CTA Rail Service Alerts
Rail Line(s) Affected: Blue
Information: O-Hare-bound trains are experiencing residual delays after an earlier minor track fire near Logan Square.
Blue line is stopped at logan square and we have helicopters over here. CTA says they had a track fire this morning in the vicinity. Maybe it rekindled.
Trains are moving again.
Aside from three O'Hare bound trains clumped together around Rosemont, I don't see anything unusual on the visual train tracker. Interesting...
12/17/14 1:33a
Construction Alert For 12/17/14 @ 9:30a until 2:30p
Rail Line(s) Affected: Green
Level Of Service Interruption: --
Information: Harlem/Lake-bound trains will not stop at 47th.
  • Service to 47th: Take a Harlem/Lake-bound train to 43rd and transfer to a 63rd-bound train
  • Service from 47th: Take a 63rd-bound train to 51st and transfer to a Harlem/Lake-bound train.
This is due to platform improvements to the 47th St. station.
12/20/14 2:09a
Upcoming Alert For 12/20/14 @ 1:40a until 11:40a
Level Of Service Interruption: Service Disrupted w/Alternate Service Available
Information: Trains operate between Harlem/Lake, Downtown(Loop Elevated), and Roosevelt and between 35th-Bronzeville-IIT, Ashland/63rd, and Cottage Grove.
Alternate Service: Shuttle Buses will replace rail service between Roosevelt and 35th-Bronzeville-IIT. Free transfer between Shuttle Buses and Rail Service is only available at Roosevelt and 35th-Bronzeville-IIT, and requires the farecard used to pay your fare at the start of your trip.
This is due to construction of the new Cermak-McCormick Place station
12/21/14 2:03a
Upcoming Alert For 12/21/14 @ 1:40a until 11:40a
12/21/14 2:04a
Upcoming Rail Alert For 12/21/14 @ 6a until 6p
Rail Line(s) Affected: Brown
Information: Trains in both directions will operate on the same track between Armitage and Merchandise Mart.
  • 6a-12p: Board/Exit all trains on the Kimball-bound platform at Sedgwick and Chicago.
  • 12p-6p: Board/Exit all trains on the Loop-bound platform at Sedgwick and Chicago.
This is due to structural improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project.
12/23/14 5:37p
Rail Line(s) Affected: Brown, Green, Orange, Purple, Pink
Level Of Service Interruption: Significant Delays
Information: Brown, Orange, Purple, Pink & 63rd-bound Green Line trains are experiencing delays due to congestion on the Inner Loop track.
Service Interruption Update(7:53p): Service has been downgraded to Major Delays due to ongoing congestion on the Inner Loop track.
Service Interruption Update(10:46p): Service continues to have Major Delays due to ongoing congestion on the Inner Loop track. The CTA website has this continuing until 12/30/14 @ 9:44p, which may be a bit exaggerated unless something is so badly damaged on the Outer Loop tracks that it's going to take a week to repair.
12/23/14 7:42p
Level Of Service Interruption: Minor Delays w/Reroute
Information: Brown Line trains are experiencing delays and being rerouted due to switching problems at the Lake/Wells junction.
Brown Line trains are being rerouted to the Inner Loop track(Orange Line) around the Loop Elevated. The first stop for the Brown Line after Merchandise Mart is Clark/Lake(Blue Line Subway)
12/23/14 7:42p
Still on the inner Loop track as of 11:51 PM.
Yeah, it's still marked TBD... this might run until some point later today or the next few days, depending on what's causing the switching issues and what needs to be repaired/replaced(that and the fact there's probably only a small maintenance crew right now for the Christmas holiday).
I was just on a Purple that pulled in to Clark/Lake. Could see a crew working on the switch on the Eastbound track. Presumably a problem with the switch that serves the green/brown line there.
12/26/14 10:55p
Construction Alert For 12/27/14 @ 6:30a until 5p
Information: Kimball-bound trains will not stop at Diversey.
  • Service to Diversey: Take a Kimball-bound train to Wellington and transfer to a Loop-bound train
  • Service from Diversey: Take a Loop-bound train to Fullerton and transfer to a Kimball-bound train.
This is due to track maintenance to ensure that trains continue to operate safely along the Brown Line.
12/28/14 1:41a
Upcoming Rail Alert For 12/28/14 @ 6a until 6p
1/3/15 12:30a
Upcoming Rail Alert For 1/3/15 @ 6a until 6p
Rail Line(s) Affected: Red
Information: Howard-bound trains will not stop at Bryn Mawr, Thorndale, Granville, Loyola, Morse or Jarvis.
  • Service from these stations: Take a 95th-bound train to Berwyn and transfer to a Howard-bound train.
  • Service to these stations: Take a Howard-bound train to Howard and transfer to a 95th-bound train.
This is due to track maintenance to ensure that trains continue to operate safely along the Red Line.
1/4/15 2:04a
Upcoming Rail Alert For 1/4/15 @ 6a until 6p
Information: Trains in both directions will operate on the same track between Armitage and Merchandise Mart. Board/Exit all trains on the Loop-bound platform at Sedgwick and Chicago.
