7000-series - Delivery & Updates
railfan4072
8 minutes ago, Sam92 said:
I get what you're saying trust me. And for all we know Rosemont can be putting out all of the 7000s it has but again theyre still a relatively small percentage (30%) of the fleet so if you've only been able to check on the Congress branch (which has 50% of the service) you're gonna have maybe a 15-30% chance of seeing a 7000 compared to a 30-50% chance of seeing one at Jackson or anywhere north of the short turn cause majority of whatever they're running is going to stay east of Halsted
I get that I'm only going to see a small portion of what could be on the lune since the Forest Park branch is the shorter and less frequent of the two branches.  I was able to observe a little more since I was downtown and some of the short turns were 2600s/3200s.    I would probably bet that if I went to O'Hare,  I would see more 7000s in Rosemont yard than I would see in service.   There has to be a reason for that.
There "has to be a reason" for your "probably bet," as by saying that you have no factual basis. How about taking the trip to O'Hare instead of making suppositions (which you have done an awful lot lately)?
On 9/22/2024 at 9:25 AM, artthouwill said:   I would probably bet that if I went to O'Hare,  I would see more 7000s in Rosemont yard than I would see in service.   There has to be a reason for that.
Yeah, to be honest I agree with this. I take blue from Wicker to O’Hare about once a week, and have at least 10 times since the summer.
I’m 0-10 (minimum) on 7000’s. There’s nearly always anywhere from 3-6 consists parked up there. I probably have awful odds but I’d be shocked if more than 25% of runs are 7000’s and bet it’s closed to 15-20.
in fact, right now I’m back from O’Hare. All 3 trains at ORD with 32/26’s, and we’ve passed 3 trains that are 32/26’s.
10 hours ago, scotthilly said:
When, if ever, are they going to switch the destination signs on these trains to not be a weird, hazy, washed out color?
when 5000’s came in they pretty quickly reverted the orange signs to full color LED’s. Surprised they haven’t fixed the 7000 series ones as they’re quite hard to read.
  1. We aren't clairvoyant.
  2. Since you bring up the 5000s, the Chief Engineer makes that decision. If you care, why not contact that office?
No. They were physically replaced with color units. The originals did not support color other than amber. Not sure about the issue with haziness you're describing. It's just a slightly lighter blue that matches the official Blue Line color (Pantone 299C) more closely.
Right, but regardless, they switched them out. And the 7000 signs are much less bright and have, like I said, a weird neutral look for every line. It’s much harder to distinguish color. Here’s a good example. There’s tons more on YouTube, Chicago-l, etc.
by the way, you can tell it’s objectively a different screen setup because it doesn’t come across in videos or photos.
Cannot see your photos. Regardless, LEDs do not photograph well, if that is the issue you are alluding to. I have not observed the problems you're describing in person. If anything, they may have a higher dot resolution, which would require a different rendering for the text, and might also make photographs appear worse than on the 5000s/3200s. They also seem to have improved color accuracy. Perhaps that makes them look less vibrant to you, but they are more accurate to CTA brand colors. Color LEDs were pretty new technology when the 5000s got them -- if you compare, it's really the 5000s that have distorted colors. We're just used to seeing those.
Well I stand by your point. I don’t like the LEDs on the 7000s myself as well they should of have retrofitted them with the same ones the 3200s and 5000s have, as the LEDs in videos remind me of old skool TVs back then that shows the grey screening that was caused by HDMI malfunctioning cables
This isn't entirely accurate. Go on youtube or the internet and search BART, MUNI, MTA, DC metro... they all have LED signs and all video and photograph perfectly. The run numbers on the 7000's are also LED and yet they photograph, and video, perfectly. All 3200 / 5000's photograph, and videotape, very well if not perfectly on both run numbers and destinations.
This is a 7000 destination sign specific issue and I believe backs up my statement that in person they're washed out, less visible, and hazy.
Not only that, but the verbiage on the sign itself is smaller and not as bolded. It's evident from the above photos.
