CTA Rail Service Alerts
sw4400
1/7/15 2:29a
***Late Night Rail Alert***
Rail Line(s) Affected: Red
Level Of Service Interruption: Service Disrupted w/Reroute
Information: Howard-bound trains are being rerouted to the elevated tracks due to Police Activity at Clark/Division.
Service To Howard: After stopping at Cermak-Chinatown, trains will operate on the elevated tracks and make the following stops:
  • Roosevelt
  • Adams/Wabash
  • Madison/Wabash
  • Randolph/Wabash
  • State/Lake(Red)
  • Clark/Lake(Blue)
  • Merchandise Mart
  • Chicago/Franklin
  • Sedgwick
  • Armitage
Trains will then stop at Fullerton and make all normal Red Line stops to Howard.
Connections to 95th-bound trains and rerouted Howard-bound trains can be made at Fullerton, State/Lake(board Howard-bound trains on elevated platform, Brown Line side) and at Roosevelt.
If anybody is entering the Red Line at 69th then please be advised that the water main line is busted causing downstairs by the platform to flood (very dangerous due to the extreme weather). #3, #4, #6, #8, #9, #J14, #15, #24, #28, #29, #49 and Green Line can be alternates for your trip. Please be mindful and safe everybody.
1/11/15 12:54a
Upcoming Rail Alert For 1/11/15 @ 6a until 6p
Rail Line(s) Affected: Brown
Information: Trains in both directions will operate on the same track between Armitage and Merchandise Mart. Board/Exit all trains on the Loop-bound platform at Sedgwick and Chicago.
This is due to structure improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project.
1/11/14 12:57a
Upcoming Alert For 12/11/14 @ 1:40a until 11:40a
Rail Line(s) Affected: Green
Level Of Service Interruption: Service Disrupted w/Alternate Service Available
Information: Trains operate between Harlem/Lake, Downtown(Loop Elevated), and Roosevelt and between 35th-Bronzeville-IIT, Ashland/63rd, and Cottage Grove.
Alternate Service: Shuttle Buses will replace rail service between Roosevelt and 35th-Bronzeville-IIT. Free transfer between Shuttle Buses and Rail Service is only available at Roosevelt and 35th-Bronzeville-IIT, and requires the farecard used to pay your fare at the start of your trip.
This is due to construction of the new Cermak-McCormick Place station
1/11/15 12:58a
Upcoming Alert For 12/11/14 @ 4:30a until 4p
Rail Line(s) Affected: Orange
Level Of Service Interruption: --
Information: Trains will operate counterclockwise on the Outer Loop. Board/Exit Orange Line trains on the Brown Line platform at all Loop stations.
This is due to track maintenance to ensure that trains continue to operate safely on the Loop Elevated.
1/11/15 12:58a
How does this not require the Pink Line to be rerouted counterclockwise, or the 63rd-bound Green Line via Wells and VanBuren? Because they run on the Inner Loop too.
May depend on whether the work is only at the crossover at Wabash-Van Buren as only the Orange Line makes that crossover.
Correct me if I'm wrong but only the Pink Line would be affected. The Green Line doesn't run on the Wells-Van Buren leg of the loop
It doesn't, but the alert didn't say where the work was being done, only that the Orange Line was going on the Brown Line loop direction.. If the southbound track on Wabash were affected, so would the Green Line.
That's why my guess about where the work was being done.
Also, I was starting to bet that they could be working on the right-turn Wells-to-Lake track. That would make sense as well.
They got some problems with forest pk bound blue line trains right now. They have 5 trains stacked between logan and addison. The train at logan had an electrical smell. They say that's a brake issue. The titan signs say that trains are moving after a problem with a train at jeff. I think they are still having trouble with that same train.
Four lines have weekend service changes for maintenance this weekend, and involve the Pink and Orange Lines going counter-clockwise around the Loop, 95th bound Red Line trains going "over the top", and Green Line trains only running between Harlem and Roosevelt and 35-Bronzeville-IIT and the 63rd Terminals.
An overview for the work can be found here.
Info for the Red Line work and reroute can be found here.
Info for the Pink Line and Orange Line work and reroute can be found here.
Info for the Green Line work and service alteration can be found here.
What seems crazy is that they are providing shuttle bus service between Roosevelt and 35/IIT-Bronzeville when those customers could easily just transfer to the rerouted Red Line and ride to 35th. You could do a much shorter bus shuttle between the 35th Red and GReen Line stations with less buses.
But that's what they have been consistently providing. Maybe the theory is that someone from 63rd wants to get to somewhere further north or then west on the Green Line.
That still doesn't change the point of the transfer at 35th to a shuttle service. Though the Roosevelt to 35th/IIT= Bronzeville has been consistent over weekends, a rare opportunity to lessen the shuttles and be more cost effective exists this weekend because the Red Line trains are being rerouted over the Loop elevated southbound. However, I suppose NB travelers would have a hike walking from the subway station up to the elevated platform at Roosevelt even with escalators in place/
Maybe someone figured no sense confusing the passengers worse than they already were.
1/23/15 1:15p
Upcoming Rail Alert For 1/23/15 @ 10p until 1/25/15 @ 6a
Level Of Service Interruption: Service Disruption w/Reroute
Information: 95th-bound trains are rerouted to the elevated tracks between Fullerton and Cermak-Chinatown.
North/Clybourn, Clark/Division, Chicago and Grand stations:
  • Service From these stations: Take a Howard-bound train to Fullerton and transfer to a 95th-bound train.
  • Service To these stations: Take a 95th-bound train to State/Lake and transfer to a Howard-bound train(State St. Subway).
Downtown:
  • Board/Exit 95th-bound trains at any Lake or Wabash Loop Elevated stations.
Roosevelt Station:
  • Board/Exit 95th-bound trains on Green/Orange Elevated platform.
This is due to maintenance in the State Street Subway and improvements at the Clark/Division station.
1/23/15 1:29p
Upcoming Alert For 1/24/15 @ 1:40a until 1/26/15 @ 4a
1/25/15 3:17a
Upcoming Rail Alert For 1/25/15 @ 6a until 6p
1/26/15 2:14a
Information: Loop-bound trains have been rerouted via the Inner Loop tracks due to track switching problems.
  • After Merchandise Mart, the first stop for Brown Line trains will be Clark/Lake(Blue).
