Tcmetro Posted October 10 Report Posted October 10 The Revision draft will be published on Oct 21st. https://pacebus.com/revision 1 Quote
MetroShadow Posted October 21 Report Posted October 21 On 10/10/2026 at 10:05 AM, Tcmetro said: The Revision draft will be published on Oct 21st. https://pacebus.com/revision Commence Speculation! Quote
Busjack Posted October 21 Report Posted October 21 (edited) On 10/21/2026 at 5:35 PM, MetroShadow said: Commence Speculation! The first thing that makes it speculation is the statement: "CTA, Metra, and Pace are providing NITA with recommendations from their network planning efforts conducted in 2026." As it appears up to the NITA board to move forward, things are certainly up in the air. @MetroShadow won't like me saying this, but most of the first part is for wonks. My areas of interest are North Cook and South Lake, and I found notable (most of which carry over from the prior drafts: New 575 provides a more direct trip to Hawthorne; 574 is replaced by alternate 272 trips. {Updated} 473 is essentially 471 only to Jewel on Deerfield Rd. and 472 north to Fort Sheridan, but no service further west on Deerfield Rd. or W. Park Ave. Route 216 between NWTC and Howard CTA, basically as an Oakton route. Route 215 would remain, and would be extended via 422 to Glenview. {Added} Route 224 is around the south side of O'Hare to the cargo area (replacing 332), and then around to the south side of Elk Grove. Route 260 is the hinted Dundee Road route, from NWTC via Harper College (replacing 697), Dundee, Pfingsten, to the Lake Cook Milw-N station. Route 333 between NWTC to Yorktown replacing north end of 715. Route 335 between NWTC to College of DuPage and Yorktown. 213 cut back to Glencoe, then Dundee Road, Skokie Blvd. (serving part of discontinued 626), to Lake-Cook Milw-N. Pulse Dempster and 290 to Rosemont CTA. 250 routing unchanged. Route 220 replaces 226 on Niles Center Rd. and 422 between Old Orchard and Linden. At this point, routes connect with the Blue Line: 270 continues east to Glenview Metra. 209 goes down Talcott serving Resurrection Hospital (ending speculation about why it wasn't returned to Harlem), and extended via Rand Road to Deer Park. 245 and 246 will be Harlem-Waukegan routes (on Waukegan north of Oakton). The new twist here is the split being at Glenview Metra, with 245 serving Waukegan Rd. and 246 The Glen. Both would join at Willow-Patriot, go through Northbrook, and then via Northbrook Court (still there, I guess), and then to Highland Park (I said it was not moot). 210 canceled between Lincolnwood and Dempster. 423 canceled where not picked up by 245 and 246 (Plaza del Lago, Winnetka). I have to be off, so I'll look at some things of less interst later. Or others can. Edited October 23 by Busjack Updated 224 and 473 after magnifying maps Quote
Busjack Posted October 21 Report Posted October 21 1 hour ago, Busjack said: The first thing that makes it speculation is the statement: "CTA, Metra, and Pace are providing NITA with recommendations from their network planning efforts conducted in 2026." As it appears up to the NITA board to move forward, things are certainly up in the air. In the Northeast Cook portion, under Evanston, it says: Quote Regional Transit and Shared Corridors This plan does not change the overall distribution of service between CTA and Pace in Evanston and Skokie, but seeks to minimize any duplication. Future regional transit planning under NITA should aim to minimize such duplications as well. (emphasis added) Accordingly, 54A is mentioned, but nothing is suggested about it. I'm also surprised by that after all the stink about cutting Northbrook and Glenview, better service is proposed. Quote
Sam92 Posted October 21 Report Posted October 21 6 hours ago, MetroShadow said: Commence Speculation! It's about time Waukegan got a consistent North-south bus route. For Lewis to connect to so many needed areas about only run hourly on the weekdays was egregious. The removal of service on 10th Street might hurt for 568 riders but at least it removes the detour of having to circle whispering oaks apartments for riders that want a straight shot. Mostly high schoolers getting on and off for school anyway anyway so 566 and 573 can do the job well enough. Quote
Busjack Posted October 22 Report Posted October 22 On only a cursory review of the rest of it: The apparent resolution of the 90 to Forest Park Blue Line is the proposal here to run 307 from 103rd to North Avenue, and then on North Ave. replacing 318. In effect, the old 747 comes back through Route 300 from Fox Valley Mall to Forest Park, express east of Oakbrook, and 539 from the St. Charles area to Yorktown. A lot of SW routes are broken at Moraine Valley College to avoid forest preserves (something on which I commented when 379 was extended to Orland Square). For instance, 376 would take over 385 to MVC, and then Orland Park and Tinley Park, while 385 would operate between MVC and Blue Island. 383 would go to 167th & Pulaski and then replace 354 on 167th. 375 from MVC would replace 354 on 147th, eliminating the nonsense clockwise and counterclockwise signs. 351 is basically Torrence, but would take I-94vnorth of Dolton Ave. to 95th,and also replace 357 east of Chicago Heights. A lot of changes around Chicago Heights. 1 Quote
