MetroShadow Posted September 9 Report Posted September 9 2 hours ago, snailyards said: Hi all! This article had a new render of what the Stadler Flirts coming to Metra soon will look like. It’s a nice read, too (for anyone who has a subscription or can bypass the paywall). Welcome! It's not a matter of if, but (1) when they're on the property and (2) in testing. Considering 2027 is around the corner, too. Quote
snailyards Posted September 16 Report Posted September 16 Here’s a Stadler-provided data sheet for the Flirts. fbemu_metra0724en_us.pdf 1 Quote
snailyards Posted September 17 Report Posted September 17 Also, according to Twitter/X, the first Flirt has been assembled! It will be shown off at the *APTA expo at McCormick Place. 1 2 Quote
snailyards Posted September 22 Report Posted September 22 Here’s an article containing recent info on the logistics of the Flirts. I’ve listed some quotes that offer a quick summary of the updates: “Metra put the expected range of a fully charged trainset at 45 to 65 miles. It said a charge from 20% to 80%, enough for the train to operate, should take roughly 20 to 30 minutes.” “Stadler says the train stores energy in lithium-ion batteries on board, so it can run on non-electrified lines with no local emissions. It can top up from existing 480-volt cabling at yards and terminals or from dedicated chargers. Regenerative braking also returns energy to the batteries.” ”A two-car set will have 112 seats, and every added trailer car about 46 more. Boarding will be at low level, with lifts for ADA compliance.” And, per Stadler, the expectation that Metra will be running service using the Flirts by 2028 remains. Exciting stuff. Quote
snailyards Posted September 22 Report Posted September 22 Also, there was another rendering of the current (and potentially final!) livery. Here’s a before/after of the design. Looking sharp. Quote
Busjack Posted September 22 Author Report Posted September 22 12 minutes ago, snailyards said: ... “Metra put the expected range of a fully charged trainset at 45 to 65 miles. It said a charge from 20% to 80%, enough for the train to operate, should take roughly 20 to 30 minutes.” “... It can top up from existing 480-volt cabling at yards and terminals or from dedicated chargers. Since it says the line is 16.4 miles, that would be a 33 mile round trip, so unless the actual range is 70 miles, a charge is good for only one round trip. At the time the solicitation was advertised, there was a tour of the 47th St. Yard, but I don't know what good a charger would do there. I'm also not sure what the 480 volt cabling means--is it the plug-in head end power that Metra uses while trains are parked at the downtown stations? Some prior depictions showed a pantograph on the power unit extending to an overhead charger. Quote
snailyards Posted September 23 Report Posted September 23 44 minutes ago, Busjack said: Since it says the line is 16.4 miles, that would be a 33 mile round trip, so unless the actual range is 70 miles, a charge is good for only one round trip. At the time the solicitation was advertised, there was a tour of the 47th St. Yard, but I don't know what good a charger would do there. Yep, so they’ll likely just charge the battery pack up between rounds at the termini. 49 minutes ago, Busjack said: I'm also not sure what the 480 volt cabling means--is it the plug-in head end power that Metra uses while trains are parked at the downtown stations? Some prior depictions showed a pantograph on the power unit extending to an overhead charger. You’ll have to ask the author or Stadler themselves for specifics, but it sounds to me that it is indeed the existing plug-in power available at yards and terminals. As for the pantograph animation you alluded to, it may have just been a proof of concept. Otherwise, new infrastructure will be required at both LaSalle St. and Blue Island - Vermont St. stations. 1 Quote
Busjack Posted October 5 Author Report Posted October 5 ABC7 story at 11:00 a.m. about the Stadler trainset at McCormick Place. Of course, Brandon Johnson takes credit for something he had nothing to do about. Quote
artthouwill Posted October 5 Report Posted October 5 YouTube video ( not mine) of Staddler built Metra battery electric train at APTA. 2 Quote
Busjack Posted October 6 Author Report Posted October 6 2 hours ago, artthouwill said: YouTube video ( not mine) of Staddler built Metra battery electric train at APTA. That's an excellent video. The thing I liked was the digital signage, which I believe should be retrofitted into the existing Metra and South Shore fleets, but won't. The following shot taken from the video leaves open the previously debated question of what kind of coupler it has. (The promotional rendering had something that looked like a CTA coupler.) 2 Quote
Transit Introvert Posted October 6 Report Posted October 6 4 hours ago, artthouwill said: YouTube video ( not mine) of Staddler built Metra battery electric train at APTA. I was there too. 1 Quote
Busjack Posted October 6 Author Report Posted October 6 7 minutes ago, Transit Introvert said: I was there too. Do you have any insights to share from your personal observation? Quote
Transit Introvert Posted October 6 Report Posted October 6 14 hours ago, Busjack said: Do you have any insights to share from your personal observation? Quote
Jstange059 Posted October 7 Report Posted October 7 On 10/5/2026 at 7:20 PM, Busjack said: That's an excellent video. The thing I liked was the digital signage, which I believe should be retrofitted into the existing Metra and South Shore fleets, but won't. The following shot taken from the video leaves open the previously debated question of what kind of coupler it has. (The promotional rendering had something that looked like a CTA coupler.) For what it’s worth, I took a picture of the data plate on the coupler, so someone more knowledgeable than me may be able to draw some conclusions 3 Quote
Busjack Posted October 7 Author Report Posted October 7 7 hours ago, Jstange059 said: For what it’s worth, I took a picture of the data plate on the coupler, so someone more knowledgeable than me may be able to draw some conclusions I magnified it enough that it is a Voith FAC Type 10. Google AI had this (link), but I'll leave it to someone more technically proficient to figure it out. Apparently it is a high-speed rail automatic coupler. Quote
snailyards Posted Monday at 10:32 PM Report Posted Monday at 10:32 PM Per Metra: Riders are invited to LaSalle Street Station to view the first of Metra’s new battery-powered trainsets from Stadler, which will be on display at the station for two days. The trainset will be on display at LaSalle St. Station on Wednesday, Oct. 14, from 10 a.m. to 6 p.m. and on Thursday, Oct. 15, from 8 a.m. to 6 p.m. A public display! Quote
Busjack Posted 20 hours ago Author Report Posted 20 hours ago I hit fast forward when the self-serving politicians took over, but it was clarified at the end that the train will be plugged in at each end of a trip. Quote
