Busjack Posted June 1, 2015 Report Posted June 1, 2015 The diesel engines are connected to the wheels. The buses are powered by GM-Allison’s parallel hybrid drive system as are the 800s. The 900s had a serial drive where the wheels were powered only from the battery. Your SUV is probably serial/parallel operating in both modes depending on conditions (the Prius definitely is)....Both the Allison and Toyota systems have in common that there is a gearset in the transmission that determines how much, if any propulsion is provided by the petrol engine (gasoline or diesel) or the electric engine. I see that even Allison claims it mixes series and parallel operation, whatever that means. Something like the Chevy Volt (at least pre 2016) or Honda Accord might have either series or parallel propulsion in the sense of whether the gasoline engine is mechanically connected and disconnected from the wheels.The distinction is between that and the pure series system (900s and BAE), which has absolutely no connection between the petrol engine and the wheels. The shill electrician on Ask This Old House last week referred to it as "an electric car with a gas electric generator" while installing a charger for a pure electric car. Quote
sw4400 Posted June 1, 2015 Author Report Posted June 1, 2015 The diesel engines are connected to the wheels. The buses are powered by GM-Allison’s parallel hybrid drive system as are the 800s. The 900s had a serial drive where the wheels were powered only from the battery. Your SUV is probably serial/parallel operating in both modes depending on conditions (the Prius definitely is).All cta articulated buses are from New Flyer4000-4149 are DE60LF have bench seats in the front section only (58 seats)4150-4207 are DE60LF have the seats you photographed above and have bench seating in both sections (50 seats)4300-4332 are DE62LFR with conventional seating for 624333-4399 are D62LFR (diesel only) with conventional seating for 62Well..... kind of yes and kind of no.... the diesel engine powers the transmission, which is connected to the transaxle, which powers the drive wheels of the bus. With the hybrids, the diesel/electric hybrid engine powers the transmission. Quote
Busjack Posted June 1, 2015 Report Posted June 1, 2015 Well..... kind of yes and kind of no.... the diesel engine powers the transmission, which is connected to the transaxle, which powers the drive wheels of the bus. With the hybrids, the diesel/electric hybrid engine powers the transmission.Unless it doesn't have a transmission, or the leg bone is connected to the ankle bone. Quote
jajuan Posted June 2, 2015 Report Posted June 2, 2015 Maybe, but why not just send them more Novas, they can spare it now. What has been running the shuttles? FG buses? Unless they are worried about having old buses for shuttles. CTA always seems to run new buses for rail shuttles. I wouldn't be surprised if the shuttles were #4300's.But then again this #1000 move might not be a loan as FG will probably get some anyway within 2-3 months. Change might finally be coming for FG. Like Reagan told Gorby in the 80's "Tear down this wall!!" It seems CTA has done a good job at constructing one.Well not one bus sent out on the Yellow Line shuttles so far has been a New Flyer of any current CTA model, borrowed or otherwise and definitely no artics out there with the Yellow Line being such a relatively lower ridership rail route, from what I've seen each time I've been passing through Howard terminal during the few weeks so far since the Yellow Line service disruption began. All have been FG's Novas. Those NFs borrowed by FG haven't been getting used on the shuttles but on FG's regular routes. So that throws a monkey wrench in your older buses not being used on rail replacement shuttle work theory. And my comment about FG borrowing New Flyers was not meant to suggest or state that they're being borrowed for the express purpose of placing them on the Yellow Shuttle route. I mentioned the borrowing in conjunction with the shuttles only to say that FG has possibly been borrowing buses because it's been sending some of its Novas out to run the Yellow Line shuttle and thus needed buses to help operate its regular service routes. 1 Quote
jajuan Posted June 2, 2015 Report Posted June 2, 2015 I saw E270 in Rogers Park today, replacing some other piece of CFD equipment. It sounded so bad, I'm surprised it wasn't being towed. It also looked like crap.I live near the area so I've had similar thoughts about E270. I've seen it quite regularly at the Clark and Peterson firehouse, which I live walking distance from, and the firehouse further north at the firehouse up near Clark and Chase, which it sounds like might be the one you were near since you mentioned Rogers Park Quote