Busjack Posted October 22 Report Posted October 22 23 hours ago, MetroShadow said: Commence Speculation! Here's some areas for wild speculation: Unless Pace did something else weird with the numbering, it appears that 26500-12, 26514-26533 (the 2024 Low/No buses) are all 35' buses and presumably going to the collar counties. 22300s are not being moved as quickly as we thought and FV is getting 26500s. Also, some NS buses were sidelined. Is Pace hoarding buses in anticipation of implementing this plan? Stuff like canceling 332, 559 and 626 and part of 423 isn't going to be enough to cover this proposal. While 272 gets separated from the downtown Waukegan system (thereby maybe limiting my concern about the length of that block for BEB purposes), there are a lot more long routes, such as 300 (Fox Valley Mall to Forest Park), 307 (North and Wolf to Harlem 103rd), and 383 to Harvey, that being long, might be broken, also brings up... Are the route numbers indicative of which garage will operate them? For instance, does 300 indicate it will run out of W, or will it be out of FV or both? As asked with respect to Harlem Pulse, will 307 also be out of SW? What about 370s-380s going to the Harvey area? While I'm sure most of this plan will be well received, I wonder about such things as 213 going down Dundee Road, a residential street, in Glencoe, although I foresaw that before the last restructuring. Quote
rotjohns Posted October 22 Report Posted October 22 2 hours ago, Busjack said: Here's some areas for wild speculation: Unless Pace did something else weird with the numbering, it appears that 26500-12, 26514-26533 (the 2024 Low/No buses) are all 35' buses and presumably going to the collar counties. 22300s are not being moved as quickly as we thought and FV is getting 26500s. Also, some NS buses were sidelined. Is Pace hoarding buses in anticipation of implementing this plan? Stuff like canceling 332, 559 and 626 and part of 423 isn't going to be enough to cover this proposal. While 272 gets separated from the downtown Waukegan system (thereby maybe limiting my concern about the length of that block for BEB purposes), there are a lot more long routes, such as 300 (Fox Valley Mall to Forest Park), 307 (North and Wolf to Harlem 103rd), and 383 to Harvey, that being long, might be broken, also brings up... Are the route numbers indicative of which garage will operate them? For instance, does 300 indicate it will run out of W, or will it be out of FV or both? As asked with respect to Harlem Pulse, will 307 also be out of SW? What about 370s-380s going to the Harvey area? While I'm sure most of this plan will be well received, I wonder about such things as 213 going down Dundee Road, a residential street, in Glencoe, although I foresaw that before the last restructuring. My speculation based on Dupage County since that's where I see the most activity: 1. 559 being eliminated isn't a surprise, ridership has always been low. 2. With the new Block 59 taking shape in Naperville, especially with IKEA moving in, buses will definitely be in demand. Now I haven't been to Fox Valley mall in a while, but why such expanded service? Is the mall going thru a revitalization? Same with Yorktown, although I get the fact that mall connects with multiple buses. The FV mall to Forest Park is a hike and likely requires a 40 footer if ridership dictates it. 3. COD to 7 days/week on some routes? Hmmm.... 4. The fact that 22300s haven't been moved and significant changes would come in Dupage County's smaller routes might tell us that might be where these buses would be heading along with some (if not all) 20300s if 26500s go all the way to 26533. That would eliminate Batavia garage altogether, which might be the long term plan anyway. 5. Lot of employers along 722 and I see lots of ridership, especially in the afternoon. Pace would need to work with them to figure out a plan as there's no option to get to Ogden easily. Currently 714 and 722 are delayed heavily due to construction along Naper Blvd and Washington St respectfully, both not expected to end until 2027. 6. IF all of this plays out, Pace is going to be hiring heavily to account for new weekend routes. Quote
