Nabinut Posted September 11, 2009 Report Posted September 11, 2009 I'm visiting in two weeks and i'm wondering, what are the chances of seeing a Flxible particularly on a Saturday? And if they do run, what lines would I have the best luck on? Quote
Busjack Posted September 11, 2009 Report Posted September 11, 2009 Odds are down on the weekend, especially since it appears that FG keeps a lot of them in the yard. Also, you are talking about 290 of about 2100, and the 290 least likely to be on the street when maybe only 900 are required to maintain service citywide. I suggest that this Saturday, you go to BusTracker, and then plug in the routes from the following garages (basically in that order): 74 FG C K Of course, look for buses in the 6000-6329 range. Also, I suggest that you know you neighborhoods, as many buses go crosstown, and traverse those of diverse socio-economic conditions (to put it politically correctly). 1 Quote
cta 5555 Posted September 11, 2009 Report Posted September 11, 2009 Your luck of seening them on Any Chicago av routes in none,Also 103rd and K doesnt run them on weekends. Quote
cta_44499_FG Posted September 11, 2009 Report Posted September 11, 2009 I'm visiting in two weeks and i'm wondering, what are the chances of seeing a Flxible particularly on a Saturday? And if they do run, what lines would I have the best luck on? Forest Glen is the best bet, as it doesn't seem to really matter there. However, with the slow replacement of Flx with NF...this may become unlikely as time progresses. The ABSOLUTE best time to see them is on Cub's game days, as they tend to use Flxibles to fill the 152 extras for the game service. Other good routes to spot a few are the 77, 86 and 91. For some reason it's always been that way. Of course as Busjack stated....watch where you go if you don't know the area. With that said, here are the routes to watch: (Note: 'Wk' notes routes that run M-F only) --------------------------------------------- 54A North Cicero/Skokie Blvd (WK) 56 Milwaukee 56A North Milwaukee (Wk) 64 Foster/Canfield (Wk) 68 Northwest Highway 69 Cumberland/East River (Wk) 77 Belmont 78 Montrose 80 Irving Park X80 Irving Park Express 81 Lawrence 81W West Lawrence 84 Peterson 85 Central 85A North Central (Monday thru Saturday only) 86 Narragansett/Ridgeland (Wk) 88 Higgins 90 Harlem 90N North Harlem (Monday thru Saturday only) 91 Austin 92 Foster 152 Addison Quote
pudgym29 Posted September 11, 2009 Report Posted September 11, 2009 Forest Glen garage routes are your best shot. Others are telling you to be cautious where you try to view | photograph them. You'll be fine if you stick to its east-west routes. Route #77 Belmont, #80 & #X80 Irving Park, and #81 Lawrence are likely to have a Flxible on them at some time of day. I think some more senior operators are opting to pull out a Flxible rather than anything else in the garage. Some routes will have service by the 35-foot Opus Optimas on weekends. If you go to the Jefferson Park terminal, you should see a handful of them on routes #81W, #85A, #56A, and perhaps even #68, and #88. I should mention somewhere that I saw bus #1219 used as an "Instruction Bus" on Thursday afternoon {Sorry - no camera then.}. It was turning left (north) onto Central from Montrose. Quote
jajuan Posted September 12, 2009 Report Posted September 12, 2009 Like others have said, Forest Glen is currently your best shot of finding Flxible 6000s in service on the weekend because it is the garage that now has the most assigned in service. The other garges that have them in service now have them in small enough numbers that they all get parked on the weekends. Quote
cta5658 Posted September 12, 2009 Report Posted September 12, 2009 Odds are down on the weekend, especially since it appears that FG keeps a lot of them in the yard. Also, you are talking about 290 of about 2100, and the 290 least likely to be on the street when maybe only 900 are required to maintain service citywide. I suggest that this Saturday, you go to BusTracker, and then plug in the routes from the following garages (basically in that order): 74 FG C K Of course, look for buses in the 6000-6329 range. Also, I suggest that you know you neighborhoods, as many buses go crosstown, and traverse those of diverse socio-economic conditions (to put it politically correctly). Don't Forget the 103 1 Quote
Busjack Posted September 12, 2009 Report Posted September 12, 2009 Don't Forget the 103 1 Except that cta 5555 said to forget 1, C, and K. Also, scoping BusTracker, jajuan is correct about 74, at least with regard to its major routes (9, 47, 55, 63). However, my suggestion seems to have laid an egg. FG buses are generally not showing up on the system. 3 77s, 1 or 2 80s, and no 56s, 78s or 81s. You know the latter is wrong. Also, even on the south side, there were so few buses that arrival times were not available at the stops. As Pace used to say, try again later. Quote
BusExpert32 Posted September 12, 2009 Report Posted September 12, 2009 Except that cta 5555 said to forget 1, C, and K. Also, scoping BusTracker, jajuan is correct about 74, at least with regard to its major routes (9, 47, 55, 63). However, my suggestion seems to have laid an egg. FG buses are generally not showing up on the system. 3 77s, 1 or 2 80s, and no 56s, 78s or 81s. You know the latter is wrong. Also, even on the south side, there were so few buses that arrival times were not available at the stops. As Pace used to say, try again later. Yes, Bustracker is still messed up now. There's only a few buses out there and no arrival times. Quote
Busjack Posted September 14, 2009 Report Posted September 14, 2009 Sunday, it appears that BusTracker is working better. However. on FG routes, while mostly Novas, it seems like they would rather send out a 1200 than a 6000. Quote
