I know that scheduling information for service changes ain’t out yet, but I figured I get this up now.
What is currently known from earlier this year from the old RTA service report from the summer (if that’s still relevant now) is routes that were planned to get changes to their span of service. So far what’s left on that list to be implemented before year’s end is changes to 37, 50, 156, and 201. 8 is/was scheduled to join the Frequent Network in Winter
Additionally, there’s the 57’s extension to Jefferson Park Blue Line/Metra Station. Now confirmed by the NITA 2027 Regional Budget report, the route will be extended southbound to end at Morton College on Central/38th Street. I assume both extensions will occur together in the Winter Pick, unless it’s be extended to Jefferson Park first in the Winter and extend to Morton College later next year.
37 and 156 likely get weekend service
50 is stop consolidation (check the CTA website) and 201 is supposedly an extension down ridge to bryn mawr.
You sure 37 and 156 are getting weekend service and not just later weekday? Those are too close to the Brown Line and Clark to really be needed.
Yeah, that seems kind of odd. I could see 157 getting weekend service before either 37 or 156.
It is starting to be believed that the L is not a substitute for the bus (despite the demise of 11 south of Brown Line).
However, while 156 generally serves Lincoln Park itself, so does 151, and my question would be is whether the conversion of LaSalle St. offices to residential has sufficiently progressed to justify it.
Throwing Old Town into the mix and the wider gap in Brown Line stops then ok 37 gets a pass.
156 I'm still iffy about since it's parallel to both 22 and 151 however one thing it does that 22 doesn't is go to the west loop and Union Station so from a coverage/transfer availability standpoint might be justified.
I'm kinda surprised 62 has been left out. It parallels the Orange Line in some spots but between 35th/Archer and Pulaski is pretty much on its own (and again after Midway) and stays pretty busy in those areas. Same reason 60 deserves the enhancements it's gotten. Parallels the Pink Line but yet also hits areas that the Pink Line doesn't and somewhat retains service along UIC/Harrison/Union Sta that separating the Blue Line from Douglas left behind
156 I'm still iffy about since it's parallel to both 22 and 151 however one thing it does that those don't is go to the west loop and Union Station so from a coverage/transfer availability standpoint might be justified.
I agree that 62 deserves more consideration, especially given how much of its route operates independently of the Orange Line and how useful it is for the areas around 35th/Archer and Pulaski. I also think 156 has a reasonable argument because of its connection to Union Station and the West Loop, even with the overlap with 22 and 151. Ultimately, I think the biggest factor should be whether these routes provide coverage and connections that rail alone cannot adequately replace.
Personally I understand 35th needed a frequency boost BUT I would have split resources among both 35 and 62 in their off peak hours. I would have started with a few buses to bring all of 35th's former 20 min headways to 12-15 min. And a few buses to bring 62's widest headways (15-17 min) to around 10-12 min but still give 35 Owl service.
I think that’s a fair approach. The 35 definitely needed the frequency boost, but I don’t think that should come at the expense of the 62, especially considering how much of its route serves areas that aren’t directly covered by the Orange Line. Splitting some of the additional resources between both routes could have been a good compromise. Keeping the 35 Owl service while improving off-peak headways on the 62 would also help maintain coverage without putting all the focus on one route.
Hmm... Maybe extending 37 to serve Union Station and terminate at Des Plaines/Harrison could make these added hours to the route more useful. You have kind of a direct connection to Ogilvie and roughly everything between Lake to Madison along the Clinton area if you take Brown to Pink but getting to the Union Station area isn't as direct considering the Blue line drops you kinda far from Union plus a dark underpass isn't really too safe an option for transferring over there nor for the operators that layover tbh. Rerouting via Adams and Des Plains to Harrison solves those issues and as a bonus puts someone from Lincoln Park within walking distance of UIC from Des Plaines 🤔
I actually like this idea. Extending the 37 would give Lincoln Park a more direct connection to Union Station while also improving access to the West Loop and UIC. I agree that relying on the Blue Line for Union Station connections isn’t ideal, especially considering the walking distance involved. Routing via Adams and Des Plaines seems like a reasonable way to address that while making the added service more useful throughout the day. The UIC connection is an interesting bonus too.
Historically, 37 was Taylor-Sedgwick, but then they were split because of too much traffic congestion. A lot of water went over the dam since then, including Lincoln-Sedgwick losing Lincoln, Taylor being combined with Streeterville, but now really not much on Taylor, so at this point, I don't know.