Busjack Posted October 22 Report Posted October 22 13 minutes ago, rotjohns said: My speculation based on Dupage County since that's where I see the most activity: ... 2. ... Now I haven't been to Fox Valley mall in a while, but why such expanded service? Is the mall going thru a revitalization? Same with Yorktown, although I get the fact that mall connects with multiple buses. The FV mall to Forest Park is a hike and likely requires a 40 footer if ridership dictates it. ... 4. The fact that 22300s haven't been moved and significant changes would come in Dupage County's smaller routes might tell us that might be where these buses would be heading along with some (if not all) 20300s if 26500s go all the way to 26533. That would eliminate Batavia garage altogether, which might be the long term plan anyway. 5. Lot of employers along 722 and I see lots of ridership, especially in the afternoon. Pace would need to work with them to figure out a plan as there's no option to get to Ogden easily. Currently 714 and 722 are delayed heavily due to construction along Naper Blvd and Washington St respectfully, both not expected to end until 2027. ... 2. Fox Valley Mall is being redeveloped (Centennial Real Estate site). But I think the focus is really on establishing a transfer center, cutting back 530 from Naperville to there. Theoretically it would have less service with 559 cut. This seems to be part of a trend to make more transfer points, such as Lake-Cook Metra (with the proposed cut of 626, nothing else would be there, so may as well put 213 and 260 there). Similarly, the new north-south orientation of routes replacing 422 would indicate one can't get to Old Orchard, but with the new grouping at Glenview, one can transfer to the new 215. 4. Could be. I wonder if something like 333 or 335 could use a 35' bus. 5. Bypassing the Warrenville Road area surprised me. That's where a lot of the Naperville-Lisle local traffic was. But did it become like Lake-Cook Road with its corporations cutting back? Quote
rotjohns Posted October 22 Report Posted October 22 3 minutes ago, Busjack said: 5. Bypassing the Warrenville Road area surprised me. That's where a lot of the Naperville-Lisle local traffic was. But did it become like Lake-Cook Road with its corporations cutting back? It did take a hit when 829 got cut, but from what I've been seeing lately, passengers seem to be getting off at Ogden/Main in Lisle and walking to Metra since it's only about 3 blocks away. I passed by there the other day around 4:20pm and 6 people were waiting at one bus stop along Warrenville going east. And a handful do still go to Naperville Metra from that area, although I'd think they've be heading to Aurora via westbound Metra or the current 530. Quote
RJL6000 Posted October 24 Report Posted October 24 In the proposed new map, the 606 will no longer run concurrently with the 208 west of New Wilke Road. Instead, the 606 will turn north on New Wilke and then back northwest on Algonquin before turning south on Meacham Road towards the Northwest Transportation Center. That will leave the Hyatt runs solely to the 208, while the Woodfield Corporate Center bus service will be taken over by the proposed 333 and 335. Also, the existing Route 209 will be extended well past Des Plaines-all the way into Palatine via Rand Road. And it will be expanded to daily service (currently, it is a weekday-only route). And 221 will be rerouted to run on Elmhurst Road and Main Street instead of Wolf Road for much of its routing, partially replacing the current 234. Finally, the new 260, which will run mostly on Dundee Road, will fully absorb the current 697 in its routing between the Lake-Cook Road Metra UP-N station and the Northwest Transportation Center. Quote
Bus1807 Posted October 24 Report Posted October 24 2 minutes ago, RJL6000 said: In the proposed new map, the 606 will no longer run concurrently with the 208 west of New Wilke Road. Instead, the 606 will turn north on New Wilke and then back northwest on Algonquin before turning south on Meacham Road towards the Northwest Transportation Center. That will leave the Hyatt runs solely to the 208, while the Northwest Corporate bus service will be taken over by the proposed 333 and 335. Also, the existing Route 209 will be extended well past Des Plaines-all the way into Palatine via Rand Road. And it will be expanded to daily service (currently, it is a weekday-only route). And 221 will be rerouted to run on Elmhurst Road and Main Street instead of Wolf Road for much of its routing, partially replacing the current 234. I am quite happy the 209 is getting extended. I grew up with CTA Route 103 and Pace 209, so seeing my childhood route getting revisions really makes me happy. Quote
Busjack Posted October 24 Report Posted October 24 6 hours ago, RJL6000 said: In the proposed new map, the 606 will no longer run concurrently with the 208 west of New Wilke Road. Instead, the 606 will turn north on New Wilke and then back northwest on Algonquin before turning south on Meacham Road towards the Northwest Transportation Center. Did the Motorola campus get redeveloped enough to deserve service? Quote
