andrethebusman Posted March 19, 2014 Report Posted March 19, 2014 5800-5864 New Flyer dispositions (5800-5801 were repowered with Cummins engines after delivery) 5820, 5826, 5858 to Chicago Fire Dept. One fully repainted, lettered "8-8-12". Status of other two unknown, but at least two were used, as two were seen together at Soldier Field 5816 still stored as of early 2013, no further disposition data known 5858 to CFD shop # FDS133, assignment 8-8-11 NEW5800.txt Quote
andrethebusman Posted April 12, 2014 Author Report Posted April 12, 2014 This is what I can decipher as far as what CFD did with the three 5800's. 5858 is FDS133, I assume this is the 8-8-11 located at Fillmore & California. There is another one, FDS number unknown, located at Woodlawn & 55th as 8-8-12. The third is assigned to the Fire Academy as 2-9-1, replacing the 5307 that was assigned to 2-9-1. If anybody sees any of these buses, try to get the FDS number (6 digits in about 2-inch high numbers on front and rear) so I can get my roster straightened out! Thanks Andre Quote
sw4400 Posted April 12, 2014 Report Posted April 12, 2014 5800-5864 New Flyer dispositions (5800-5801 were repowered with Cummins engines after delivery) You're missing 5862-5864. These buses were powered with Cummins engines as well(more of a Nova Bus idle, smaller tailpipe w/ a cover similar to the 6000-Series Flxibles). I don't recall 5800 and 5801, but I'm not going to say they were or weren't, as I always remember them having the Detroit Series-50. After midlife rehabs, 5862-5864 had the stock Detroit Series-50 installed. Quote
Guest Posted April 14, 2014 Report Posted April 14, 2014 5800-5864 New Flyer dispositions (5800-5801 were repowered with Cummins engines after delivery) 5820, 5826, 5858 to Chicago Fire Dept. One fully repainted, lettered "8-8-12". Status of other two unknown, but at least two were used, as two were seen together at Soldier Field 5816 still stored as of early 2013, no further disposition data known 5858 to CFD shop # FDS133, assignment 8-8-11 CFD bus #5826 is assigned to the fire academy. Along with the Flxible Metro. Quote
andrethebusman Posted April 15, 2014 Author Report Posted April 15, 2014 CFD bus #5826 is assigned to the fire academy. Along with the Flxible Metro. Any chance of getting shop numbers for these two? The 8-8-12 at 55/Woodlawn is a Bluebird (?) rear-engine in full red-black. Quote
andrethebusman Posted April 19, 2014 Author Report Posted April 19, 2014 CFD bus #5826 is assigned to the fire academy. Along with the Flxible Metro.Info is that the Cooling Bus at Academy (2-9-0) is FDS134. RTS is 2-9-1, FDS-062 Quote
Guest Posted April 19, 2014 Report Posted April 19, 2014 Info is that the Cooling Bus at Academy (2-9-0) is FDS134. RTS is 2-9-1, FDS-062 That is correct! Quote
andrethebusman Posted April 20, 2014 Author Report Posted April 20, 2014 So what did CFD do with 5820?? Quote
Guest Posted May 15, 2014 Report Posted May 15, 2014 I found out today one of the CFD New Flyers I believe FDS134, will be trashed. It will cost more than three grand to fix it up. So it was decided to get rid of it instead. Currently the bus sits at the city repair shops at North/Throop. Quote
andrethebusman Posted May 16, 2014 Author Report Posted May 16, 2014 I found out today one of the CFD New Flyers I believe FDS134, will be trashed. It will cost more than three grand to fix it up. So it was decided to get rid of it instead. Currently the bus sits at the city repair shops at North/Throop.Scrap over a three grand repair bill? That's ludicrous! If they can peddle a DOA Flx for $4100, $3000 should be nothing. They just don't want to deal with it for some other reason. Quote
