Erin Mishkin Jr. Posted December 29, 2020 Report Posted December 29, 2020 55 minutes ago, Shannoncvpi said: Yea when the hoods are up thats a sign bus brokedown Yep. And here are the pictures I got from his video as proof they broke down with the engine covers up. I also rode 1166 in June which kind of makes this a little sad too. Quote
Shannoncvpi Posted December 29, 2020 Report Posted December 29, 2020 10 hours ago, Erin Mishkin Jr. said: Yep. And here are the pictures I got from his video as proof they broke down with the engine covers up. I also rode 1166 in June which kind of makes this a little sad too. Yea sometimes control tell you if you can make it to your layover spot or they will break doen at layover then they will bring you a new bus it aint like back in the day when the driver just stayed with the bus & be towed back a garage worker now brings you another bus to continue your run 1 Quote
artthouwill Posted December 29, 2020 Report Posted December 29, 2020 2 hours ago, Shannoncvpi said: Yea sometimes control tell you if you can make it to your layover spot or they will break doen at layover then they will bring you a new bus it aint like back in the day when the driver just stayed with the bus & be towed back a garage worker now brings you another bus to continue your run In the case of the 28 at Union Station, 103rd is a mighty long way to bring a bus. If its a.m. rush, should be easier to get a bus deadheading back to 193rd or a bus that would be stored downtown to swap. Quote
Shannoncvpi Posted December 29, 2020 Report Posted December 29, 2020 58 minutes ago, artthouwill said: In the case of the 28 at Union Station, 103rd is a mighty long way to bring a bus. If its a.m. rush, should be easier to get a bus deadheading back to 103rd or a bus that would be stored downtown to swap. Just corrected bro you had said 193rd when you ment 103rd but yea it is a long way I a decent drive also just not as long as 3 is but yea it may have been 1 stored down there Quote
Erin Mishkin Jr. Posted January 22, 2021 Report Posted January 22, 2021 1029 has been delayed at Central and Altgeld facing NB for minutes now. it's follower bus 6869 has just passed it and the next bus behind (1024) will pass it too. It just went off the tracker and that probably means it's broken down when follow buses pass it when it's stuck for a while. Quote
Erin Mishkin Jr. Posted January 23, 2021 Report Posted January 23, 2021 Flip dot nova 6684 broke down on Harlem around 1:40 pm today. I saw it at 2:20 pm while riding 6826. Rear Engine door closed but there were two vans around it probably fixing up the bus. As of now there’s no replacement bus for that run and that bus’s block is before 6826 so passengers has to wait in the cold for 30 minutes. Luckily the 6826 driver was fast and we didn’t pick up too much people. 6684 is also a unit with the unusual transmission like 6710 Quote
artthouwill Posted January 23, 2021 Report Posted January 23, 2021 4 minutes ago, Erin Mishkin Jr. said: Flip dot nova 6684 broke down on Harlem around 1:40 pm today. I saw it at 2:20 pm while riding 6826. Rear Engine door closed but there were two vans around it probably fixing up the bus. As of now there’s no replacement bus for that run and that bus’s block is before 6826 so passengers has to wait in the cold for 30 minutes. Luckily the 6826 driver was fast and we didn’t pick up too much people. 6684 is also a unit with the unusual transmission like 6710 Harlem seems to get a lot of the 6400s with an occasional New Flyer or 7900. Quote
Erin Mishkin Jr. Posted January 23, 2021 Report Posted January 23, 2021 5 minutes ago, artthouwill said: Harlem seems to get a lot of the 6400s with an occasional New Flyer or 7900. Today we have 3 6400s and 3 1000s no newer novas. The old novas are getting more and more common on saturdays and last Saturday at 5pm there were 5 of them active and the only other bus was 8257. One of the novas (6724) replaced 1043 as well Quote
Erin Mishkin Jr. Posted January 23, 2021 Report Posted January 23, 2021 23 minutes ago, Erin Mishkin Jr. said: Flip dot nova 6684 broke down on Harlem around 1:40 pm today. I saw it at 2:20 pm while riding 6826. Rear Engine door closed but there were two vans around it probably fixing up the bus. As of now there’s no replacement bus for that run and that bus’s block is before 6826 so passengers has to wait in the cold for 30 minutes. Luckily the 6826 driver was fast and we didn’t pick up too much people. 6684 is also a unit with the unusual transmission like 6710 Ok they fixed it it’s operating again Quote
Shannoncvpi Posted January 23, 2021 Report Posted January 23, 2021 1 hour ago, Erin Mishkin Jr. said: Ok they fixed it it’s operating again What kinda trans they got to be unusual bro? Quote
