Random CTA
NewFlyerMCI
On 7/16/2025 at 10:05 PM, YoungBusLover said:
On 7/12/2025 at 9:23 AM, $100KBusoperator said:
#53 Pulaski Extension
The legends on the 53 notice that running ahead is allowed without permission on outer portions of the route during non-Owl hours leads me to ask: What is the policy on this? Are there portions of routes out of 77th where drivers otherwise would have permission to run ahead? Would this anger potential passengers who are at the bus  stop on time but are missed, are they expected to use the tracker, or doesn't it make a difference because the timepoints are too spread out?
I've seen these notes on #2 north of Balbo, I think #3 has it north of Roosevelt, #87 west of western. 103rd has it on J14 once it finishes it's express zone along with #146 out of NP. I gotta look through IRM to find the rest. J14 and 146 make sense due to them being pick up on one end and drop off on the other type of routes.
On 7/14/2025 at 6:44 AM, Shannon tahoeppv said:
All the buses here over on 89th & Woodlawn
Wonder does it still have its original amenities like the plastic seats in the back and steel boxy seats up front. I know the (1000) number is still inside over the next stop request sign while the fleet has the numbers under it. im pretty sure it still has its original log in screen on the wall in front over the driver seats where sometimes drivers used to reach to stand up to access the screen. Those have been relocated during the rehabs and the original spot is patched up. Second picture specifically.
The bus doesn’t have its original license plates from 20 years ago however it is this same unit despite falsely reports of it being returned to new flyer or replaced with #1005
In simple terms, were allowed to run ahead at the scheduled time on our run paddles at that particular time point. So for example. On Halsted at Belmont were allowed to run early at the scheduled time point indicated for us and also at 74th Street. I believe certain routes have this implemented into the running time on our paddles system wide. Now to answer your second question about the potential effects on passengers this is where frequency comes in based on overall demand throughout the course of the day. Which is why the control center has been cracking down so much on operators maintaining schedules properly no matter what time of day it is. It's gotten to the point where they're making sure we pull in to the garage at the scheduled time to make sure that the last runs of the evening aren't running ahead of schedule before pulling in. We're pretty much back to pre pandemic guidelines as far as enforcement and tolerance for transit operations. The CTA cut everyone some slack during the pandemic.
Here's some examples shown below from 77th. Notice how only certain routes have early time allowance while others don't.
The original 1000 in the photograph had chassis number 28549 and was returned to New Flyer. The first 20 delivered (1001-1020) had chassis numbers 29081-29100. The current 1000 has chassis number 31602 which puts its delivery between 1429 (30731) and 1430 (31793) - 2nd 1000, 1429, 1430 chassis numbers  from CTA official lists.
Ahhhh ok, looks like another prototype was made and delivered. It looks very familiar in @Shannon tahoeppv’s video
On 7/7/2025 at 9:52 PM, pokemonprime said:
Bus 1967 still has an older "No smoking, littering, eating or radio playing" sticker
it also has the new Ventra reader, but it's not yet active.PXL_20250707_203038560.thumb.jpg.4b88059619b390420450896f4fb1924e.jpg
What do the new Ventra readers look like? Do you know when they are supposed to roll out system wide?
They're twice the size of the older unit. I assume by then of the year they'll be ready for service.
Spotted a good number of novas with their markers lights off but with headlights on even at night time as some operators have the master switch on day run mode. On the 6400s there was a setting where headlights were off along with the markers, if the marker lights are activated the headlights are on. The 1000s used to have this no marker lights thing as well before the rehabs in 2014. It still happens with them but not as common as the novas as before.
The old Fishbowl had 3 settings.  One was Run which was the engine running with no lights. The second was Day Run which was with the marker lights on.  The last setting had the headlights and taillights and the markers.  Obviously this was well before daytime running lights existed.  It sounds like the first setting i mentioned still exists except the headlights are now on for all settings.  The second should enable the marker and the taillights.   IWhatever the case, it should be standard for all manufacturers.
12 hours ago, pokemonprime said:
spotted 2879 & 2880 today, sitting in Midway yard with Howard (Yellow) roll signs. Been quite a while since 2600s have run there, thought it was neat.
original_1c976f4e-3dd2-42d7-a856-b347729d0d29_PXL_20250906_172202027.thumb.jpg.5ac6e6eb28c30796e1870207e5b54ad4.jpgPXL_20250906_172205682.thumb.jpg.ea2a130a3fc09411197f917ccec8e746.jpg
Wait did we switch back to black text before the 5000s came in? I could've sworn we stayed with the new signs until the 5000s came....
Not 100% sure but it might be because white on yellow was hard to read so just the yellow line had black text
T'm not sure, but I don't think it ran on the Yellow Line. Yellow Line had single units and artics, 3200s, and 5000s. There was not a "Howard" roll, as the Red Line roll also had Brown Line. But I seem to recall the Yellow Line reading somewhere else, maybe by itself, but I'm not going back 15 years to resech it. Anyway, with cars that were stored with "Lake-Jackson Park" signsb  at Londen way back, I no longer make conclusions on where they ran.
As far as rolls this thread says that 1995-2006 you had a roll with Green, Blue and Orange; a roll with Red, Purple, Brown and Orange; then a roll with Red, Purple, Brown and Yellow. The rolls with red included the Wilson and Roosevelt signs, Ford City for the rolls with Orange, and 58th for the rolls with Green.
After 2006 it shows a roll with Green, Pink, Blue and Red; another for Brown, Orange, Red, Yellow and Purple; one with Brown, orange, green, red along with the black airport signs.
As far as yellow line cars I can't remember the exact number but there have been times where 2600s were briefly assigned, I definitely saw them around the time they tried White text on the Yellow signs.