That’s a good point. I wasn’t aware the original Taylor-Sedgwick route was split primarily because of traffic congestion. I do think the changes in development and travel patterns since then could justify taking another look at the idea, especially with the loss of Lincoln service and the changes around Taylor. That said, I wouldn’t want an extension to become unreliable because of the same congestion issues that led to the split in the first place. Perhaps a limited extension or a revised routing could be worth studying before committing to bringing the old route back.
@Sam92 is mostly like on the money, 37 & 156 will most likely only get a slight increase in service hours for weekdays. I don’t see 156 or 37 getting weekend service, I feel there’s probably not much demand for it when the Brown Line 151 Sheridan and 22 Clark are adjacent service options for them. The stop consolidation is something else entirely, not change in its service hours. 201 extension to Bryn Mawr ain’t happening till one of the picks next years, though I believe for the upcoming pick this winter, it will be getting Sunday/holiday service to make it a week-round route as they did with the 93.
That was one of the routes CTA was covering earlier in the spring on giving weekend service and the NITA Budget report recently released does confirm that proposals is still in the works with routes 31, 48, 85A, and 86
No idea why the 37 would get weekend service but the 156 is generally the fastest and most reliable way to get to lincoln park from downtown (high demand route!!) so it makes sense why they'd want to expand service on that route
Theoretically LaSalle would make a fantastic corridor for N-S local buses into downtown with it being a 6-lane road and all. Anyways
85A? They might as well just tack the whole caldwell-toughy-lehigh onto the 85 and I would not be at all surprised if they did just that.
Glad to see 86 getting weekend service (probably, right?), no buses between austin and harlem on the weekend really stings
Certainly no point to connecting 85A to 85, because the loads don't match. 85 is a heavy route, but 85A was so light that CTA ran Optimas on it until those were deemed not suitable for CTA service. The only real function of 85A is to get people to Touhy-Lehigh, and the proposed Pace 220 (Central-Niles Center) may take care of it.
Yeah the only reason I can see weekend service working on 37 is the wider gap in brown line stops and it's northern segment being a bit further way so I backed off of 37 based of that.
Yeah originally I wanted to say extend via Harrison to Polk and Paulina for access to the Medical district on top of the Union connection but was iffy due to 157 and 60. On the plus side it would be a one seat ride from LP to the West Loop but would enough people switch to it vs taking Blue/Brown? Maybe as a rush hour extension go to medical district but all other times terminate at Harrison and Des Plaines
Yeah originally I wanted to say extend via Harrison to Polk and Paulina for access to the Medical district on top of the Union connection but was iffy. On the plus side it would be a one seat ride from LP to the West Loop but would enough people switch to it vs taking Blue/Brown? Maybe as a rush hour extension go to medical district but all other times terminate at Harrison and Des Plaines
I actually think having the Medical District as a rush-hour extension could be a good compromise. It would provide a one-seat ride from Lincoln Park to the Medical District and give commuters another option into the West Loop without necessarily committing to the longer routing all day. I’d be interested to see whether the demand would justify extending every trip during peak hours or if a limited number of trips would be enough. Either way, I think the Union Station connection alone makes the extension worth looking into.
3 hours ago, TaylorTank1229 said:
Does anyone possibly know that when the 57 is extended, it’ll still serve the Blue Line on Cicero or just keep buses on Laramie?
I would expect the Cicero Blue Line connection to remain, especially since it provides an important transfer point for riders coming from the northern portions of Laramie. Extending the route shouldn’t necessarily mean sacrificing its existing southern terminus. Unless the proposed extension specifically calls for replacing the Cicero connection, I’d think maintaining service to both the Laramie Green Line and Cicero Blue Line would make the most sense.
IDK if it is still relevant, but the X28 originally went to IMD, but was subsequently cut back to Union Station (current 28 downtown trips), and there was the 127 Circulator, which failed for several reasons. Maybe coming from the North Side is different, or maybe they are going to Northwestern Medicine and Lurie.
I personally think there should be better N-S access around the Morgan-Racine area, but we've discussed that before.
That’s a fair point. I think the North Side could have a somewhat different demand pattern, especially with Northwestern Memorial and Lurie Children’s being major destinations. Coming from Lincoln Park, a direct connection could be useful for both commuters and people traveling to medical appointments. I agree that the X28 and 127 are worth considering when evaluating whether the extension would be successful, though. I’d still be interested in seeing some peak-hour trips tested before ruling the idea out entirely. I also agree that better north-south access around Morgan and Racine would help address some of the connectivity issues in that area.
49 minutes ago, TaylorTank1229 said:
Any word on when the winter pick will be implemented? I predict either Sunday, December 13th or the Sunday of Christmas week, December 20th.
Probably the 20th? It's usually around then iirc