Busjack Posted October 26 Report Posted October 26 On 10/24/2026 at 2:58 PM, RJL6000 said: ... Also, the existing Route 209 will be extended well past Des Plaines-all the way into Palatine via Rand Road. And it will be expanded to daily service (currently, it is a weekday-only route). And 221 will be rerouted to run on Elmhurst Road and Main Street instead of Wolf Road for much of its routing, partially replacing the current 234. ... This concurs with my prior observation about longer routes. Both here and in South, they are getting rid of stub routes left from prior restructurings (here 209 used to go to Schaumburg but the Golf Rd. portion was assumed by 208). On the other hand, the interline between 209 and 234 gets cut, so 221 provides some coverage, but apparently there isn't enough ridership to Wheeling and Buffalo Grove. Quote
Adam Hubbard Posted October 26 Report Posted October 26 Is Pace Routes 215 suppose to go to the Jefferson Park Transit Center, Route 226 be extended to the Howard Station? Quote
RJL6000 Posted October 26 Report Posted October 26 54 minutes ago, Adam Hubbard said: Is Pace Routes 215 suppose to go to the Jefferson Park Transit Center, Route 226 be extended to the Howard Station? The plans have been changed. Route 226 will be superseded by a new 216, now operating between the Howard CTA terminal and the Northwest Transportation Center via Oakton and Higgins. 215 will remain, but extended into Glenview. Quote
jajuan Posted October 27 Report Posted October 27 On 10/21/2026 at 8:35 PM, Busjack said: On only a cursory review of the rest of it: The apparent resolution of the 90 to Forest Park Blue Line is the proposal here to run 307 from 103rd to North Avenue, and then on North Ave. replacing 318. In effect, the old 747 comes back through Route 300 from Fox Valley Mall to Forest Park, express east of Oakbrook, and 539 from the St. Charles area to Yorktown. A lot of SW routes are broken at Moraine Valley College to avoid forest preserves (something on which I commented when 379 was extended to Orland Square). For instance, 376 would take over 385 to MVC, and then Orland Park and Tinley Park, while 385 would operate between MVC and Blue Island. 383 would go to 167th & Pulaski and then replace 354 on 167th. 375 from MVC would replace 354 on 147th, eliminating the nonsense clockwise and counterclockwise signs. 351 is basically Torrence, but would take I-94vnorth of Dolton Ave. to 95th,and also replace 357 east of Chicago Heights. A lot of changes around Chicago Heights. One thing that caught my eye last night, adding to what you mentioned for Southwest Cook, is their also putting forth a proposal add another extension 315 along Cicero beyond Midway to 79th and then have it travel to Moraine Valley along the current 379 routing and therefore combining the northern part of the current iteration of 379 into the 315. They're also proposing it be among their frequent routes, which they define as routes with headways no higher than 15 minutes. On the I-90 front, their proposal is to combine the existing routes, with the exception of 606, under the route number 600 and convert that new 600 to a daily frequent route. In West Division's territory, 317 goes bye bye. So looks like Pace also couldn't maintain it after finally fully taking it over from CTA. Quote
Busjack Posted October 27 Report Posted October 27 9 minutes ago, jajuan said: On the I-90 front, their proposal is to combine the existing routes, with the exception of 606, under the route number 600 and convert that new 600 to a daily frequent route. It still said that 605 will be retained as a peak hour route. Pace isn't going to give up the Randall Road P&R. Quote
jajuan Posted October 27 Report Posted October 27 10 minutes ago, Busjack said: It still said that 605 will be retained as a peak hour route. Pace isn't going to give up the Randall Road P&R. Thanks for the reminder. I was trying to go off memory of my quick glance through on that one. Like you, I also notice some of these changes would result in some pretty long routes, if NITA were to accept them. The changes you noted for the 307 for example would be a monster of a route for operators to take on after extending to 103rd on top of getting combined with 318. Quote
RJL6000 Posted October 27 Report Posted October 27 What the I-90 express routes consolidation means is that 603 will be discontinued in favor of combining the 600 and the 607 into a single 600 express route, making a single intermediate stop in Schaumburg (the 600 and 607 have been interlining with the other). Quote
