CTA Rail Service Alerts
sw4400
4/18/14 12:56a
Upcoming Rail Alert for 4/18/14 @ 10p until 4/21/14 @ 4a
Rail Line(s) Affected: Orange
Level Of Service Interruption: Service Disrupted w/Alternate Service Available
Information: Trains operate between Midway and Halsted only,
Alternate Service: Shuttle Buses will provide service between Halsted and Roosevelt. A Orange Line Shuttle Train will operate between Roosevelt and the Loop Elevated, making stops at the Orange Line platform at Loop 'L' stations to provide connections between the Shuttle Buses and the Loop stations. Red or Green Line trains can also be used between Roosevelt and Downtown.
Rail Shuttle Transfers: Free transfer between Shuttle Buses and Rail Service is only available at Halsted and Roosevelt, and requires the farecard you used at the start of your trip.
This is due to structural and track improvements on the 18th St. Connector to improve rail service along the Orange Line.
4/19/14 1:02a
Upcoming Rail Alert for 4/19/14 @ 6a until 6p
Rail Line(s) Affected: Blue
Information: Trains in both directions will operate on the same track between Oak Park and Cicero. Board/Exit all trains on the Forest Park-bound side of the platform at Austin.
This is due to track maintenance to ensure that trains continue to operate safely along the Blue Line.
4/19/14 1:10a
Special Rail Alert Bulletin Effective 4/19/14 until 10/31/14
Rail Line(s) Affected: Brown, Green, Pink
Level Of Service Interruption: Varying Degrees Of Interruption
Information: During the Spring and Summer seasons, the bridges along the Chicago River open periodically to allow boats to pass. Bridge lifts typically occur late morning to early afternoon on Wednesdays and Saturdays, but may occur on other days and times as requested by the City Of Chicago. When bridge openings are scheduled, service on the Brown, Green and Pink Line service will be impacted. The level of impact depends upon the length of time the bridge is opened. Typically a bridge lift lasts about 5-10 minutes and will usually result in Minor Delays to rail service along affected route(s). If a bridge lift lasts longer than 10 minutes, service could see Significant Delays or Major Delays. During these delays, Alternate Service via nearby Bus Routes will be provided, and Bus Shuttles may also be implemented depending upon length of delay.
4/19/14 1:10a
Brace yourselves. They're coming...
4/21/14 12:52a
Construction Alert For 4/21/14 @ 10:50a until 2:45p
Rail Line(s) Affected: Red
Level Of Service Interruption: --
Information: Howard-bound trains will not stop at Addison.
  • Service to Addison: Take a Howard-bound train to Sheridan and transfer to a 95th-bound train
  • Service from Addison: Take a 95th-bound train to Belmont and transfer to a Howard-bound train
This is due to track maintenance to ensure that trains continue to operate safely along the Red Line
4/21/14 12:54a
Construction Alert For 4/21/14 @ 9:05a until 2:25p
Rail Line(s) Affected: Green
Information: Harlem/Lake-bound trains will not stop at Indiana.
  • Service to Indiana: Take a Harlem/Lake-bound train to 35th-Bronzeville-IIT and transfer to a 63rd-bound train
  • Service from Indiana: Take a 63rd-bound train to 43rd and transfer to a Harlem/Lake-bound train
This is due to platform improvements to the Indiana station.
4/22/14 1:12a
Construction Alert For 4/22/14 @ 10:50a until 2:45p
4/22/14 1:13a
Construction Alert For 4/22/14 @ 9:05a until 2:25p
4/22/14 9:14p
Construction Alert For 4/23/14 @ 9:05a until 2:25p
4/24/14 12:05a
Construction Alert For 4/24/14 @ 9:05a until 2:25p
4/24/14 11:54p
Construction Alert For 4/25/14 @ 10:50a until 2:45p
4/24/14 11:56p
Construction Alert For 4/25/14 @ 9:05a until 2:25p
4/24/14 11:59p
Upcoming Alert For 4/25/14 @ 10p until 4/28/14 @ 4a
Information: Trains operate between O-Hare and Western(O-Hare Branch), Damen, Downtown(Dearborn St. Subway) and Forest Park.
Alternate Service: Shuttle Buses will replace rail service between Damen and Western(O-Hare Branch). The Bus Shuttle will run between Clark/Lake and Western, making stops at all intermediate rail stations. Passengers requiring an accessible transfer between bus and rail, or with luggage or strollers, or otherwise desire the use of an elevator, should use the Shuttle Bus between Western and Clark/Lake. Free Transfer between Shuttle Buses and rail service is only available at Western, Damen and Clark/Lake, and requires the farecard used to pay your fare at the start of your trip.
This is due to track improvements to eliminate slow zones and improve rail service along the Blue Line.
4/25/14 9:12p
Upcoming Rail Alert for 4/26/14 @ 6a until 6:30p
Information: Trains in both directions will operate on the same track between Sedgwick and Fullerton. Board/Exit all trains on the Kimball-bound platform at Armitage.
This is due to structural improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project.
4/27/14 12:43a
Upcoming Alert for 4/27/14 @ 6a until 6p
Information: Howard-bound trains will not stop at Morse and Jarvis.
  • Service from Morse and Jarvis: Take a 95th-bound train to Loyola and transfer to a Howard-bound train.
  • Service to Morse and Jarvis: Take a Howard-bound train to Howard and transfer to a 95th-bound train.
This is due to track maintenance to ensure that trains continue to operate safely along the Red Line.
4/27/14 12:50a
Upcoming Rail Alert for 4/27/14 @ 5a until 12p
Information: Trains in both directions will operate on the same track between Sedgwick and Fullerton. Board/Exit all trains on the Loop-bound platform at Armitage.
4/27/14 12:51a
Upcoming Rail Alert for 4/27/14 @ 12p until 7p
4/28/14 12:03a
Construction Alert For 4/28/14 @ 10:50a until 2:45p
4/28/14 12:04a
Construction Alert For 4/28/14 @ 9:05a until 2:25p
4/29/14 1:11a
Construction Alert For 4/29/14 @ 10:50a until 2:45p
4/29/14 1:11a
Construction Alert For 4/29/14 @ 9:05a until 2:25p
Power outage at logan square blue line station service is getting through but the station on the kedzie side is pitch black with just a few emergency lights. They put glow sticks on the escalators and set up a spot light at the end of the platform shining on the stairs.Truck 276 just rolled up with a generator. This is going to be interesting after sunset!!
Power has just been restored. 7:32pm alarms are going off probably on the ventra machine.
4/29/14 9:17p
Construction Alert For 4/30/14 @ 10:50a until 2:45p
