sw4400 Posted January 5, 2015 Author Report Posted January 5, 2015 1/5/15 2:27p Rail Line(s) Affected: Blue Level Of Service Interruption: Minor Delays Information: O-Hare-bound trains are experiencing delays due to a earlier mechanical problem on a train at Forest Park. Quote
sw4400 Posted January 5, 2015 Author Report Posted January 5, 2015 1/5/15 2:29p Rail Line(s) Affected: Yellow Level Of Service Interruption: Minor Delays Information: Skokie-bound trains are experiencing delays after an earlier switching problem near Hamlin. Quote
sw4400 Posted January 7, 2015 Author Report Posted January 7, 2015 1/7/15 2:29a ***Late Night Rail Alert*** Rail Line(s) Affected: Red Level Of Service Interruption: Service Disrupted w/Reroute Information: Howard-bound trains are being rerouted to the elevated tracks due to Police Activity at Clark/Division. Service To Howard: After stopping at Cermak-Chinatown, trains will operate on the elevated tracks and make the following stops: Roosevelt Adams/Wabash Madison/Wabash Randolph/Wabash State/Lake(Red) Clark/Lake(Blue) Merchandise Mart Chicago/Franklin Sedgwick Armitage Trains will then stop at Fullerton and make all normal Red Line stops to Howard. Connections to 95th-bound trains and rerouted Howard-bound trains can be made at Fullerton, State/Lake(board Howard-bound trains on elevated platform, Brown Line side) and at Roosevelt. Quote
sw4400 Posted January 8, 2015 Author Report Posted January 8, 2015 1/8/14 2:07p Rail Line(s) Affected: Red Level Of Service Interruption: Minor Delays Information: 95th-bound trains are operating with delays after an earlier sick passenger near Roosevelt. Quote
garmon757 Posted January 8, 2015 Report Posted January 8, 2015 If anybody is entering the Red Line at 69th then please be advised that the water main line is busted causing downstairs by the platform to flood (very dangerous due to the extreme weather). #3, #4, #6, #8, #9, #J14, #15, #24, #28, #29, #49 and Green Line can be alternates for your trip. Please be mindful and safe everybody. Quote
sw4400 Posted January 11, 2015 Author Report Posted January 11, 2015 1/11/15 12:54a Upcoming Rail Alert For 1/11/15 @ 6a until 6p Rail Line(s) Affected: Brown Level Of Service Interruption: Minor Delays Information: Trains in both directions will operate on the same track between Armitage and Merchandise Mart. Board/Exit all trains on the Loop-bound platform at Sedgwick and Chicago. This is due to structure improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project. Quote
sw4400 Posted January 11, 2015 Author Report Posted January 11, 2015 1/11/14 12:57a Upcoming Alert For 12/11/14 @ 1:40a until 11:40a Rail Line(s) Affected: Green Level Of Service Interruption: Service Disrupted w/Alternate Service Available Information: Trains operate between Harlem/Lake, Downtown(Loop Elevated), and Roosevelt and between 35th-Bronzeville-IIT, Ashland/63rd, and Cottage Grove. Alternate Service: Shuttle Buses will replace rail service between Roosevelt and 35th-Bronzeville-IIT. Free transfer between Shuttle Buses and Rail Service is only available at Roosevelt and 35th-Bronzeville-IIT, and requires the farecard used to pay your fare at the start of your trip. This is due to construction of the new Cermak-McCormick Place station Quote
sw4400 Posted January 11, 2015 Author Report Posted January 11, 2015 1/11/15 12:58a Upcoming Alert For 12/11/14 @ 4:30a until 4p Rail Line(s) Affected: Orange Level Of Service Interruption: -- Information: Trains will operate counterclockwise on the Outer Loop. Board/Exit Orange Line trains on the Brown Line platform at all Loop stations. This is due to track maintenance to ensure that trains continue to operate safely on the Loop Elevated. Quote
peter.pyterek Posted January 11, 2015 Report Posted January 11, 2015 1/11/15 12:58a Upcoming Alert For 12/11/14 @ 4:30a until 4p Rail Line(s) Affected: Orange Level Of Service Interruption: -- Information: Trains will operate counterclockwise on the Outer Loop. Board/Exit Orange Line trains on the Brown Line platform at all Loop stations. This is due to track maintenance to ensure that trains continue to operate safely on the Loop Elevated.How does this not require the Pink Line to be rerouted counterclockwise, or the 63rd-bound Green Line via Wells and VanBuren? Because they run on the Inner Loop too. Quote