Sam92 Posted June 2, 2015 Report Posted June 2, 2015 Well not one bus sent out on the Yellow Line shuttles so far has been a New Flyer of any current CTA model, borrowed or otherwise and definitely no artics out there with the Yellow Line being such a relatively lower ridership rail route, from what I've seen each time I've been passing through Howard terminal during the few weeks so far since the Yellow Line service disruption began. All have been FG's Novas. Those NFs borrowed by FG haven't been getting used on the shuttles but on FG's regular routes. So that throws a monkey wrench in your older buses not being used on rail replacement shuttle work theory. And my comment about FG borrowing New Flyers was not meant to suggest or state that they're being borrowed for the express purpose of placing them on the Yellow Shuttle route. I mentioned the borrowing in conjunction with the shuttles only to say that FG has possibly been borrowing buses because it's been sending some of its Novas out to run the Yellow Line shuttle and thus needed buses to help operate its regular service routes.they probably got some form of interline as far as North Park runs on shuttles. I remember seeing like 3 or 4 4300s out there when I went but that was still kinda in the rush so that may have a part in it too. Quote
Sam92 Posted June 2, 2015 Report Posted June 2, 2015 and while I'm here.... Isn't there a pick supposed to be going on for the summer? I haven't seen any signage or alerts about it other than beach service. Maybe the yellow line outage is making things strained Quote
jajuan Posted June 2, 2015 Report Posted June 2, 2015 they probably got some form of interline as far as North Park runs on shuttles. I remember seeing like 3 or 4 4300s out there when I went but that was still kinda in the rush so that may have a part in it too.Well while catching up on the posts I missed due to work and Memorial Day, I did learn in the rail thread devoted to the Yellow Line disruption that NP has indeed sent some buses out on the shuttles but oddly enough in addition, to the rush hour artics you saw a few times, a lot of it during evening times that CTA overall ridership tends to be smaller or taper off from rush period daily highs. A lot of my times passing through Howard terminal since the accident sidelining the Yellow Line occurred have been pretty much been during the later parts of AM rush and weekday daytime off peak hours. And those times it seems that FG handles of lot of the shuttle service if not all of it during those times. And yeah, when the summer pick starts in about three weeks time, the expansion of the beach services to full through trips from the current shuttle buses extensions connecting to the relevant main routes might make things interesting. However, the route giving beach service relevant to FG is the 78, and the 78's beach service has always been restricted to weekends only from the moment CTA expanded its beach service to include that route. So the impact on FG might not be too high given many of FG's assigned routes outside of the few "core"/high service level routes it has have drastically reduced weekend service levels or no weekend service at all. The real question is whether this service disruption on the Yellow Line will extend very far into the summer pick. Quote
BusHunter Posted June 2, 2015 Report Posted June 2, 2015 @Jajuan: That's why I went up there and was shocked they were running the old junk. Take riders off a new #5000 and put them on an old junk bus that's about had it. BTW, I saw a few dead ones today. #6554 on the #37 kept dying out. I saw the bus stranded twice and #6836 was dead on the #152. I don't know how FG can keep these old junks going. #6474 actually had some good acceleration today on the #80. But soon they will get some fresher buses, there is only 87 left and each #1000 rehabbed now sends a Nova to FG. Some buses will probably get retired and never move so they might really be moving just 60-65 buses. If they receive the #8100's regardless of where they'll go, then that's it for an all #6400 fleet at FG. It's been too long in coming already. Quote
jajuan Posted June 2, 2015 Report Posted June 2, 2015 @Jajuan: That's why I went up there and was shocked they were running the old junk. Take riders off a new #5000 and put them on an old junk bus that's about had it. BTW, I saw a few dead ones today. #6554 on the #37 kept dying out. I saw the bus stranded twice and #6836 was dead on the #152. I don't know how FG can keep these old junks going. #6474 actually had some good acceleration today on the #80. But soon they will get some fresher buses, there is only 87 left and each #1000 rehabbed now sends a Nova to FG. Some buses will probably get retired and never move so they might really be moving just 60-65 buses. If they receive the #8100's regardless of where they'll go, then that's it for an all #6400 fleet at FG. It's been too long in coming already. Speaking of 6400s, I was surprised to see more than one on the #9 this morning in less than hour's time. 6400s at 74th have become so few that it's gotten to a point that it takes an hour or more a lot of times to see more than one in service on the #9. And the #94 has once again gone from majority Nova weekdays to majority New Flyer for the first time since that route went from split 74th and Chicago garage coverage to full 74th coverage. Quote
