ajay Posted January 29, 2019 Report Share Posted January 29, 2019 Hello. I want to find what app or websites that i can use. I mean like CTA Map what i can find what Coach number. Like 6629. Can you give me any any or website? Quote Link to comment Share on other sites More sharing options...
Erin Mishkin Jr. Posted January 30, 2019 Report Share Posted January 30, 2019 I have a map that you can use. http://tmweb.pacebus.com/TMWebWatch/MultiRoute Quote Link to comment Share on other sites More sharing options...
ajay Posted January 30, 2019 Author Report Share Posted January 30, 2019 6 hours ago, Erin Mishkin Jr. said: I have a map that you can use. http://tmweb.pacebus.com/TMWebWatch/MultiRoute Thanks. Quote Link to comment Share on other sites More sharing options...
Erin Mishkin Jr. Posted January 30, 2019 Report Share Posted January 30, 2019 You're welcome. Quote Link to comment Share on other sites More sharing options...
rotjohns Posted November 1, 2021 Report Share Posted November 1, 2021 The tracker is acting a little wonky so far this morning. Route 208 isn't showing any bus numbers listed, but it will show the arrival/departure times. Same with other routes. Quote Link to comment Share on other sites More sharing options...
andrethebusman Posted November 17, 2021 Report Share Posted November 17, 2021 Ever notice on the Pace interactive map if you click on a route one of the details it gives you is date the route started? Neat detail that Pace has kept up since 1975! 1 Quote Link to comment Share on other sites More sharing options...
Erin Mishkin Jr. Posted December 24, 2021 Report Share Posted December 24, 2021 Bus tracker won’t show buses on map and labels all buses as “scheduled” on departure times 1 Quote Link to comment Share on other sites More sharing options...
artthouwill Posted July 13, 2022 Report Share Posted July 13, 2022 2 hours ago, mary fahey said: I would like to know why Pace 381 has so many ghost busses? People have appointments and need to go to work. The app is never correct. Have you thought about putting the real time on the app instead of having people stand on the corner for a half hour or more. This is extreme;y frustrating especially in very hot or cold days. This is a better thread for your question. I'm not exactly sure what app you use to track Pace buses. On my Ventra App, it lists the estimated arrival times for the routes nearest me, be it CTA or Pace. Even so, there are times when buses are supposed to arrive and don't. Then there are the ghost buses. My recommendation is to download the 381 schedule. When you are ready to travel, check the Ventra App or whatever you use to track that particular bus. You can also call SW Division at the Lost and Found number on the schedule. Quote Link to comment Share on other sites More sharing options...
Busjack Posted July 13, 2022 Report Share Posted July 13, 2022 22 hours ago, mary fahey said: I would like to know why Pace 381 has so many ghost busses? People have appointments and need to go to work. The app is never correct. Have you thought about putting the real time on the app instead of having people stand on the corner for a half hour or more. This is extreme;y frustrating especially in very hot or cold days. In addition to what @artthouwill said, it isn't clear to me what your complaint is. The term "ghost bus," as used in this forum, means a bus on the route that does not register on the tracker, but it seems like you are complaining about buses that are not on the road at all. The version with bus times basically just use estimates or scheduled times. I usually use a map, which indicates that there is only one bus in the middle of the route. That would indicate to me that at least the buses are bunched, or one of the two problems I noted above occurred. But if I were waiting for a bus at Cicero, I would stay inside until the bus was at Central. I would contact Pace customer service if you think the route doesn't have enough buses to maintain the 20-minute interval. Quote Link to comment Share on other sites More sharing options...
MetroShadow Posted July 15, 2022 Report Share Posted July 15, 2022 Ghost buses in your case @mary faheyaren't applicable. They're missed trips that should've been wiped from the arrival boards and bus tracker Service delivery is only as good as available drivers on hand; and if the last 850 days have dictated nationwide, very few agencies are at full strength. Hopefully that'll change soon. Quote Link to comment Share on other sites More sharing options...
Busjack Posted July 15, 2022 Report Share Posted July 15, 2022 13 minutes ago, MetroShadow said: Ghost buses in your case @mary faheyaren't applicable. They're missed trips that should've been wiped from the arrival boards and bus tracker Service delivery is only as good as available drivers on hand; and if the last 850 days have dictated nationwide, very few agencies are at full strength. Hopefully that'll change soon. Undoubtedly the case. My analysis of the schedule at the time I posted was a minimum of 5 buses, not counting layovers, and only 4 buses with 3 at or near the terminals doesn't hack it. Quote Link to comment Share on other sites More sharing options...
Busjack Posted July 15, 2022 Report Share Posted July 15, 2022 16 hours ago, Busjack said: Undoubtedly the case. My analysis of the schedule at the time I posted was a minimum of 5 buses, not counting layovers, and only 4 buses with 3 at or near the terminals doesn't hack it. Intuition was correct. Webwatch now shows 6 buses. Quote Link to comment Share on other sites More sharing options...
Busjack Posted November 26, 2023 Report Share Posted November 26, 2023 Speaking on whether Pace Bus Tracker shows ghost buses, here's a converse I hadn't seen before: Quote Link to comment Share on other sites More sharing options...
Busjack Posted February 14 Report Share Posted February 14 29 minutes ago, Erin Mishkin Jr. said: 2685 was first used on 5/20/24. Did you not use the Load More button on the history? Yes I did, but since you implied the problem was on my end, I used Chrome after Firefox. It did not come up on Firefox, did come up on Chrome. Strange! Quote Link to comment Share on other sites More sharing options...
Erin Mishkin Jr. Posted February 14 Report Share Posted February 14 1 hour ago, Busjack said: Yes I did, but since you implied the problem was on my end, I used Chrome after Firefox. It did not come up on Firefox, did come up on Chrome. Strange! Interesting. I thought it worked on All browsers but I don’t usually use Firefox. Quote Link to comment Share on other sites More sharing options...
busfan2847 Posted February 14 Report Share Posted February 14 59 minutes ago, Erin Mishkin Jr. said: Interesting. I thought it worked on All browsers but I don’t usually use Firefox. It works on Firefox for me! Quote Link to comment Share on other sites More sharing options...
Erin Mishkin Jr. Posted February 14 Report Share Posted February 14 31 minutes ago, busfan2847 said: It works on Firefox for me! Ohh ok maybe it either depends on the device used or maybe he didn’t see it. Quote Link to comment Share on other sites More sharing options...
Busjack Posted February 14 Report Share Posted February 14 1 hour ago, Erin Mishkin Jr. said: Ohh ok maybe it either depends on the device used or maybe he didn’t see it. I'm using a Win 11 laptop. This morning, just had the button reappear; now all I get is a spinner. Comparable in Chrome (after brief spinner): Quote Link to comment Share on other sites More sharing options...
Erin Mishkin Jr. Posted February 14 Report Share Posted February 14 37 minutes ago, Busjack said: I'm using a Win 11 laptop. This morning, just had the button reappear; now all I get is a spinner. Comparable in Chrome (after brief spinner): That’s interesting…It happens for me when my network is low but sometimes after clicking search a few times it seems to work better. Quote Link to comment Share on other sites More sharing options...