Busjack Posted January 11, 2015 Report Posted January 11, 2015 How does this not require the Pink Line to be rerouted counterclockwise, or the 63rd-bound Green Line via Wells and VanBuren? Because they run on the Inner Loop too. May depend on whether the work is only at the crossover at Wabash-Van Buren as only the Orange Line makes that crossover. Quote
Chicago13 Posted January 11, 2015 Report Posted January 11, 2015 May depend on whether the work is only at the crossover at Wabash-Van Buren as only the Orange Line makes that crossover. How does this not require the Pink Line to be rerouted counterclockwise, or the 63rd-bound Green Line via Wells and VanBuren? Because they run on the Inner Loop too. Correct me if I'm wrong but only the Pink Line would be affected. The Green Line doesn't run on the Wells-Van Buren leg of the loop Quote
Busjack Posted January 11, 2015 Report Posted January 11, 2015 Correct me if I'm wrong but only the Pink Line would be affected. The Green Line doesn't run on the Wells-Van Buren leg of the loop It doesn't, but the alert didn't say where the work was being done, only that the Orange Line was going on the Brown Line loop direction.. If the southbound track on Wabash were affected, so would the Green Line. That's why my guess about where the work was being done. Quote
peter.pyterek Posted January 11, 2015 Report Posted January 11, 2015 It doesn't, but the alert didn't say where the work was being done, only that the Orange Line was going on the Brown Line loop direction.. If the southbound track on Wabash were affected, so would the Green Line. That's why my guess about where the work was being done.Also, I was starting to bet that they could be working on the right-turn Wells-to-Lake track. That would make sense as well. Quote
BusHunter Posted January 14, 2015 Report Posted January 14, 2015 They got some problems with forest pk bound blue line trains right now. They have 5 trains stacked between logan and addison. The train at logan had an electrical smell. They say that's a brake issue. The titan signs say that trains are moving after a problem with a train at jeff. I think they are still having trouble with that same train. 1 Quote
MTRSP1900-CTA3200 Posted January 16, 2015 Report Posted January 16, 2015 Four lines have weekend service changes for maintenance this weekend, and involve the Pink and Orange Lines going counter-clockwise around the Loop, 95th bound Red Line trains going "over the top", and Green Line trains only running between Harlem and Roosevelt and 35-Bronzeville-IIT and the 63rd Terminals. An overview for the work can be found here. Info for the Red Line work and reroute can be found here. Info for the Pink Line and Orange Line work and reroute can be found here. Info for the Green Line work and service alteration can be found here. 2 Quote
artthouwill Posted January 16, 2015 Report Posted January 16, 2015 Four lines have weekend service changes for maintenance this weekend, and involve the Pink and Orange Lines going counter-clockwise around the Loop, 95th bound Red Line trains going "over the top", and Green Line trains only running between Harlem and Roosevelt and 35-Bronzeville-IIT and the 63rd Terminals. An overview for the work can be found here. Info for the Red Line work and reroute can be found here. Info for the Pink Line and Orange Line work and reroute can be found here. Info for the Green Line work and service alteration can be found here. What seems crazy is that they are providing shuttle bus service between Roosevelt and 35/IIT-Bronzeville when those customers could easily just transfer to the rerouted Red Line and ride to 35th. You could do a much shorter bus shuttle between the 35th Red and GReen Line stations with less buses. Quote
Busjack Posted January 17, 2015 Report Posted January 17, 2015 What seems crazy is that they are providing shuttle bus service between Roosevelt and 35/IIT-Bronzeville when those customers could easily just transfer to the rerouted Red Line and ride to 35th. You could do a much shorter bus shuttle between the 35th Red and GReen Line stations with less buses. But that's what they have been consistently providing. Maybe the theory is that someone from 63rd wants to get to somewhere further north or then west on the Green Line. Quote