sw4400 Posted May 16, 2014 Report Posted May 16, 2014 Scrap over a three grand repair bill? That's ludicrous! If they can peddle a DOA Flx for $4100, $3000 should be nothing. They just don't want to deal with it for some other reason. It's a 20 year old bus, and a bill of $3,000 to get it repaired sounds like something major mechanically is bad on the bus like the tranny. These buses also had a habit of being squealers(drive belts, perhaps?). The cost of the repair alone is probably more than the bus is worth now(20 years old w/ probably close to or over 1,000,000 miles on it) But look at it this way, andre.... you have in the next 1 & 1/2 to 2 years 484 Nova LFS buses retiring. No doubt some will have a second, non-revenue life doing various things(6402 and 6404 are Work Buses now, 6400 is slated to go to Olive Harvey College), perhaps the CFD will buy or receive free of charge a few Novas to be CFD buses. Quote
Guest Posted May 16, 2014 Report Posted May 16, 2014 From what Im told it has a host of problems. Quote
sw4400 Posted May 16, 2014 Report Posted May 16, 2014 From what Im told it has a host of problems. You couldn't even go down there to take pics if you wanted. I used google maps to find it and it's just a little north on Throop off of North Ave., but posted right in front in a sign that says "No Tresspassing. Violators will be prosecuted." and right next to that is a shed which no doubt houses caretakers/guards. I see a lot of spare engines and tower ladder trucks in the lot along with two all white Flxible Metro(6000's) and an all white TMC RTS(stock footage from last year I bet). As far as spare engines/tower ladders, this is what I see in the stock footage: E270(Ladder Truck) Engine Co. 122(Active Fire Engine?) Tower Ladder 61(Active Fire Engine?) E252(this spare unit is still in use. I've seen it in the past subbing for Tower Ladder 21) E248(Tower Ladder Truck) E250(I've seen this spare unit once subbing for Tower Ladder 21. I think both E252 and E250 are 1985 Emergency One Tower Ladders. E248 may be as well) D528(Engine Co. Truck) D547(Engine Co. Truck) Engine Co. 49 E238(Ladder Truck) E269(Ladder Truck) Anyone have info on the other units mentioned here? E270, D528, D547, E238 and E269? Year of build, Manufacturer and Model? CTA5750, I look to you for some insight on these Fire Units. Year, Make, Model & status of them. Maybe even you know their original in-service unit numbers when they were the main units(e.g: D528 was ex-Engine 112) Quote
andrethebusman Posted May 21, 2014 Author Report Posted May 21, 2014 You couldn't even go down there to take pics if you wanted. I used google maps to find it and it's just a little north on Throop off of North Ave., but posted right in front in a sign that says "No Tresspassing. Violators will be prosecuted." and right next to that is a shed which no doubt houses caretakers/guards. I see a lot of spare engines and tower ladder trucks in the lot along with two all white Flxible Metro(6000's) and an all white TMC RTS(stock footage from last year I bet). As far as spare engines/tower ladders, this is what I see in the stock footage:E270(Ladder Truck)Engine Co. 122(Active Fire Engine?)Tower Ladder 61(Active Fire Engine?)E252(this spare unit is still in use. I've seen it in the past subbing for Tower Ladder 21)E248(Tower Ladder Truck)E250(I've seen this spare unit once subbing for Tower Ladder 21. I think both E252 and E250 are 1985 Emergency One Tower Ladders. E248 may be as well)D528(Engine Co. Truck)D547(Engine Co. Truck)Engine Co. 49E238(Ladder Truck)E269(Ladder Truck)Anyone have info on the other units mentioned here? E270, D528, D547, E238 and E269? Year of build, Manufacturer and Model? CTA5750, I look to you for some insight on these Fire Units. Year, Make, Model & status of them. Maybe even you know their original in-service unit numbers when they were the main units(e.g: D528 was ex-Engine 112)D528 is 1992 Luverne new Eng 61, 2001 to Eng 63 to spare 2005D547 is 1995 Luverne new Eng 122, 2002 to Eng 60, 2007 to spareE270 is 1993 Seagrave, new to Truck 53, to spare 2000'sE238 is 1982 Hendrickson/Emergency One new to ?, 1992 to Truck 50, to spare 2000E269 is 1993 Seagrave, new to Truck 57, 2003 to Truck 20, to spare 2000's Quote
andrethebusman Posted May 23, 2014 Author Report Posted May 23, 2014 Which is the NFIL at Throop St? 5820? Quote
