VIII Posted June 29, 2011 Report Share Posted June 29, 2011 Just an update to the thread...approximately 30 of the fishbowls remain active in the fleet and 8 at a time are being cycled out of service over the summer. Whether all of them will return to service remains to be seen, because this practice has occurred in years past and we've emerged from the summer with fewer GMs, so we'll wait and see what happens come September. Quote Link to comment Share on other sites More sharing options...
Busjack Posted March 8, 2023 Report Share Posted March 8, 2023 If you want something to cure insomnia, this video is it: Surprisingly, bicyclists ride between the streetcar and closed sections of the curb lane. You can imagine how the activists would howl about that in Chicago. Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 18, 2023 Report Share Posted June 18, 2023 TTC is apparently going all in on electric buses, with reports of 186 firm from NF and 124 firm from Nova Bus. Montreal, and the rest of Quebec, have a firm order for 339 LFSe+. Of course, they have hydroelectric power. Quote Link to comment Share on other sites More sharing options...
strictures Posted June 19, 2023 Report Share Posted June 19, 2023 On 3/7/2023 at 7:39 PM, Busjack said: If you want something to cure insomnia, this video is it: Surprisingly, bicyclists ride between the streetcar and closed sections of the curb lane. You can imagine how the activists would howl about that in Chicago. That brought me back to my childhood riding the 22 Clark car. The ride was smooth, unlike a bus & very quiet. But to me, nothing will ever top the look of the classic 1937 design of the PCC streetcar. But one question: Why do some of them use the pantograph & some use the single juice jack at the rear end? The cars are equipped with both. And Toronto has far better designed shelters than the godawful garbage we have in Chicago, what with all the openings for wind & snow to blow through! And their automated announcements are far more pleasant than Lee Crooks. 1 Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 19, 2023 Report Share Posted June 19, 2023 4 hours ago, strictures said: But one question: Why do some of them use the pantograph & some use the single juice jack at the rear end? The cars are equipped with both. Something said some wires can't take the pantograph. Update: An engineering report is here. Quote Link to comment Share on other sites More sharing options...
Glennwood Road Ent. Posted March 23 Report Share Posted March 23 (edited) Dusting this thread off from the dumpster bin, During my first trip in Toronto, Canada on my 4-day Vacation from 13th-16th September 2024, I spotted one of TTC's oldest 2006-07 Orion VII HEV buses in service along with the newest NFI XDE40s, XDE60s and NovaBus LFS HEVs with chrome rims, some Orions NG Diesels and HEVs, EPA10 diesels, NovaBus LFS Diesel and HEVs with red rims and LFS Artics. At the time of this writing as of March 2025, majority of the units are in the process of being retired along with NG HEVs and they are in the process of being replaced with newer hybrid buses in chrome rims. Here's the two videos: VID_20240913_190314.mp4 VID_20240915_155723.mp4 Edited March 28 by Glennwood Road Ent. September 2024 in Canada Quote Link to comment Share on other sites More sharing options...
MetroShadow Posted March 25 Report Share Posted March 25 On 3/22/2025 at 6:21 PM, Glennwood Road Ent. said: Dusting this thread off, During my first trip in Toronto, Canada on my 4-day Vacation from 13th-16th September 2024, I spotted one of TTC's oldest 2006-07 Orion VII HEV buses in service along with the newest NFI XDE40s, XDE60s and NovaBus LFS HEVs with chrome rims, some Orions NG Diesels and HEVs, EPA10 diesels, NovaBus LFS Diesel and HEVs with red rims and LFS Artics. At the time of this writing as of March 2025, majority of the units are in the process of being retired along with NG HEVs and they are in the process of being replaced with newer hybrid buses in chrome rims. Here's the two videos: VID_20240913_190314.mp4 VID_20240915_155723.mp4 Thanks for sharing - when I get to Toronto next week, hoping I can catch one more (Orion 7). 1 Quote Link to comment Share on other sites More sharing options...
Glennwood Road Ent. Posted March 28 Report Share Posted March 28 On 3/24/2025 at 9:18 PM, MetroShadow said: Thanks for sharing - when I get to Toronto next week, hoping I can catch one more (Orion 7). Your welcome. BTW, Use Wikipedia for TTC fleet rosters and do not use CPTDB Wiki; that site is an unreliable source of fleet information. Quote Link to comment Share on other sites More sharing options...