daerah Posted September 15, 2009 Report Posted September 15, 2009 Hmm..I particularly like to pull out odd buses on odd lines (buses you wouldnt normally see on the route) For example. I've taken a 4000 on the (82 Kimball-Homan) on the Weekend lol...talk about "turning heads" even the passengers were in Aww. lol On week days, you're more than likely to see anything out there...Ive had a 6000, 800 and 900 as well. I've also taken a 7500 NABI on the (8 Halsted) as well as a 800 and 900 series too. Never a 6000...but I have seen a couple 6000s out there...but its a RARE thing. Good luck Quote
BusHunter Posted September 15, 2009 Report Posted September 15, 2009 Hmm..I particularly like to pull out odd buses on odd lines (buses you wouldnt normally see on the route) For example. I've taken a 4000 on the (82 Kimball-Homan) on the Weekend lol...talk about "turning heads" even the passengers were in Aww. lol On week days, you're more than likely to see anything out there...Ive had a 6000, 800 and 900 as well. I've also taken a 7500 NABI on the (8 Halsted) as well as a 800 and 900 series too. Never a 6000...but I have seen a couple 6000s out there...but its a RARE thing. Good luck You must have had a blast when driving your #4000 through Lincolnwood Town Center. It looks challenging for a 60 footer, then with the saturday traffic at the mall and the narrow mall drives it just adds to the toughness. I haven't really seen any #4000's go through there yet. It probably would be rare to see that. Quote
jajuan Posted September 16, 2009 Report Posted September 16, 2009 You must have had a blast when driving your #4000 through Lincolnwood Town Center. It looks challenging for a 60 footer, then with the saturday traffic at the mall and the narrow mall drives it just adds to the toughness. I haven't really seen any #4000's go through there yet. It probably would be rare to see that. Come to think of it, I don't think I've seen an artic on 82 since it started serving the mall. I'd see the occasional 4000 on weekdays before that but not after. But for the topic at hand, I too noticed FG has started to send out a 1000 more likely than a 6000 on weekends. Quote
BusExpert32 Posted September 19, 2009 Report Posted September 19, 2009 Today, there are about 25 FG Flxibles in service- 10 Flxs on Belmont alone, so its not that bad with Flxibles out of Fg on weekends yet. You just have to scan Bustracker first to make it as easy as possible to track one down. Quote
cta_44499_FG Posted September 21, 2009 Report Posted September 21, 2009 You must have had a blast when driving your #4000 through Lincolnwood Town Center. It looks challenging for a 60 footer, then with the saturday traffic at the mall and the narrow mall drives it just adds to the toughness. I haven't really seen any #4000's go through there yet. It probably would be rare to see that. The only artics you should or would see on the 82 would be the North Park runs serving either Von Steuben or Northside Prep High School's and ending their trips at Congress and Homan to deadhead downtown for a 135 136. Quote
sht6131 Posted September 21, 2009 Report Posted September 21, 2009 You are absolutely correct regarding the southbound artic school trips. However, last week I did notice on the 82 Tracker a northbound Kedzie artic at Belmont at approximately 4PM. This run continued into the evening hours, One exception to the rule that I noticed that day. Quote
BUSANGEL#1 Posted September 21, 2009 Report Posted September 21, 2009 Kedzie usually puts at least 1 artic on a am or pm rush run on the #82 daily, the same with the #52 Quote
Nabinut Posted September 22, 2009 Author Report Posted September 22, 2009 Just a brief update. I will be in chicago during the week and the 152 (From Bustracker) looks to be the best bet despite seeing one assigned to the 124 last night ;) Quote
cta5658 Posted September 22, 2009 Report Posted September 22, 2009 Just a brief update. I will be in chicago during the week and the 152 (From Bustracker) looks to be the best bet despite seeing one assigned to the 124 last night if you have a chance to come south during the week, go to 95th/Dan Ryan and you might see some 6000's Quote
Nabinut Posted September 22, 2009 Author Report Posted September 22, 2009 I love going down to 95th/Dan Ryan. My best shots have come from there. I plan to hit the AM rush next Wednesday, crossing my fingers ;) Quote
jajuan Posted September 23, 2009 Report Posted September 23, 2009 I love going down to 95th/Dan Ryan. My best shots have come from there. I plan to hit the AM rush next Wednesday, crossing my fingers If you're making your trip during the week, route 82 out of Kedzie is a good candidate for 6000 sightings. Up to half the weekday runs (shudders at the thought) are covered by them. Quote
Busjack Posted September 23, 2009 Report Posted September 23, 2009 If you're making your trip during the week, route 82 out of Kedzie is a good candidate for 6000 sightings. Up to half the weekday runs (shudders at the thought) are covered by them. Seems like, with 157 being mostly NFs, the 6000s are being concentrated there and on 52. I wonder if that was what was intended. Quote
cta5658 Posted September 23, 2009 Report Posted September 23, 2009 sometimes 103 will put at least one 6000 on the #29 Quote
Nabinut Posted September 23, 2009 Author Report Posted September 23, 2009 Interesting note. I checked Bustracker this morning and saw at least 3 6000s (6006, 6007 & 6013) assigned to the 151 and another assigned to the 125 Quote
jajuan Posted September 23, 2009 Report Posted September 23, 2009 Seems like, with 157 being mostly NFs, the 6000s are being concentrated there and on 52. I wonder if that was what was intended. Yes but 52 hasn't been as consistant weekdays as 82 in terms of volume against numbers of NFs assigned. There are still weekdays where there may be few 6000s compared to NFs on 52. Quote
