#1892 is rehabbed on the #72. #1775 is rehabbed on the #49. #1135 on the #49 and #1614 on the #9 has the clever devices in the new position.
#1727 has been released from south shops on the #47.
Buses released from South Shop:
North Park
#1782 while on #148
#1881 while on #151
Chicago
n/a
Kedzie
#1359 is rehabbed while on #126
#1662 is rehabbed while on #157
74th
#1115 and #1122 while on #9
#1121 while on #44
#1727 is rehabbed while on #59
#1730 is rehabbed while on #63
77th
#1071 has been reactivated from OOS while on #53A
#1473 has been specially rehabbed while on #43
#1958 while on #2
103rd
#1018 is rehabbed while on #71
#1019 is rehabbed while on #112
#1031 (Needs verification whether it's fully rehabbed or still mechanically rehabbed) while on #15
#1111 (Needs verification whether it's fully rehabbed or still mechanically rehabbed) #1816 while on #108
#1810 while on 95W
North Park
#1782 while on #148
#1881 while on #151
Chicago
n/a
Kedzie
74th
#1121 while on #44
77th
#1958 while on #2
103rd
#1810 while on 95W
Wow you learned all that today??? Looks like I have some catching up to do.
Shots of rehabbed #1680 and #1712. It's really a mess out there with all this construction going on.
hey Garmon #1680 is not rehabbed on the #21. It's not wrapped either. I don't know what bus that is. Also #1662 is not rehabbed on the #157. I've been aboard both buses so that's 100 percent correct. #1359 is rehabbed for sure on the #82 as I was tied up with it during the logan mishap this afternoon.
Yeah I was about to correct myself about #1680 because I saw it while I was on my way to Mercy Hospital. I'm guessing #1353 with the wrap. Also, i have to figure out which bus 1X62 was getting rehabbed since you helped me point out that it wasn't #1662.
Let's see if we can narrow down options via new member byroncheng's Individual Bus Tracker(I would name it Bus Finder or Bus Locater) and your list of rehabs.
Here goes....
  • 1062(Your rehab roster doesn't show 1062 as awaiting rehab, so it must be rehabbed)
  • 1162(Possibility. This bus does not appear to be rehabbed in your roster)
  • 1262(Your roster shows this bus mechanically rehabbed. Low possibility this bus is in South Shops currently)
  • 1362(Possibility. This bus does not appear to be rehabbed in your roster)
  • 1462(Ruled Out: Operating #20)
  • 1562(Ruled Out: Operating #75)
  • 1662(Ruled Out: Operating #157)
  • 1762(Ruled Out: Operating #22)
  • 1862(Possibility. This bus does not appear to be rehabbed in your roster)
  • 1962(Ruled Out: Operating #73)
So, these are your three high probability buses.... 1162,1362 & 1862, with 1262 a low possibility.
#1665 is rehabbed on the #126. #1389 is rehabbed on the #136 #1122 is rehabbed on the #9. #1211 is rehabbed on the #52. Both #1211 and #1611 have their clever devices in the new position.
#2008 is not rehabbed on the #73. #1121 on the #9 is notrehabbed either but it looks like they put LEd lights on the stairs in back. It's the brightest part of the whole bus.
#1290 is rehabbed on the #74. #1084 is rehabbed on the #8 and the bus is wrapped that purple wrap (same one as Garmon showed on the #12 of the mystery bus) for domestic violence. #1980 is rehabbed on the #8. #1786 has finally showed up on the #36.
