Erin Mishkin Jr. Posted March 15, 2021 Report Posted March 15, 2021 1 minute ago, amybusphotos said: I just tried the incognito tab but unfortunately that doesn't work either. You needs to press the buttons on the bottom and eventually the proceed to site will pop up Quote
amybusphotos Posted March 15, 2021 Report Posted March 15, 2021 thank you Erin! Found the bus number I was looking for! Quote
YoungBusLover Posted March 15, 2021 Report Posted March 15, 2021 29 minutes ago, amybusphotos said: I just tried the incognito tab but unfortunately that doesn't work either. Click on the advanced tab then click on procced after that you should be able to continue to website without issue. Quote
Erin Mishkin Jr. Posted March 15, 2021 Report Posted March 15, 2021 2 hours ago, amybusphotos said: thank you Erin! Found the bus number I was looking for! You're welcome Quote
pete6125 Posted March 25, 2021 Report Posted March 25, 2021 I still can't get into the math 22 site. Is anyone able to get in. Quote
Erin Mishkin Jr. Posted March 25, 2021 Report Posted March 25, 2021 7 hours ago, pete6125 said: I still can't get into the math 22 site. Is anyone able to get in. Yes I can, but you have to use incognito mode to get in to maths 22. Click everything on the bottom that will lead you to the side and then you’ll be in finally! Quote
pete6125 Posted March 25, 2021 Report Posted March 25, 2021 5 hours ago, Erin Mishkin Jr. said: Yes I can, but you have to use incognito mode to get in to maths 22. Click everything on the bottom that will lead you to the side and then you’ll be in finally! I got into the site. Thank you very much. Quote
Erin Mishkin Jr. Posted March 25, 2021 Report Posted March 25, 2021 4 minutes ago, pete6125 said: I got into the site. Thank you very much. You're welcome. Quote
busfan2847 Posted April 6, 2021 Report Posted April 6, 2021 Certificate has been renewed and Jacob has added the 600 series to the bus tracker. The addition is retroactive so you can see data from when they first started operating on 3/23. Quote
Erin Mishkin Jr. Posted April 6, 2021 Report Posted April 6, 2021 24 minutes ago, busfan2847 said: Certificate has been renewed and Jacob has added the 600 series to the bus tracker. The addition is retroactive so you can see data from when they first started operating on 3/23. That's good! Quote
Mr.NewFlyer1051 Posted April 6, 2021 Report Posted April 6, 2021 8 minutes ago, Erin Mishkin Jr. said: That's good! the #600’s aren’t showing up on my trscker Quote
Erin Mishkin Jr. Posted April 6, 2021 Report Posted April 6, 2021 2 minutes ago, Mr.NewFlyer1051 said: the #600’s aren’t showing up on my trscker Oh i think you need to refresh it. If refreshing don't work then idk what happened Quote
Erin Mishkin Jr. Posted August 5, 2021 Report Posted August 5, 2021 Maths appears to be down this morning, keeps giving me a 404 error on my iPad. Incognito mode apparently isn’t working for me either unfortunately. Quote
amybusphotos Posted August 5, 2021 Report Posted August 5, 2021 Hi Jacob! It seems as though the bus tracker is no longer working even opening in an incognito tab doesn't seem to be working. I use the tracker almost everyday to help me find busses that have advertisements posted on them. best, Amy Quote
Policeman Posted August 6, 2021 Report Posted August 6, 2021 Seems like it's still down after 12+ hours Quote
busfan2847 Posted August 9, 2021 Report Posted August 9, 2021 On 8/5/2021 at 10:55 PM, Policeman said: Seems like it's still down after 12+ hours Looks like it came back up at 4:20pm on Friday Quote
Policeman Posted August 11, 2021 Report Posted August 11, 2021 Broken again... well at least for me Quote
Policeman Posted October 23, 2021 Report Posted October 23, 2021 maths has been on and off since 10 am Quote
busfan2847 Posted October 23, 2021 Report Posted October 23, 2021 15 hours ago, Policeman said: maths has been on and off since 10 am Back up again 11:00am 10/23 Quote
maths22 Posted October 25, 2021 Author Report Posted October 25, 2021 PSA: I have replaced the infrastructure hosting this tracker. All historical data has been carried forward, and it should work almost identically, but please let me know if you run into any issues. 1 1 1 Quote
Mr.NewFlyer1051 Posted October 25, 2021 Report Posted October 25, 2021 51 minutes ago, maths22 said: PSA: I have replaced the infrastructure hosting this tracker. All historical data has been carried forward, and it should work almost identically, but please let me know if you run into any issues. nice to see you back on the forums?? 1 Quote
YoungBusLover Posted October 26, 2021 Report Posted October 26, 2021 4 hours ago, maths22 said: PSA: I have replaced the infrastructure hosting this tracker. All historical data has been carried forward, and it should work almost identically, but please let me know if you run into any issues. Welcome back ! Is there anyway to add a feature that would show when buses were last in service? Also having a headcount for the buses that are in service. Quote
Erin Mishkin Jr. Posted October 26, 2021 Report Posted October 26, 2021 5 hours ago, maths22 said: PSA: I have replaced the infrastructure hosting this tracker. All historical data has been carried forward, and it should work almost identically, but please let me know if you run into any issues. On incognito mode this doesn’t happen on my iPad but on the regular mode, whenever I try to pop open the archive calendar, I get this message. It should be fixed so I don’t have to interchange between incognito and normal mode. 9 minutes ago, YoungBusLover said: Welcome back ! Is there anyway to add a feature that would show when buses were last in service? Also having a headcount for the buses that are in service. This is a very smart idea! I’ve always wanted to track when certain buses were last out like I’m trying to find when 8288 was specifically last in service since I didn’t see that bus on the tracker for a while and other buses I’m tracking too Quote
busfan2847 Posted October 26, 2021 Report Posted October 26, 2021 11 hours ago, Erin Mishkin Jr. said: This is a very smart idea! I’ve always wanted to track when certain buses were last out like I’m trying to find when 8288 was specifically last in service since I didn’t see that bus on the tracker for a while and other buses I’m tracking too I use Maths22 to keep a track of buses in service at 8am and 5pm on Mondays, Wednesdays and Fridays. From that data the last date I have for 8288 in service is 9/29/21, although it was not out from 8/30/21 to 9/29/21 as well Quote
