Metra has been delivering the locomotives that will be used in future service: https://metra.com/newsroom/new-metra-locomotive-debuts
According to the Trains article (https://www.trains.com/trn/news-reviews/news-wire/news-photo-another-metra-sd70mach-delivered/), the fourth unit of the SD70MACH, METX #505, has been delivered on May 11, 2023.
METX #500 is going to be a heritage livery, in commemoration of the upcoming RTA's 50th anniversary.
Let's get this discussion rolling!
506 on the way to chicago, probably already interchanged to metra
Chicago Metra SD70MACH #506, Mortons Gap,KY 5/25/2023
From pics I've seen 500, 502, 503, 505 and now 506 are on metra property, pretty much every day you can see a few of them sitting at the north end of the bnsf 14th st yard so its fair to assume their all intended for the bnsf.
  • 4 months later...
Metra needs a new revenue line.  The rebuilts SD70s would look cool on excursion trains to Ill Rail museum.   They have the Rockford project it os possible.   Metra can get into running more excursion trains. They have experience with steam trains, take over Polar express operationa from Amtrak, bring back the bar cars/parlor cars, use off peak parties to downtown, bacholor parties, wedings, etc.  Why have pub crawls when you can have it on the train
Only tangentially related to this topic, and not only is Metra not in that business, I doubt that it would be allowed to enter that line of business.
15 hours ago, Railguy said:
Metra needs a new revenue line.  The rebuilts SD70s would look cool on excursion trains to Ill Rail museum.   They have the Rockford project it os possible.   Metra can get into running more excursion trains. They have experience with steam trains, take over Polar express operations from Amtrak, bring back the bar cars/parlor cars, use off peak parties to downtown, bachelor parties, weddings, etc.  Why have pub crawls when you can have it on the train
I would love to see Metra running trains directly to the Rail Museum on weekends.
Metra has operated charter trains including steam and the state has awarded them service to Rockford.  Anything is on the table.  My point was jest as to putting  these SD70s to some use
Their use is to haul commuter cars. YouTubers have video of them on the MD-N and MD-W.
You think Metra bought 15 locos just to mothball them?
Not intentionally.  Metra bought the wrong type of equipment for regional service including old frieght engines and the new cars on order.  Sure they ran in service doesnt mean its the best use of equipment.  Will they run the fate as airbus A380 or long Island RR  engines which were mothballed or the electric engines Amtrak retires based on the Acela.   It happens in the industry. Doubtful Metra will exercise the contract options
On what authority are you making these assertions? The general search indicates there are several now in revenue service.
Yours just seems the usual response here that EVERYTHING is junk until it has run for 20 years.
My comments have nothing to do with age of equipment , even if these SD70s' were delivered fresh off the assembly line.
These engines are for long express trains with limited stops.  Not condusive to multiple stop reggional network.  I would speculate Metra placed order pre pandemic based on serving the downtown rush commute.  Then the bottom fell out.
Of course Metra will spin this on positive light and make the best of it.  Sure they will be in service, they are rebuilt engines and are an asset to use.
For regional rail they need a new train  consist for the higher frequency segments and not  current locomotive hauled cars.  These can remaim in tje longer rush express markets.   Im basing this on looking at the ideas from midwest high speed rail association, CMAP PART section on regional rail and Metra strategic plan
I'm not an expert per se, but I think your analysis is off.  Yes, engines are built for ling distance use, but they aren't LIMITED to that use.  Here's an analogy.   MCI  Prevost,  VanHool build buses and they get engines that can handle ling distance touring and travel and intercity runs.  But most operators who purchase them use those buses for lune runs. Commuter services, local charters, etc .  That's not a misuse if the equipment.   Similarly, using engines or locomotives from Amtrak or freight railroads to run Metra service is not misuse of equipment.   In fact, I believe its the BEST USE for the equipment.   As this type of equipment ages it's best to restrict the range to better maintain the equipment.   If you go back to my bus analogy,  charter companies and even Greyhound runs the newest equipment across the country,  but keeps its oldest equipment local or regional.
Your Airbus 380 analogy was off because that's a niche plane that works well for certain carriers.  Even the carriers that had decided to retire them are bringing them back because they fill a need.
The point is that using this refurbished equipment is financially affordable,  efficient,  and reliable until Metra can splurge on new locomotives.
I agree with @artthouwill, but for different reasons.
PART is a joke, in the sense of equipment deployment, because Metra is never going to be able to afford to build yards for smaller coaches where the diesel lines now short turn trains: UPN: Highland Park or Winnetka; MD-N Lake Forest (formerly Deerfield), UP-NW Des Plaines, BNSF Fairview Ave. or Brookfield. It also seems ill-conceived that there would be more traffic between, say, Fox Lake and Lake-Cook, when the latter office corridor is much more decimated than the Loop. Hence, if there is any need for smaller coaches, it would be on the outer ends  of the system.  Since the MACHs appear operational on routes such as MD-N (unless a whole bunch of YouTubers have conspired to doctor the videos), that seems good enough. They just better not sound their horns outside my window.
Metra is acknowledging regional rail by:
  • the Feb. 2024 fare system.
  • The proposal for battery trainsets for the RI, which is about the only diesel line that has characteristics that may conform to the pattern.
Besides that, you seem to be arguing all over the place for a futile cause, from that they should be used only for excursions on a track that won't be in serviceable condition until 2028, to saying they are/were freight locomotives, to comparing them to doomed aircraft, to this PART fallacy. If you are saying they are not going to last as long a the 35-45 year old F40s, I don't think diesel power is going to last much more than another 15 years, anyway.
On 10/31/2023 at 4:55 PM, Railguy said:
On a positive note they do look really cool!  How useful a 3 axle truck locomotives are  in commuter service remains to be seen.    It's wait and see time.
While they are six axle, only four are powered. Both end axles are idlers (1B-B1). More dictated by available cores than anything else. 4 axle cores are getting hard to come by.
  • 6 months later...
  • 1 year later...
  • 3 months later...
