sw4400 Posted October 16, 2012 Report Share Posted October 16, 2012 Just thought I'd post the current bus fleet with Engine/Transmission information(courtesy of Wikipedia)2000-2002 NOVA LFS(6400-6883):Engine: Cummins ISCTransmission: ZF 5HP552C2006-2007 Optima Opus(500-544):Engine: Cummins ISBTransmission: ZF 5HP502C2006-2009 New Flyer D40LF(1000-2029):Engine(1000-1629): Cummins ISMTransmission(1000-1429): ZF 6HP592CEngine(1630-2029): Cummins ISLTransmission(1430-1929) ZF 6HP594CTransmission(1930-2029) Allison B4002006-2007 New Flyer DE40LF(800-809, 900-909)Engine(800-809): Cummins ISLTransmission(800-809): Allison EP-40 Hybridrive SystemEngine(900-909): Cummins ISBTransmission(900-909): ISE Thundervolt Hybridrive System2008-2009 New Flyer DE60LF(4000-4207)Engine: Cummins ISLTransmission: Allison EP-50 Hybridrive System2012 New Flyer DE60LFR(Numbers TBD)Engine: Cummins ISL9Transmission: Allison EP-50 Hybridrive System2012 New Flyer D60LFR(Numbers TBD)Engine: Cummins ISL9Transmission: Allison WB-500R2013 New Flyer XE40Engine: TBDTransmission: TBD Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 16, 2012 Report Share Posted October 16, 2012 ... 2013 New Flyer XE40 Engine: TBD Transmissio: TBD If this refers to the 2 Electric buses, the answer to both is None. They will have some sort of electrical traction motor(s). Quote Link to comment Share on other sites More sharing options...
See Tea Eh Posted October 16, 2012 Report Share Posted October 16, 2012 Assuming the XE40 are the two all-electric buses that are being built, they will have neither engines nor transmissions. Quote Link to comment Share on other sites More sharing options...
sw4400 Posted October 16, 2012 Author Report Share Posted October 16, 2012 If this refers to the 2 Electric buses, the answer to both is None. They will have some sort of electrical traction motor(s). Well, it still counts as a "Engine" to some extent, since it is a electric bus with no overhead wires. It has to have something to power it(Engine, so to speak) and propel it(Transmission, so to speak) Quote Link to comment Share on other sites More sharing options...
sw4400 Posted October 16, 2012 Author Report Share Posted October 16, 2012 Assuming the XE40 are the two all-electric buses that are being built, they will have neither engines nor transmissions. Those are the two Electric buses, but they have to have some "Engine" to power them and a "Transmission" to propel them. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 16, 2012 Report Share Posted October 16, 2012 Well, it still counts as a "Engine" to some extent, since it is a electric bus with no overhead wires. It has to have something to power it(Engine, so to speak) and propel it(Transmission, so to speak) Batteries and an electrical cord plugged into the charging station. Read the first Press Release (preceding the one on the CTA order), which says: The bus is equipped with an electric drive and is modified to carry advanced lithium ion batteries from MHI that are charged from the city's electrical grid instead of by a conventional diesel engine. This ain't no hybrid. More like a Nissan Leaf than a Fisker Karma/Chevy Volt. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 16, 2012 Report Share Posted October 16, 2012 Maybe related to this topic, is that while CTA's 3 fuel cell buses still sit there, New Flyer and Ballard have reintroduced the fuel cell bus as the H40LFR. No engine in those, either. While the 900s have an engine, technically they don't have a transmission. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 16, 2012 Report Share Posted October 16, 2012 As far as "unknown," the NF Press Release on the CTA order says: CTA's battery-electric bus will feature the latest in electric traction drives and components supplied by Siemens, including a high efficiency permanent magnet traction motor, inverters, voltage protection modules, junction boxes and the application software. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 19, 2012 Report Share Posted October 19, 2012 BTW, whoever posted it on Wikipedia may have gotten it from page 81 of the latest addendum to the 600 bus order. That was included there on the basis of a question "if we are evaluated based on compatibility, what do you have?" However, my impression from the stories about rebuilding the 1000 series buses is that all are supposed to get the same engines, instead of up to 1629 having ISM and the rest ISL. Anyway, the addendum indicates that the last 400 have Allison B400 transmissions. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 19, 2012 Report Share Posted October 19, 2012 Also interesting from the addendum is that 1000-1429 have American Seating 6488. 1430-2029 and 4000-4149 American Seating Insight, and 4150-4207 4One Aries. However, I don't think that is correct, in that the earlier buses were retrofitted, and I recently rode on a 1300 that had the Insight. Also later that day, I rode on a 1630+ (both Route 60) that seemed to have a different type of seat (instead of the scooped back, it had a flatter one with a pebbled metal sheet insert). Thus, does anyone have any more current info? Quote Link to comment Share on other sites More sharing options...