artthouwill Posted January 17, 2015 Report Posted January 17, 2015 But that's what they have been consistently providing. Maybe the theory is that someone from 63rd wants to get to somewhere further north or then west on the Green Line. That still doesn't change the point of the transfer at 35th to a shuttle service. Though the Roosevelt to 35th/IIT= Bronzeville has been consistent over weekends, a rare opportunity to lessen the shuttles and be more cost effective exists this weekend because the Red Line trains are being rerouted over the Loop elevated southbound. However, I suppose NB travelers would have a hike walking from the subway station up to the elevated platform at Roosevelt even with escalators in place/ Quote
Busjack Posted January 17, 2015 Report Posted January 17, 2015 That still doesn't change the point of the transfer at 35th to a shuttle service. Though the Roosevelt to 35th/IIT= Bronzeville has been consistent over weekends, a rare opportunity to lessen the shuttles and be more cost effective exists this weekend because the Red Line trains are being rerouted over the Loop elevated southbound. However, I suppose NB travelers would have a hike walking from the subway station up to the elevated platform at Roosevelt even with escalators in place/ Maybe someone figured no sense confusing the passengers worse than they already were. Quote
sw4400 Posted January 21, 2015 Author Report Posted January 21, 2015 1/20/15 8:43p Rail Line(s) Affected: Red, Purple Level Of Service Interruption: Major Delays Information: Some trains are operating with residual delays after an earlier medical emergency on the track near Thorndale. Quote
sw4400 Posted January 22, 2015 Author Report Posted January 22, 2015 1/22/15 2:31a ***Late Night Rail Alert*** Rail Line(s) Affected: Blue Level Of Service Interruption: Minor Delays Information: O-Hare-bound trains are operating with delays after an earlier mechanical problem on a train at Kedzie-Homan. Quote
sw4400 Posted January 23, 2015 Author Report Posted January 23, 2015 1/23/15 1:15p Upcoming Rail Alert For 1/23/15 @ 10p until 1/25/15 @ 6a Rail Line(s) Affected: Red Level Of Service Interruption: Service Disruption w/Reroute Information: 95th-bound trains are rerouted to the elevated tracks between Fullerton and Cermak-Chinatown. North/Clybourn, Clark/Division, Chicago and Grand stations: Service From these stations: Take a Howard-bound train to Fullerton and transfer to a 95th-bound train. Service To these stations: Take a 95th-bound train to State/Lake and transfer to a Howard-bound train(State St. Subway). Downtown: Board/Exit 95th-bound trains at any Lake or Wabash Loop Elevated stations. Roosevelt Station: Board/Exit 95th-bound trains on Green/Orange Elevated platform. This is due to maintenance in the State Street Subway and improvements at the Clark/Division station. Quote
sw4400 Posted January 23, 2015 Author Report Posted January 23, 2015 1/23/15 1:29p Upcoming Alert For 1/24/15 @ 1:40a until 1/26/15 @ 4a Rail Line(s) Affected: Green Level Of Service Interruption: Service Disrupted w/Alternate Service Available Information: Trains operate between Harlem/Lake, Downtown(Loop Elevated), and Roosevelt and between 35th-Bronzeville-IIT, Ashland/63rd, and Cottage Grove. Alternate Service: Shuttle Buses will replace rail service between Roosevelt and 35th-Bronzeville-IIT. Free transfer between Shuttle Buses and Rail Service is only available at Roosevelt and 35th-Bronzeville-IIT, and requires the farecard used to pay your fare at the start of your trip. This is due to construction of the new Cermak-McCormick Place station Quote
sw4400 Posted January 25, 2015 Author Report Posted January 25, 2015 1/25/15 3:17a Upcoming Rail Alert For 1/25/15 @ 6a until 6p Rail Line(s) Affected: Brown Level Of Service Interruption: Minor Delays Information: Trains in both directions will operate on the same track between Armitage and Merchandise Mart. Board/Exit all trains on the Loop-bound platform at Sedgwick and Chicago. This is due to structure improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project. Quote
sw4400 Posted January 26, 2015 Author Report Posted January 26, 2015 1/26/15 2:14a ***Late Night Rail Alert*** Rail Line(s) Affected: Brown Level Of Service Interruption: Service Disruption Information: Loop-bound trains have been rerouted via the Inner Loop tracks due to track switching problems. After Merchandise Mart, the first stop for Brown Line trains will be Clark/Lake(Blue). Quote