Guest Posted June 2, 2015 Report Posted June 2, 2015 I saw E270 in Rogers Park today, replacing some other piece of CFD equipment. It sounded so bad, I'm surprised it wasn't being towed. It also looked like crap.I love how those spare trucks drive. They have the same DD 6V92 like the old Pace Orion Is. When I get a chance to drive one, they remind me of the Orion Is that I drove for Pace. Quote
briman94 Posted June 2, 2015 Report Posted June 2, 2015 Well..... kind of yes and kind of no.... the diesel engine powers the transmission, which is connected to the transaxle, which powers the drive wheels of the bus. With the hybrids, the diesel/electric hybrid engine powers the transmission.On a typical hybrid drive like my Toyota SUV or a Prius or something, the engine's starter acts as a generator, but the engine can also be mechanically connected to and disconnected from the transmission on demand, so it can either power the battery or the wheels or both. Quote
BusHunter Posted June 5, 2015 Report Posted June 5, 2015 #6844 went back to 74th yesterday it was on the #63. This morning it was on the #62H Quote
briman94 Posted June 5, 2015 Report Posted June 5, 2015 Is it normal for a Purple Line to R6.4 halfway downtown? Between basically every stop we'd be going fine, and then slow down to ~10-15 MPH and the thing would start beeping every few seconds. I've never seen that happen before except during construction or single-tracking. Quote
Busjack Posted June 5, 2015 Report Posted June 5, 2015 Is it normal for a Purple Line to R6.4 halfway downtown? Between basically every stop we'd be going fine, and then slow down to ~10-15 MPH and the thing would start beeping every few seconds. I've never seen that happen before except during construction or single-tracking.Depends where. I've been on some where the Purple was following the Brown too closely, and since it did not have helicopter rotors, beeped every time the Brown stopped at a station. And, since the stations are every 2 blocks or so, that meant it beeped pretty constantly. Quote
briman94 Posted June 5, 2015 Report Posted June 5, 2015 Depends where. I've been on some where the Purple was following the Brown too closely, and since it did not have helicopter rotors, beeped every time the Brown stopped at a station. And, since the stations are every 2 blocks or so, that meant it beeped pretty constantly.We were behind a brownage and a brown line, but this was between Armitage and Mart...I didn't think the signals were that dense in those locations. Quote
Busjack Posted June 5, 2015 Report Posted June 5, 2015 We were behind a brownage and a brown line, but this was between Armitage and Mart...I didn't think the signals were that dense in those locations.It isn't how dense the signals are, but how close on the prior train's tail you were. However, the Brownage wouldn't have as many stops in that stretch.It still highlights what you implied in your other thread that the Purple should go into the subway, but with all the proposed construction zones on the north main, I don't see the Purple really being express until maybe 2027. Quote
briman94 Posted June 5, 2015 Report Posted June 5, 2015 It isn't how dense the signals are, but how close on the prior train's tail you were. However, the Brownage wouldn't have as many stops in that stretch.It still highlights what you implied in your other thread that the Purple should go into the subway, but with all the proposed construction zones on the north main, I don't see the Purple really being express until maybe 2027.Probably not. Although I do have to say, I'm quite impressed with the progress so far on the track rehab for the Ravenswood connector. In the 5000s, it's like riding on a cloud because they've removed a lot of joints. Quote
garmon757 Posted June 8, 2015 Report Posted June 8, 2015 Breaking News: #1357 has returned back to service after nearly a year being OOS. It's currently on #12. Is it rehabbed though? Quote
Busjack Posted June 8, 2015 Report Posted June 8, 2015 Looks like someone figured out how to make a bit of money or have a bit of amusement on the Random CTA. Tribune Quote
joerailfan2015 Posted June 8, 2015 Report Posted June 8, 2015 (edited) DNAinfo did an article with the voice of the CTA surprising riders. Edited June 8, 2015 by joerailfan2015 Quote
Busjack Posted June 8, 2015 Report Posted June 8, 2015 DNAinfo did an article with the voice of the CTA surprising riders. That was good for a laugh.But he lied at about 1:00--he didn't stay on that train forever. Quote
garmon757 Posted June 9, 2015 Report Posted June 9, 2015 I thought this was pretty cool. A CNG cement truck. Quote
strictures Posted June 9, 2015 Report Posted June 9, 2015 I thought this was pretty cool. A CNG cement truck.I've been seeing them for the last year or so. Plus almost all of Peoples Gas trucks are CNG. Quote
garmon757 Posted June 9, 2015 Report Posted June 9, 2015 I've been seeing them for the last year or so. Plus almost all of Peoples Gas trucks are CNG.I seriously didn't know that. 1 Quote
