MetroShadow Posted June 2, 2016 Report Posted June 2, 2016 New [Shuttle Bug] Route starts with the Summer Pick: 638 Quote
Busjack Posted June 3, 2016 Report Posted June 3, 2016 4 hours ago, MetroShadow said: New [Shuttle Bug] Route starts with the Summer Pick: 638 Need the map to know which HBSC. Turns out it is at Dundee and Rt. 53. Also, it does not have "Bug" in its name, as apparently nothing to do with the Lake-Cook TMA. Apparently 465 got the Bug because the LC TMA advised on it. "Shuttle Bug fare" only indicates that there won't be reduced fares. Quote
PNW7380 Posted June 3, 2016 Report Posted June 3, 2016 http://www.pacebus.com/sub/schedules/route_notice_detail.asp?Notice_ID=5671 I dont understand why Pace North Shore is operating this when Northwest Division is closer in proximity. Quote
Busjack Posted June 3, 2016 Report Posted June 3, 2016 1 hour ago, PNW7380 said: http://www.pacebus.com/sub/schedules/route_notice_detail.asp?Notice_ID=5671 I dont understand why Pace North Shore is operating this when Northwest Division is closer in proximity. Only conceivable things are union issues or equipment availability. Route 619 Allstate-Des Plaines raised the same issue. Deadhead is all the way on Dempster to McCormick. The former Aon-Des Plaines route was NW. Quote
Busjack Posted December 17, 2018 Report Posted December 17, 2018 The invisible route gets canceled (Hearing Notice). Quote
BusHunter Posted December 17, 2018 Report Posted December 17, 2018 4 hours ago, Busjack said: The invisible route gets canceled (Hearing Notice). I wonder how many retired nabis all these cuts translate to? Quote
NewFlyerMCI Posted December 17, 2018 Report Posted December 17, 2018 5 hours ago, Busjack said: The invisible route gets canceled (Hearing Notice). The invisible route? Quote
busfan2847 Posted December 18, 2018 Report Posted December 18, 2018 15 hours ago, Busjack said: None. Maybe NS has one more spare. It needed one more bus for the 213 restructuring. 638 is run using a 14xxx minibus. Quote
Busjack Posted December 18, 2018 Report Posted December 18, 2018 5 minutes ago, busfan2847 said: 638 is run using a 14xxx minibus. That certainly answers that. Gets back to the thought that whoever the corporate employer is should have just joined the corporate vanpool program. Quote
Busjack Posted December 19, 2018 Report Posted December 19, 2018 On 12/17/2018 at 3:16 PM, NewFlyerMCI said: The invisible route? You have your answer: 10 hours ago, busfan2847 said: 638 is run using a 14xxx minibus. Quote
MetroShadow Posted December 22, 2018 Author Report Posted December 22, 2018 On 12/18/2018 at 7:08 AM, Busjack said: That certainly answers that. Gets back to the thought that whoever the corporate employer is should have just joined the corporate vanpool program. Most cases, we give(gave) the option. And the costs. I’d be surprised if they don’t go with the vanpool options (typically it’s the best case scenario for a fixed route replacement). Quote