Diesel S560 Posted October 29, 2012 Report Share Posted October 29, 2012 Batteries and an electrical cord plugged into the charging station. Read the first Press Release (preceding the one on the CTA order), which says: This ain't no hybrid. More like a Nissan Leaf than a Fisker Karma/Chevy Volt. The Fisker Karma and Chevy Volt are not hybrids either. The only difference between the Leaf and the Fisker Karma and Chevy Volt is that the ladder two vehicles have an ICE range extender that is linked to an electric generator. The ICE does not directly propel the wheels unlike more traditional hybrids. All 3 cars are considered EV's and all can run on electricity alone for an extended period of time until their respective batteries are depleted. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 29, 2012 Report Share Posted October 29, 2012 The Fisker Karma and Chevy Volt are not hybrids either. The only difference between the Leaf and the Fisker Karma and Chevy Volt is that the ladder two vehicles have an ICE range extender for their electric generator. The ICE does not directly propel the wheels unlike a traditional hybrid. All 3 cars are considered EV's and all can run on electricity alone for an extended period of time until their respective batteries are depleted. Probably OT. However, by that definition, the bus series hybrids (BAE and apparently formerly ISE) wouldn't be hybrids either. However, in this case, propulsion or range isn't going to be aided by a combustion engine, although the Press Release indicates that there will be a diesel heater. Like the Leaf, once the battery is dead, so are these two buses. Quote Link to comment Share on other sites More sharing options...
Diesel S560 Posted October 29, 2012 Report Share Posted October 29, 2012 Probably OT. However, by that definition, the bus series hybrids (BAE and apparently formerly ISE) wouldn't be hybrids either. However, in this case, propulsion or range isn't going to be aided by a combustion engine, although the Press Release indicates that there will be a diesel heater. Like the Leaf, once the battery is dead, so are these two buses. Technically the BAE series hybrid powered buses would still be considered hybrids unless they have an "electric only" mode that would propel the wheels. This is what separates the Volt and Karma from other traditional hybrids like the Ford Fusion, Honda Civic, and the ubiqutous Toyota Prius. In theory, the Karma and Volt have a set-up similar to that of a series hybridrive system. However both vehicles can run independent of their range extending generators on pure electricity alone making them electric vehicles first and foremost. As the technology improves so will the electric range making the range extender potentially a thing of the past. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 29, 2012 Report Share Posted October 29, 2012 Technically the BAE series hybrid powered buses would still be considered hybrids unless they have an "electric only" mode, this is what separates the Volt and Karma from other traditional hybrids like the Ford Fusion, Honda Civic, and the ubiqutous Toyota Prius. In theory, the Karma and Volt have a set-up similar to that of a series hybridrive system. However both vehicles can run independent of their range extending generators on pure electricity alone making them electric vehicles first and foremost. As the technology improves so will the electric range making the range extender potentially a thing of the past. Various transit authorities run their hybrids in "electric only" mode for short distances. For instance, apparently Seattle does through tunnels, although they are parallel hybrids. I suppose that someone from Seattle could elaborate. Quote Link to comment Share on other sites More sharing options...
Diesel S560 Posted October 29, 2012 Report Share Posted October 29, 2012 Various transit authorities run their hybrids in "electric only" mode for short distances. For instance, apparently Seattle does through tunnels, although they are parallel hybrids. I suppose that someone from Seattle could elaborate. Yes there maybe several TA's that run hybrid buses in electric only mode in certain instances. However the notion of considering a hybrid bus an EV is negligible when factoring in the very short distance that said hybrid can travel in electric only mode. The parallel hybrid propulsion system is a totally different subject that is out of the realm of my previous posts. The point I was trying to make is that in order for a vehicle to be considered an EV it must be able to travel for an extended period of time in electric only mode. The Fisker Karma and Chevy Volt both have the resources to travel for an extended range of time in electric only mode----unfortunately a hybrid powered bus is not withstanding. Quote Link to comment Share on other sites More sharing options...
sw4400 Posted October 30, 2012 Author Report Share Posted October 30, 2012 Also interesting from the addendum is that 1000-1429 have American Seating 6488. 1430-2029 and 4000-4149 American Seating Insight, and 4150-4207 4One Aries. However, I don't think that is correct, in that the earlier buses were retrofitted, and I recently rode on a 1300 that had the Insight. Also later that day, I rode on a 1630+ (both Route 60) that seemed to have a different type of seat (instead of the scooped back, it had a flatter one with a pebbled metal sheet insert). Thus, does anyone have any more current info? Recheck those numbers, Busjack. The New Flyers started changing somewhere in the early 1300's from American Seating Insight, not 6488. I know 1302 has American seating 6488, where 1375 has American seating Insight. I think the retrofit occured somwhere in the 1330's. I'm surprised the CTA didn't finish the retrofit they claimed they were going to do later on. If they did, then 1000-13XX would have the American Seating Insight. Quote Link to comment Share on other sites More sharing options...
