11/11/14 1:18a
Upcoming Rail Alert For 11/11/14 @ 9p until 11:30p
Rail Line(s) Affected: Yellow
Information: Trains in both directions will operate on the same track between Howard and Oakton-Skokie.
This is due to track maintenance to ensure that trains continue to operate safely along the Yellow Line.
11/11/14 11:43p
Upcoming Rail Alert For 11/12/14 @ 9p until 11:30p
11/12/14 7:58a
Rail Line(s) Affected: Purple, Yellow
Information: Linden and Dempster-Skokie-bound trains are experiencing delays at Howard due to track switching problems.
Evening rush trouble!
Purple Line Express and Pink Line trains will run in the Outer Loop due to track switching problems at Lake/Wells. Brown, Green, and Orange Lines will run their normal circuits around the Loop.
After 9 P.M. tonight, Orange Line trains will navigate the Loop counter-clockwise.
Expect minor delays.
11/12/14 10:31p
Upcoming Rail Alert For 11/13/14 @ 9p until 11:30p
11/14/14 5:39p
Rail Line(s) Affected: Brown
Information: Kimball-bound trains are experiencing delays near Merchandise Mart due to a door problem on a train.
11/15/14 12:21a
Upcoming Rail Alert For 11/15/14 @ 6:30a until 5:30p
Information: Trains in both directions will operate on the same track between Belmont and Southport.
This is due to structural maintenance to ensure that trains continue to operate safely along the Brown Line.
11/15/14 12:27a
Upcoming Rail Alert For 11/15/14 @ 6:30a until 7:30p
Information: Trains in both directions will operate on the same track between Fullerton and Sedgwick. Board/Exit all trains on the Kimball-bound platform at Armitage.
This is due to structural improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project.
11/15/14 10:32a
Level Of Service Interruption: Service Disrupted
Information: Trains are experiencing disrupted service due to a raised bridge at the Chicago River, Downtown.
Alternate Service: Shuttle Buses are available to provide connecting service between Merchandise Mart and Clark/Lake.
Additional Note(s): Some Loop-bound trains may be held or turned back before reaching the bridge in order to maintain service across the remainder of the route. Listen for Operator announcements and check train destination signs when boarding.
11/15/14 11:06a
Rail Line(s) Affected: Green, Pink
Alternate Service: Shuttle Buses are available to provide connecting service between Clinton and Clark/Lake.
Additional Note(s): Some Loop-bound trains may be held or turned back before reaching the bridge in order to maintain service across the remainder of the route(s). Listen for Operator announcements and check train destination signs when boarding.
11/16/14 1:24a
Upcoming Rail Alert For 11/16/14 @ 6:30a until 5:30p
  • 6:30a-12p: Board/Exit all trains on the Loop-bound platform at the Armitage station.
  • 12p-5:30p: Board/Exit all trains on the Kimball-bound platform at the Armitage station.
11/16/14 12:50p
Rail Line(s) Affected: Red
Information: Minor Delays, Station(s) Bypassed
Information: Howard-bound trains are not stopping at Jarvis due to a track condition. Passengers wishing to alight between Berwyn and Jarvis must board a 95th-bound train at Howard and ride back south to these stations.
Alternate Service: Passengers can use the #151 Sheridan, #36 Broadway or #147 Outer Drive Express buses as alternates.
11/17/14 1:23a
Construction Alert For 11/17/14 @ 9:30a until 2:30p
Level Of Service Interruption: --
Information: Harlem/Lake-bound trains will not stop at 47th.
  • Service to 47th: Take a Harlem/Lake-bound train to 43rd and transfer to a 63rd-bound train
  • Service from 47th: Take a 63rd-bound train to 51st and transfer to a Harlem/Lake-bound train.
This is due to platform improvements to the 47th St. station.
11/18/14 12:50p
Level Of Service Interruption: Significant Delays
Information: Trains are operating with delays after earlier fire department activity in the area of Armitage.
11/18/14 10:11p
Construction Alert For 11/19/14 @ 9:30a until 2:30p
11/20/14 1:13a
Construction Alert For 11/20/14 @ 9:30a until 2:30p
11/21/14 2:22a
Construction Alert For 11/21/14 @ 9:30a until 2:30p
11/21/14 11:04p
Rail Line(s) Affected: Red, Purple
Information: Some Howard-bound and 95th-bound trains are operating with delays after earlier mechanical problems on a train at Howard.
11/22/14 1:30a
Upcoming Rail Alert For 11/22/14 @ 6:30a until 4:30p
11/24/14 1:00a
Construction Alert For 11/24/14 @ 9:30a until 2:30p
11/25/14 12:32a
Construction Alert For 11/25/14 @ 9:30a until 2:30p
11/30/14 1:00p
Rail Line(s) Affected: Blue
Information: Forest Park-bound trains are standing near Harlem(O-Hare) due to a mechanical problem on a train.
11/30/14 2:02p
Information: Howard-bound trains are operating with delays after an earlier door problem at 63rd.
11/30/14 9:49p
Upcoming Alert For 12/1/14 @ 9a until 3p
Information: Trains in both directions will operate on the same track between Garfield and King Drive.
This is due to track maintenance to ensure that trains continue to operate safely along the Green Line.