Erin Mishkin Jr. Posted January 23, 2021 Report Posted January 23, 2021 28 minutes ago, Shannoncvpi said: What kinda trans they got to be unusual bro? Check out one of the 6710 videos posted on YouTube that’s what 6684 sounds like as well Quote
Shannoncvpi Posted January 24, 2021 Report Posted January 24, 2021 2 hours ago, Erin Mishkin Jr. said: Check out one of the 6710 videos posted on YouTube that’s what 6684 sounds like as well Aw ok I aint notice I even drove 6710 & 6862 when they was at K before they went back in service they both felt different with the trans 1 Quote
Erin Mishkin Jr. Posted January 24, 2021 Report Posted January 24, 2021 3 minutes ago, Shannoncvpi said: Aw ok I aint notice I even drove 6710 & 6862 when they was at K before they went back in service they both felt different with the trans Yep 6862 has normal and 6710 has the interesting sounding one Quote
Shannoncvpi Posted January 24, 2021 Report Posted January 24, 2021 Just now, Erin Mishkin Jr. said: Yep 6862 has normal and 6710 has the interesting sounding one Thinking about it they do Quote
Shannoncvpi Posted January 24, 2021 Report Posted January 24, 2021 Just now, Erin Mishkin Jr. said: Yep 6862 has normal and 6710 has the interesting sounding one Cuz I had both on the 18 & the 52 Quote
Erin Mishkin Jr. Posted January 24, 2021 Report Posted January 24, 2021 Just now, Shannoncvpi said: Cuz I had both on the 18 & the 52 Just now, Shannoncvpi said: Thinking about it they do Oh cool. Any other novas with the trans like in 6710 and 6684 I didn't heard yet Quote
Shannoncvpi Posted January 24, 2021 Report Posted January 24, 2021 1 minute ago, Erin Mishkin Jr. said: Oh cool. Any other novas with the trans like in 6710 and 6684 I didn't heard yet Those was the few I did drive that many we had like 10 at the garage until they went back to FG & the last of the 64's & 65's never came back Quote
Erin Mishkin Jr. Posted January 24, 2021 Report Posted January 24, 2021 10 minutes ago, Shannoncvpi said: Those was the few I did drive that many we had like 10 at the garage until they went back to FG & the last of the 64's & 65's never came back Oh ok Quote
Shannoncvpi Posted January 24, 2021 Report Posted January 24, 2021 4 hours ago, Erin Mishkin Jr. said: Oh ok Yea thats when they knocked the rest of them off Quote
Erin Mishkin Jr. Posted February 16, 2021 Report Posted February 16, 2021 8302 broke down on the 152 earlier today around 10am https://twitter.com/garpo3000/status/1361730172496601098/photo/1 Quote
Erin Mishkin Jr. Posted March 14, 2021 Report Posted March 14, 2021 Yesterday I was riding 8285 on the 78 and while we was going southbound on Elston, I heard a warning alarm coming from the front of the bus that sounded like there was an issue with the bus. The bus driver continued driving until he pulled over on Montrose & Springfield. The driver got out his cell phone and then exited his cab area of the bus. He said 8285 might be broken so he had to call in control. About 3 minutes later, he finished the call and control said the bus was okay to move again. The bus didn’t have any problems after that but I got off a few blocks later at Kimball. Quote
Erin Mishkin Jr. Posted March 17, 2021 Report Posted March 17, 2021 8281 broke down on Austin between Hirsch and potomac going south, bus has been stuck there for a while now on the tracker and has now went off the tracker at that location. Also 1391 broke down this morning on the 80 at Irving Park & Central park. Quote
Mr.NewFlyer1051 Posted March 17, 2021 Report Posted March 17, 2021 44 minutes ago, Erin Mishkin Jr. said: 8281 broke down on Austin between Hirsch and potomac going south, bus has been stuck there for a while now on the tracker and has now went off the tracker at that location. Also 1391 broke down this morning on the 80 at Irving Park & Central park. idk if it’s me or 1391 is having some sort of problem that flyer been in and out of SS Quote
Erin Mishkin Jr. Posted March 17, 2021 Report Posted March 17, 2021 1 minute ago, Mr.NewFlyer1051 said: idk if it’s me or 1391 is having some sort of problem that flyer been in and out of SS Wow, 1391 is stalking me and I can't stop hearing about that bus lol. Friday it was on 90 and I saw it too, Saturday I saw it on 78, yesterday it was back on 90, and today it broke down. Might be having issues but idk Quote
Mr.NewFlyer1051 Posted March 17, 2021 Report Posted March 17, 2021 1 minute ago, Erin Mishkin Jr. said: Wow, 1391 is stalking me and I can't stop hearing about that bus lol. Friday it was on 90 and I saw it too, Saturday I saw it on 78, yesterday it was back on 90, and today it broke down. Might be having issues but idk oh don’t worry a couple weeks ago every day i seen 1394 monday thru sunday i was like yo bro what’s up? Quote