Glennwood Road Ent. Posted June 26 Report Share Posted June 26 (edited) Sorry for the late post, via CBC Toronto News earlier this month, TTC has new CEO The Toronto Transit Commission (TTC) has appointed Mandeep Lali as its new CEO, effective July 7, 2025. He previously held the position of Executive Vice President and Chief Operating Officer of Subways at New York City Transit. Lali replaces interim CEO Greg Percy, who took over after Rick Leary's resignation. https://www.ttc.ca/news/2025/June/Official-Statement Edited June 26 by Glennwood Road Ent. Ttc has New CEO Quote Link to comment Share on other sites More sharing options...
Busjack Posted June 26 Report Share Posted June 26 15 hours ago, Glennwood Road Ent. said: earlier this month, TTC has new CEO T Does anybody care? It's not like they hired Forrest Claypool or Rev. Acree. 1 1 1 Quote Link to comment Share on other sites More sharing options...
strictures Posted June 26 Report Share Posted June 26 5 hours ago, Busjack said: Does anybody care? It's not like they hired Forrest Claypool or Rev. Acree. LOL! 2 Quote Link to comment Share on other sites More sharing options...
Glennwood Road Ent. Posted Sunday at 11:31 PM Report Share Posted Sunday at 11:31 PM Everyone, please shut up with the insane political crap talk on this topic here and let's get back to peaceful class and talk about this topic here based on TTC's fleet roster on Wikipedia. Here's the updates of ongoing retirements as of this month: 1000-1149-2006-07 Orion VII HEV: 12 units remaining (TTC's Oldest Fleet) 1200-1423-2007-08 Orion VII NG HEV: 132 units remaining 1500-1689-2008 Orion VII NG HEV: 40 units remaining 8100-8219-2009-10 Orion VII NG Diesel: 56 units left 8300-8396-2011-12 Orion VII EPA10 Diesel: 93 units left And here's the updates of ongoing deliveries of 2024-25 EV buses as of this month: 6000-6203-2024-25 NFI XE40 NG CHARGE: 100/204 in service 6600-6735-2024-25 Nova Bus LFSe+: 1/136 in service Quote Link to comment Share on other sites More sharing options...
Busjack Posted Monday at 05:02 PM Report Share Posted Monday at 05:02 PM 22 hours ago, Glennwood Road Ent. said: Everyone, please shut up with the insane political crap talk on this topic here I'm not sure to what you are referring, but this is a Chicago Transit Forum, and all comments were asking was "what does this have toi do with Chicago?" Nobody here cares who is the CEO of TTC, unless he is the second coming of Alf Savage and is being recruited by Brandon Johnson for a 6-month job running the CTA. Chicagoans know who the named persons were, including that Savage was in charge of TTC and NFTA before CTA. (According to legacy.com, he's not coming back, so so much for that thought.) BTW, speaking of political bull, who by the name of Glennwood posted this? I'm sure that the view of some commonwealth legislator from Erie Pa. is of importance in the Bahamas. Not. 1 Quote Link to comment Share on other sites More sharing options...
MetroShadow Posted Thursday at 03:28 AM Report Share Posted Thursday at 03:28 AM On 6/26/2025 at 10:16 AM, Busjack said: Does anybody care? It's not like they hired Forrest Claypool or Rev. Acree. On 8/11/2025 at 10:02 AM, Busjack said: I'm not sure to what you are referring, but this is a Chicago Transit Forum, and all comments were asking was "what does this have toi do with Chicago?" Nobody here cares who is the CEO of TTC, unless he is the second coming of Alf Savage and is being recruited by Brandon Johnson for a 6-month job running the CTA. Chicagoans know who the named persons were, including that Savage was in charge of TTC and NFTA before CTA. (According to legacy.com, he's not coming back, so so much for that thought.) BTW, speaking of political bull, who by the name of Glennwood posted this? I'm sure that the view of some commonwealth legislator from Erie Pa. is of importance in the Bahamas. Not. To be fair, this is the General Transit Discussion, so items like these are allowed. Folks can and should exercise the need to respond (or not). 1 Quote Link to comment Share on other sites More sharing options...
