On 10/27/2022 at 12:47 PM, Mr.NewFlyer1051 said:
4000’s are getting replaced soon by XE60’s in the next couple yrs so i highly doubt they getting a rehab
Well with Nova pulling out the States, this speculation became partially more likely by way of dumb luck. Emphasis on partially given CTA seems imply the order won't be completely all artics and we don't yet know how many artics out of the equivalent 208 will actually be ordered.
On 12/19/2023 at 11:07 AM, Kevin said:
4376 has new seat inserts. I think these are similar to what the newest Novas have? They’re comfy. A gentleman who boarded with me commented that he thought it was a new bus. It certainly smells new thanks to the seats.
On 12/19/2023 at 6:32 PM, Mr.NewFlyer1279 said:
i wonder what the pilot buses look like unless they talking about #4376 and #4399, also two buses were removed from the scope?……..my huge guess is 4323 and 4333?
should be (4) pilots……4301, 4351, and ofc 4376 and 4399
Just rode 4351 on the 22 and yes it has the new seat inserts. All of your related comments posted above answers my question of how long ago this happened.
now this confirms that 4301 also has new seat inserts and a rebuilt engine…….did 4351’s engine sound different?
No. Its engine sounded the same as before. The only notable and noticeable difference was the seat inserts.
4362 got the new inserts. Currently working red line shuttle service. Engine seems quiet and i don't think I've seen a bus this clean for a while.
  • garmon757 changed the title to 4300/4330-series DE60LF/D60LF - Updates
  • garmon757 pinned this topic
  • 3 months later...
  • 3 months later...
All active D60LFR’s at North Park as of today are successfully rehabbed. The last non rehabbed ones have went out to rehab. 4358 and 4383 were the last two buses that have went to their overhaul.
not sure about 103rd but most of the ones I’ve seen recently are overhauled.
4341 sits on the south fence with a new drivers shield.
4359 has been active since August and  the bus tracker has not even been installed or repaired in that bus yet.
4336 and 4340 do not have working run number boxes.
From what i've seen for 103rd's DE60LFR's, 4304, 4312 and 4327 have the new seat inserts
4341 has been at South Fence with a new shield since June, and has not been touched since then. 4318 has been sitting at South fence for a long time. 4391 is now at the South Fence and was broken since September.
No idea where 4343, 4366, 4368, 4370, 4375, 4379, or 4389 are.
  • Sad 1
Every active unit in this series is active and has been rehabbed.
4341 and 4318 sit along the south fence and their rehab status is unknown.
i don’t think they’ll be overhauling 4307 due to its bad shape
has anyone seen 4375?
#4307 was in the process of getting rehabbed. They replaced the doors on it and some other miscellaneous work a month or so ago.
Interesting that bus should be Back on the road soon then
Has 4341 been in some kind of incident that’s causing CTA to drag their feet a bit with repairs?
I’m not even sure because all it’s been doing sitting at the same spot on the south fence for about a year now. It’s been OOS from summer of 2019 to January 2023 and only lasted 8 months before ending back up at SS in September of 2023
With #8350 deliveries and service placement winding down the focus has shifted back to the #4000s & #4300s receiving heavy maintenance this summer. I've seen a lot of activity around SS over the past month or so.
Hopefully that means we might see some artics come back from being OOS.
