Sam92 Posted October 15 Report Posted October 15 22 minutes ago, Bus1807 said: Ok then maybe I didn't ride #6515 on the 103 because I think #6515 was assigned to 77th. It might be possible with all the loaning they used to do. I remember catching a Nova on 95E and 14 as loans. Quote
Bus1807 Posted October 15 Report Posted October 15 Just now, Sam92 said: It might be possible with all the loaning they used to do. I remember catching a Nova on 95E and 14 as loans. True, what I DO remember is that I definitely rode a #6500 series on the 103. Quote
Bus1807 Posted October 15 Report Posted October 15 #1423 has done only ONE trip on the 93 before going OOS. Is this a school trip or not because it had block id 93. Quote
Bus1883 Posted October 15 Report Posted October 15 6 hours ago, Sam92 said: You rung a bell about that 6440.... Is that an archer nova that got sent to 74th or 77th cause I kinda remember seeing that back in HS. I know for sure the all the weird signs were out south like 6518, 6515 and 1249 (ironically running Run #1249 on 95E) 6440 was at 77th probably stayed at Archer. Archer had 6500s and 6600s before it closed then they went were sent to 74th, 77th and Chicago Quote
Bus1883 Posted October 15 Report Posted October 15 4 hours ago, Bus1807 said: True, what I DO remember is that I definitely rode a #6500 series on the 103. Caught my first option 3 bus on that same route when I was little, it was a high #17XX or 1800-series. During the option 3 and 4 deliveries, the evens were at 103rd while the odds were at North Park during the deliveries. They pretty much had every thing, 1000s, 1200s, 1400s, 1500s, 1600s, 1700s, 1800s and 1900s, a few 1930s were also assigned to 103rd when they first arrived. #1730 thru 1760 went to 74th to which was all 6000s. Chicago and 77th has had the high numbered Allison’s from 1980-2029, mentioned on here as well from 17 years ago if I’m correct. Quote
Bus1807 Posted October 15 Report Posted October 15 2 hours ago, Bus1883 said: Caught my first option 3 bus on that same route when I was little, it was a high #17XX or 1800-series. During the option 3 and 4 deliveries, the evens were at 103rd while the odds were at North Park during the deliveries. They pretty much had every thing, 1000s, 1200s, 1400s, 1500s, 1600s, 1700s, 1800s and 1900s, a few 1930s were also assigned to 103rd when they first arrived. #1730 thru 1760 went to 74th to which was all 6000s. Chicago and 77th has had the high numbered Allison’s from 1980-2029, mentioned on here as well from 17 years ago if I’m correct. Yesss I remember that! I remember riding #1936 on the 4 Quote
Bus1807 Posted October 16 Report Posted October 16 I heard #1405 got in an accident. Can someone confirm and/or send a picture so I can see how bad the damage is? Quote
Mr.NewFlyer1279 Posted October 16 Report Posted October 16 40 minutes ago, Bus1807 said: I heard #1405 got in an accident. Can someone confirm and/or send a picture so I can see how bad the damage is? 1 Quote
Bus1807 Posted October 16 Report Posted October 16 6 minutes ago, Mr.NewFlyer1279 said: Damnnnn it got rear ended? Quote
Busjack Posted October 16 Report Posted October 16 15 minutes ago, Bus1807 said: Damnnnn it got rear ended? Looks like a fire (compare to the video of 8660). Quote
Bus1807 Posted October 16 Report Posted October 16 4 minutes ago, Busjack said: Looks like a fire (compare to the video of 8660). Yeah true, engine looks pretty black/burnt Quote
Mr.NewFlyer1279 Posted October 16 Report Posted October 16 1 hour ago, Busjack said: Looks like a fire (compare to the video of 8660). no it got crashed into 1 Quote
Bus1807 Posted October 16 Report Posted October 16 (edited) 1 hour ago, Mr.NewFlyer1279 said: no it got crashed into Is it fixable? Looks like it damaged the engine badly. Edited October 16 by Bus1807 Quote
Bus1517 Posted October 17 Report Posted October 17 7 hours ago, Bus1807 said: Is it fixable? Looks like it damaged the engine badly. Probably not, @Mr.NewFlyer1279can give you the final answer since idk if im correct or not. Quote
Bus1807 Posted October 17 Report Posted October 17 12 minutes ago, Bus1517 said: Probably not, @Mr.NewFlyer1279can give you the final answer since idk if im correct or not. Alright. Quote
Mr.NewFlyer1279 Posted October 17 Report Posted October 17 7 hours ago, Bus1807 said: Is it fixable? Looks like it damaged the engine badly. it’ll eventually get fixed, should be on litigation hold or smth lemme page @YoungBusLover Quote
Bus1807 Posted October 17 Report Posted October 17 1 minute ago, Mr.NewFlyer1279 said: it’ll eventually get fixed, should be on litigation hold or smth lemme page @YoungBusLover That means they might have to part out a retired flyer to fix #1405. Quote
Busjack Posted October 17 Report Posted October 17 14 minutes ago, Bus1807 said: That means they might have to part out a retired flyer to fix #1405. At some point (here 19 years old), it isn't worth it. If, as it looks, the engine is toast, the only source of a comparable engine is an option 1 or 2 bus. Along with the "lightweight" bodies, the option 3 and 4 buses have smaller engines ( @sw4400 kept track, but I didn't). There was a debate about cannibalizing, but the only way to part out would be if there is some bus that is wrecked, but not as wrecked in the rear. Quote
Bus1807 Posted October 17 Report Posted October 17 1 hour ago, Busjack said: At some point (here 19 years old), it isn't worth it. If, as it looks, the engine is toast, the only source of a comparable engine is an option 1 or 2 bus. Along with the "lightweight" bodies, the option 3 and 4 buses have smaller engines ( @sw4400 kept track, but I didn't). There was a debate about cannibalizing, but the only way to part out would be if there is some bus that is wrecked, but not as wrecked in the rear. Yeah you do have a point. Maybe they might do the same thing with #1405 as they did with #1305. But #1305 had a bad engine fire and it’s pretty much gutted for parts. #1405 actually has potential in getting fixed. Quote
Bus1883 Posted October 18 Report Posted October 18 On 10/16/2026 at 12:03 PM, Bus1807 said: Is it fixable? Looks like it damaged the engine badly. If the frame and engine isn’t damaged internally it should be fine Quote
Bus1883 Posted October 18 Report Posted October 18 22 hours ago, Bus1807 said: What happened to #1509 and #1596? Both are retired Quote
Bus1883 Posted October 18 Report Posted October 18 On 10/16/2026 at 8:54 PM, Bus1807 said: Yeah you do have a point. Maybe they might do the same thing with #1405 as they did with #1305. But #1305 had a bad engine fire and it’s pretty much gutted for parts. #1405 actually has potential in getting fixed. That bus is a shell 1 Quote
Bus1807 Posted October 18 Report Posted October 18 7 minutes ago, Bus1883 said: Both are retired Any reason why? Quote
YoungBusLover Posted October 18 Report Posted October 18 22 hours ago, Bus1807 said: What happened to #1509 and #1596? Frame damage on #1509 along with rust, #1596 was retired mid repair for routine maintanence at SS. Quote
