  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 months later...
The LED signs are proliferating nowadays! I just got into chicago from dekalb, and it seems like the signs are appearing out of nowhere on the 6000's...
...I'm still assuming that 74th is getting the sign changes for now?
  • 3 months later...
Interestingly, the re-signed buses I've seen heading eastbound on Foster have had their signs reprogrammed to read "TO RED LINE" instead of "BERWYN RED L." Westbound buses still read "JEFF/BLUE LINE."
WHEN WILL THE 103rd 6000's GET THE LED SIGNS?! BECAUSE ALL I SEE IS THOSE BUSES WITH FLIP DOT SIGNS IN THE FRONT,BACK AND SIDE!
6000's are starting to appear at the 103st garage with new destination signs and logos.#28 has at least 2 of these buses with the new logo. Also I saw a Flxible today with the new destination sign(finally!!). the number was 6263. The interior was different than the others. The normal flxibles(on the interior)has 2 seats  on the left side of the bus, and on the right is only 1 seat per row. On the this bus it had 2 seats per row on both sides! Has anyone else noticed this change? im not sure if the bus had the new logo :( . The route was once again #9.
I remeber seeing one on route 28. I seen the other one on the same route. I didnt see there numbers, so they might be the same one. I assume that Bus Repairman knows about these buses. Since he does work at the 103st garage.
