  • 3 months later...
  • 3 months later...
On 12/19/2021 at 11:58 AM, Erin Mishkin Jr. said:
Route schedule won’t load for me, trying to track how long I will be with a friend of mine tomorrow and now I don’t know since it’s not working
tracker was fixed as of last night and today's event was successful thanks to transsee!
  • 2 years later...
1 hour ago, YoungBusLover said:
The devs are doing maintenance on it right now.
Many thanks for the info.
2 hours ago, Erin Mishkin Jr. said:
Transsee appears to not be loading CTA stuff correctly like the tracker
So much for those who said it was an alternative to Ventra or Transit apps.
  • 10 months later...
23 hours ago, sht6131 said:
Regarding TransSee, although the run number box is checked, the run numbers disappeared and numbers appeared that I don`t understand. Is it only me?
They changed the source to track buses, so it does appear a little differently.
Thanks for the response. In settings any idea as to how to get the run numbers to appear when the run number box is checked?
It's hard to capture it, but it looks like it is how much it is running ahead of the scheduled departure time at the selected stop. PDF attached. Note that the number after "ahead of" is every 10 minutes. A bus that arrived at 9::47 is now listed as 9:58, waiting, 0:00 behind 9:58
Randolph on Columbus - 4-Cottage Grove - Chicago CTA Arrival Predictions - TransSee.pdf
Randolph on Columbus - 4-Cottage Grove - Chicago CTA Arrival Predictions - TransSee.pdf 224.55 kB · 5 downloads
Thanks Busjack.
27 minutes ago, sht6131 said:
Thanks Busjack.
As a aforementioned thought, the link I previously had before the change, listed bus number, run number, direction and approaching stop and destination. Simple to understand. Its got to be somewhere in the settings but afraid I will screw this up looking for it.
4 hours ago, renardo870 said:
When will the TranSee update the upcoming Bus Schedules that are to take effect 3/23/25? I've been checking for the last 4 days and it not updated yet.
Give or take several days, provided that the GTFS feed matches the new schedules. Pantograph and TransitApp both have minimal lags.
Transsee now has the wrong schedule and a lot of the bus runs are now way off. Like it says “a 147 going to 87th & Damen terminal” bc the 147 trip ID from today is coinciding with a 95 trip from the winter pick which is still published