RJL6000 Posted October 27 Report Posted October 27 The western portion of the 313 will be changed as well: The routing between Madison/Westmore-Meyers and 22nd/Grace will revert to operating on Madison-Main-22nd instead of continuing south on Westmore-Meyers, while operation along Villa and Washington will be discontinued in favor of continuing west on St. Charles Road to Westmore-Meyers Road before turning south. To partially compensate for the loss of service on Villa, a new route 335 will operate in Villa Park via Ardmore Avenue. Most of Route 318 will be absorbed into the restructured Route 307, which will be extended further south into Worth, while the 315 will be extended all the way to Moraine Valley College. The northern end of the current 307 will be entirely provided by the CTA route 90 and an extended Pace route 319, which will now operate all the way to the CTA Harlem Green Line terminal, absorbing the portion of the current 311 north of South Blvd. Un the process. Quote
RJL6000 Posted October 27 Report Posted October 27 Finally, for thosewho are complaining about Wheeling and Buffalo Grove becoming unserved, the new Route 260 will render the current 604 redundant, plus the 260 will serve locations in Palatine that are currently served only by the Northwest On Demand service. Quote
Busjack Posted October 28 Report Posted October 28 2 hours ago, RJL6000 said: What the I-90 express routes consolidation means is that 603 will be discontinued in favor of combining the 600 and the 607 into a single 600 express route, making a single intermediate stop in Schaumburg (the 600 and 607 have been interlining with the other). Not really. 607 now goes to Randall Road. 603 now goes to Elgin TC. 605 now runs 5:15am to 11:38pm. weekdays and 6:15am to 8:08pm Saturdays. The proposal is "Route 600 would provide service every 15 minutes, seven days per week, between Elgin, Barrington Rd, Pace Northwest Transportation Center, and the Rosemont station on the CTA Blue Line. In northeast Elgin, this route would also provide frequent local service along Dundee Ave. The proposed service would consolidate and replace service currently provided by Routes 600, 603, and 607 with a single higher-frequency pattern. • Route 605 would remain in the Draft Plan network but would operate during peak hours only between Pace I-90/Randall Rd Station and Rosemont." Thus, 600 would be a combination of 600 and 603. 607 would essentially be dead, except one could take a bus between NWTC and Barrington Rd. (and presumably the IL 25 P&R). And, as I noted before, Randall Road would be limited to rush hour service. Quote
MetroShadow Posted October 28 Report Posted October 28 14 hours ago, jajuan said: Thanks for the reminder. I was trying to go off memory of my quick glance through on that one. Like you, I also notice some of these changes would result in some pretty long routes, if NITA were to accept them. The changes you noted for the 307 for example would be a monster of a route for operators to take on after extending to 103rd on top of getting combined with 318. After experiencing the 208, you might think that these long routes are a liability unless TSP is working. But with 307/318, we've already established this as a precursor to Pulse, and it could be acceptable as long as reliability isn't impacted. This is where 315 might be a bit too long, since Midway is already a hub. Giving some of these routes a new home (315/379, 300/737/747), does make sense on paper., but I worry about the runtime as a whole. Missed opportunities (301/305, Mundelein On-Demand) are also an issue. Some suggestions (351, 376, 385, 245/46, etc.) show a commitment to building coverage in areas that might haven't seen service since the 80s and 90s. On 10/21/2026 at 12:27 PM, Busjack said: The first thing that makes it speculation is the statement: "CTA, Metra, and Pace are providing NITA with recommendations from their network planning efforts conducted in 2026." As it appears up to the NITA board to move forward, things are certainly up in the air. @MetroShadow won't like me saying this, but most of the first part is for wonks. Hey - I resemble that remark. 🤪 Quote
Busjack Posted October 29 Report Posted October 29 4 hours ago, MetroShadow said: Giving some of these routes a new home (315/379, 300/737/747), does make sense on paper., but I worry about the runtime as a whole. Missed opportunities (301/305, Mundelein On-Demand) are also an issue. I hadn't thought about that angle, but I agree that getting off schedule and missing connections are concerns. I was thinking about operators' bladders (remember the figurative and literal stinks over the lack of CTA operators' facilities), and the length of blocks for electrification purposes.* One probably could add the problem of getting a replacement bus to a breakdown. I also wonder if Morraine Valley College can handle all the routes planned to terminate there. *These are related to comments I previously made about the long 565-574-272-272-574-572 interline, including an "unscheduled stop" at the Dunkin at Milwaukee and Palatine Road. As I noted, 272 was detached from that in the plan, but the plan seems to contain longer ones. Quote
