Pace Bus Moves
pace2322
1 hour ago, rotjohns said:
I'm sure more will be moving later this year though, potentially to eliminate the last of the 30-footers.
I assume you mean at SW, but that just means more at R. The 30 ft buses won't be eliminated until the 35' hybrids come in (if even then).
I wasn't aware of this, but 6569 is at NW, currently on 290.  Wonder how long that bus has been there?
I’m pretty sure 6569 has been at NW all its life. It’s normally a pulse bus but they run pulse buses on everything at NW
Yes. 6566-6575 have been NW buses since the beginning. 6564 and 6565 were NS but are NW.
6560/1 started out at R, moved to W and then NW in 12/21
6562/3 started out at R, moved to W, then N and finally NW in 12/21
6564/5 moved to NW from NS in 8/22
6566-6572 were new at NW in 1/17,
6573/4 may have also been at SW moving to NW in 9/17.
6575 was first allocated to SW but has not been on tracker since before 6/2022. I have never seen it at NW.
Oh ok, I don't know why I was thinking 6569 was at SW previously.  So SW has less 6500s than I was thinking, especially with the mixture of some 2600 series El Dorados still there.
SW had 6522 up, but R got about 5 for 606, then, as mentioned above, NS and NW, although    @busfan2847 indicated the last couple at SW. SW"s Eldos were stimulus  buses' some directly and others for 895.