dailycommuter62 Posted December 26, 2019 Report Posted December 26, 2019 If someone got a great holiday bonus this year the city is auctioning off one of the CFD bus's (5858), still with full interior https://publicsurplus.com/sms/chicago,il/auction/view?auc=2467477 Quote
Shannon CVPI Posted December 26, 2019 Report Posted December 26, 2019 46 minutes ago, dailycommuter62 said: If someone got a great holiday bonus this year the city is auctioning off one of the CFD bus's (5858), still with full interior https://publicsurplus.com/sms/chicago,il/auction/view?auc=2467477 Nice if I was to bid on a bus I think I would want a flex 5300 or 6000 or a nova 6400's Quote
Mr.NewFlyer1051 Posted December 26, 2019 Report Posted December 26, 2019 1 hour ago, Shannon CVPI said: Nice if I was to bid on a bus I think I would want a flex 5300 or 6000 or a nova 6400's if they end up auctioning a new flyer 1000-2029 i’ll happily buy me one? Quote
Shannon CVPI Posted December 27, 2019 Report Posted December 27, 2019 2 hours ago, Mr.NewFlyer1051 said: if they end up auctioning a new flyer 1000-2029 i’ll happily buy me one? Me too Quote
MTRSP1900-CTA3200 Posted December 27, 2019 Report Posted December 27, 2019 3 hours ago, Shannon CVPI said: Nice if I was to bid on a bus I think I would want a flex 5300 or 6000 or a nova 6400's 2 hours ago, Mr.NewFlyer1051 said: if they end up auctioning a new flyer 1000-2029 i’ll happily buy me one? I jokingly considered buying a used bus for when me and my family go on vacation. Just have our baggage stowed in the raised portion in the rear and everyone riding comfortably towards the front! When Phoenix Sky Harbor International Airport completes their airport train to the rental car center they’re going to phase out their shuttle buses, which would work good for us because they have luggage racks. We leased a 2017 Toyota Highlander that could seat 8, but with 5 of us plus all of our luggage it was a tight squeeze, and the Highlander is not a small car by any means. Even when it was just me my dad and step mom traveling to LA and Phoenix it was like playing Tetris trying to get all the bags in (though we had my brother pick us up to avoid paying for airport parking). Quote
NewFlyerMCI Posted December 27, 2019 Report Posted December 27, 2019 6 hours ago, dailycommuter62 said: If someone got a great holiday bonus this year the city is auctioning off one of the CFD bus's (5858), still with full interior https://publicsurplus.com/sms/chicago,il/auction/view?auc=2467477 Seems like you'd need a tow capable of hauling it, seeing as it has no key or batteries Quote
Shannon CVPI Posted December 27, 2019 Report Posted December 27, 2019 2 minutes ago, NewFlyerMCI said: Seems like you'd need a tow capable of hauling it, seeing as it has no key or batteries They said that they keeping the keys & battery lol Quote
Pace831 Posted December 27, 2019 Report Posted December 27, 2019 6 hours ago, dailycommuter62 said: If someone got a great holiday bonus this year the city is auctioning off one of the CFD bus's (5858), still with full interior https://publicsurplus.com/sms/chicago,il/auction/view?auc=2467477 29 minutes ago, NewFlyerMCI said: Seems like you'd need a tow capable of hauling it, seeing as it has no key or batteries The only current bidder is Adelman's, a salvage yard. With the poor condition noted, I doubt anyone would buy it to return it to service. Quote
YoungBusLover Posted December 27, 2019 Report Posted December 27, 2019 5 hours ago, Pace831 said: The only current bidder is Adelman's, a salvage yard. With the poor condition noted, I doubt anyone would buy it to return it to service. I wonder what the real cause was for it to get retired again, it was in running condition just last month. Quote
Shannon CVPI Posted December 27, 2019 Report Posted December 27, 2019 6 hours ago, YoungBusLover said: I wonder what the real cause was for it to get retired again, it was in running condition just last month. Guess they didnt wanna fix it Quote
