8/10/14 1:09a
Upcoming Rail Alert For 8/10/14 @ 6:30a until 7p
Rail Line(s) Affected: Brown
Information: Trains in both directions will operate on the same track between Fullerton and Sedgwick.
  • 6:30a-12p: Board/Exit all trains on the Loop-bound platform at the Armitage station.
  • 12p-7p: Board/Exit all trains on the Kimball-bound platform at the Armitage station.
This is due to structural improvements to remove slow zones and improve rail service on the Brown Line as part of the Ravenswood Connector Rehabilitation Project.
This has to be one of the most weirdest single-track operations in a while because I'm on the Brown Line now and so far, they're having northbound trains - crossing the Larrabee/Sedgwick crossover - reverse/divert the trains back to Sedgwick by switching them to the inbound/southbound track - then having them crossing the crossover again without switching! Like damn, they couldn't just have them switch to the inbound track without doing all that crap?!?!?!
8/11/14 1:55p
Construction Alert For 8/11/14 @ 9:30a until 2p
Rail Line(s) Affected: Green
Level Of Service Interruption: --
Information: 63rd-bound trains will not stop at 51st station.
  • Service to 51st: Take a 63rd-bound train to Garfield and transfer to a Harlem/Lake-bound train
  • Service from 51st: Take a Harlem/Lake-bound train to 47th and transfer to a 63rd-bound train.
This is due to platform improvements to the 51st St. station.
8/12/14 2:08a
Construction Alert For 8/12/14 @ 9:30a until 2p
8/13/14 1:36a
Construction Alert For 8/13/14 @ 9:30a until 2p
8/14/14 1:53a
Construction Alert For 8/14/14 @ 9:30a until 2p
8/14/14 10:35a
Rail Line(s) Affected: Blue
Level Of Service Interruption: Major Delays
Information: O-Hare-bound trains are standing near Clinton due to a mechanical problem on a train.
8/14/14 10:35a
The Blue Line curse strikes again.
8/14/14 10:35a
Sadly enough that I was on that damn train with that problem this morning. Idk what happened that lead to that but the first 3 cars were inside the portal but the jacked up part was that they reversed the train back to UIC-Halsted and the conductor said that the train was going out of service. However, 30 seconds later the conductor said hold on and told us to get back on the defected train and continue the route to O'Hare. Only Cta!!! :huh:
8/14/14 11:05p
Rail Line(s) Affected: Purple
Information: Loop/Howard-bound trains are being delayed after an earlier sick employee at Linden.
8/15/14 12:34a
Construction Alert For 8/15/14 @ 9:30a until 2p
8/15/14 9:29p
Upcoming Rail Alert For 8/16/14 @ 2:40a until 8/18/14 @ 4a
Level Of Service Interruption: Service Disrupted w/Alternate Service Available
Information: Trains will operate between Western and The Loop Elevated.
Alternate Service: Shuttle Buses replace rail service between Western and Kimball. The #81 Lawrence bus can also be used as an alternate to rail service and makes stops at Rockwell, Sacramento and Kedzie.
8/17/14 11:51p
Construction Alert For 8/18/14 @ 9:30a until 2p
8/18/14 9:46p
Construction Alert For 8/19/14 @ 9:30a until 2p
8/20/14 12:52a
Construction Alert For 8/20/14 @ 9:30a until 2p
8/21/14 1:52a
Construction Alert For 8/21/14 @ 9:30a until 2p
8/21/14 9:58p
Construction Alert For 8/22/14 @ 9:30a until 2p
Blue Line service will be shut down between Damen/Milwaukee and Kedzie/Milwaukee (Logan Square) due to Your New Blue track work. Work will last from 10pm on Friday to 4am on Monday. Free shuttle bus service is available between Logan Sq. and Clark/Lake. Trains will run between O'Hare and Logan Sq. and Damen/Milwaukee and Forest Park (via downtown).
This looks like the biggest service modification so far. We'll see.
8/22/14 11:43p
Upcoming Rail Alert For 8/23/14 @ 6:30a until 7p
8/22/14 11:44p
Overnight until Late Morning Rail Alert
Upcoming Alert For 8/23/14 @ 1:40a until 11:40a
Information: Trains operate between Harlem/Lake, Downtown(Loop Elevated), and Roosevelt and between 35th-Bronzeville-IIT, Ashland/63rd, and Cottage Grove.
Alternate Service: Shuttle Buses will replace rail service between Roosevelt and 35th-Bronzeville-IIT. Free transfer between Shuttle Buses and Rail Service is only available at Roosevelt and 35th-Bronzeville-IIT, and requires the farecard used to pay your fare at the start of your trip.
This is due to construction of the new Cermak-McCormick Place station
8/23/14 11:36a
Rail Line(s) Affected: Red, Purple, Yellow
Information: Trains are operating with delays due to a loss of power at Howard.
  • Board/Exit all Skokie-Dempster bound Yellow Line and Linden-bound Purple Line trains on the 95th-bound platform at Howard.