Busjack Posted October 30, 2012 Report Share Posted October 30, 2012 Recheck those numbers, Busjack. The New Flyers started changing somewhere in the early 1300's from American Seating Insight, not 6488. I know 1302 has American seating 6488, where 1375 has American seating Insight. I think the retrofit occured somwhere in the 1330's. I'm surprised the CTA didn't finish the retrofit they claimed they were going to do later on. If they did, then 1000-13XX would have the American Seating Insight. All I know is what I rode. Being under the stress of going to and from jury duty, you won't get more definite numbers from me on the two buses I rode. And if you read my post more closely, you will see that I was questioning the models that CTA gave in its addendum. Update: Image of the chart in the addendum: Quote Link to comment Share on other sites More sharing options...
sw4400 Posted October 30, 2012 Author Report Share Posted October 30, 2012 Ok, I was slightly wrong about what buses started using the Insight seating. I am currently on bus#1322, and it has the insight seats. So the first bus to have the insight seats is between #1303 and #1321. Quote Link to comment Share on other sites More sharing options...
andrethebusman Posted October 31, 2012 Report Share Posted October 31, 2012 Seating as follows: 1000 Insight (remember, this is 1000 2nd. 1000 1st has 6488's, but is a maintenance training bus - apparently numbered 5321000) 1001-1303 6488 1304-1929 Insight (also 800-809, 900-909) 1930-2029 I guess Insight?, but both wheelchair positions on curb side instead on one on each 4000-4149 Insight 4150-4207 Completely different, stainless frame with gray padding Recheck those numbers, Busjack. The New Flyers started changing somewhere in the early 1300's from American Seating Insight, not 6488. I know 1302 has American seating 6488, where 1375 has American seating Insight. I think the retrofit occured somwhere in the 1330's. I'm surprised the CTA didn't finish the retrofit they claimed they were going to do later on. If they did, then 1000-13XX would have the American Seating Insight. Quote Link to comment Share on other sites More sharing options...
See Tea Eh Posted October 31, 2012 Report Share Posted October 31, 2012 And last time I saw it, 4155 had a completely different type of seats from any other bus in the CTA fleet. Don't know what the model type is. Quote Link to comment Share on other sites More sharing options...
sw4400 Posted February 26, 2014 Author Report Share Posted February 26, 2014 Here's a more updated powertrain roster of the CTA Fleet from the TMC's to present. I didn't include the used buses from PACE or Seattle Metro in the lists during the time frame... 4400 & 4900-Series TMC RTS(1989-1990) Detroit Diesel 6V92 5300-Series Flxible Metro(1990-1991) 5300-5740: Detroit Diesel 6V92TA 5741-5744: Detroit Diesel 6L71TA 5745-5765: Cummins L-10 5766-5769: Detroit Diesel 6V92TA 6000-Series Flxible Metro(1994-1995) 6000-6304: Detroit Series-50 6305-6329: Cummins C8.3 5800-Series New Flyer(1995) 5800-5861: Detroit Series-50 5862-5864: Cummins C8.3(these engines were replaced with Detroit Series-50 during rehabs) 6400-Series Nova LFS(2000-2002) Cummins ISC 7500-Series NABI 60-LFW(2003-2004) Detroit Series-50 7800-Series NABI 45C-LFW(2005) Detroit Series-50 1000-Series New Flyer D40LF(2006-2009) Cummins ISM6(1000-1429) Cummins ISM7(1430-1629) Cummins ISL7(1630-1929) Cummins ISL8(1930-2029) 500-Series Optima Opus(2006) Cummins ISB02 800-Series New Flyer DE40LF(2006) Cummins ISL8.9L 900-Series New Flyer(2007) Cummins ISB6.7L 4000-Series New Flyer DE60LF(2008-2009) Cummins ISL8.9L 4300-Series New Flyer DE60LFR(2012) Cummins ISL9 4333-Series New Flyer D60LFR(2013) Cummins ISL9 7900-Series Nova LFS Smart Bus(2014) Cummins ISL9 Quote Link to comment Share on other sites More sharing options...
jajuan Posted February 26, 2014 Report Share Posted February 26, 2014 You might want to make a correction to the transmissions in the NF 1000s list. You have 1000-1629 as having ZF 6HP592C transmissions and 1630-1929 having ZF 6HP594C transmissions. However, per the info Kevin posted in the Buses section of the site, the cutoff is actually 1000-1429 having the ZF 6HP592C and 1430-1929 being equipped with the ZF 6HP594C. Quote Link to comment Share on other sites More sharing options...
